wnorth(at)sdccd.edu Guest
Posted: Mon May 08, 2006 5:42 pm Post subject: idle air fuel |
<<<<<<<<<<Guys, I'm getting almost no RPM rise when I pull the mixture to
idle cutoff at shutdown, and occasionally get some hesitation when I apply
full throttle for a go-around. Which probably means my idle mixture setting
is too lean. I don't have a manual for the MA-4-5 carb on my O-360 so I'm
wondering if anybody remembers which way I turn the screw to make it richer?
M,
The plate the screw is in often has cool little indicator arrows....
hesitation is more likely the accelerator pump or mild MAP leak or dirty
plug, the idle circuit is off during anything above 1/8 throttle.
W
