daberti(at)sbcglobal.net Guest
Posted: Sun Jan 02, 2011 8:25 am Post subject: GNS 430 Calibration sequence |
Does anyone on the list have documentation on the initial setup for a 430, calibration with other instruments, that they can share?
tim2542(at)sbcglobal.net Guest
Posted: Sun Jan 02, 2011 10:02 am Post subject: GNS 430 Calibration sequence |
What are you connecting it to? The install
manual has a lot of info in it for connecting and
configuring various peripheral equipment.
Tim Andres
On Jan 2, 2011, at 8:19 AM, "Dave" <daberti(at)sbcglobal.net (daberti(at)sbcglobal.net)> wrote:
[quote] Does anyone on the list have documentation on the initial setup for a 430, calibration with other instruments, that they can share?
Posted: Fri Jan 07, 2011 8:45 pm Post subject: GNS 430 Calibration sequence |
Tim,
Ever since I had my 430 converted to a 430w the GI-106 has been out of calibration. On startup the half up and half left don't quite make it to half. When flying a course on the 106 it would not match the CDI built in the 430 by about half a needle tick on the 106. I have entered the setup mode and done the 225 (I believe) adjustment and that is spot on. I don't fly hard IFR so it's not a life or death issue, but it was spot on before the upgrade so I know it can be adjusted somehow. I have the install manuals but I'm missing one that deals with calibration. I have pinouts and rack mounting antenna mounting etc but nothing on calibration. I learned about the set up mode from another user.
Dave
Posted: Fri Jan 07, 2011 11:50 pm Post subject: GNS 430 Calibration sequence |
On 1/7/2011 8:36 PM, Dave wrote: | Quote: | Message Tim,
Dave
| Sorry then Icant help except to email you a copy of my install manual. MAybe call a Garmin Tech or Stein.
Good luck, Tim
