raymondj(at)frontiernet.n Guest
dave.go
Posted: Fri Dec 31, 2010 10:25 am Post subject: Engine choice |
Engine choice is very personal, and I encourage you to do what is best for
your situation.... But if it were my choice I would use an O-200. Reliable,
proven, available, sometimes cheap. their low-revving power is ideal for a
draggy slow aircraft.
I'm considering the big 3 and leaning towards the 3300. Seems like the
best cost/weight/power/ease of installation combination.
| | - The Matronics Zenith750-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Zenith750-List |
kenryan
Posted: Fri Dec 31, 2010 11:14 am Post subject: Engine choice |
Recommend you look over the Jabiru list archives before making your decision. I fournd it to be an eye opener.
On Fri, Dec 31, 2010 at 12:31 PM, rayj <raymondj(at)frontiernet.net (raymondj(at)frontiernet.net)> wrote:
[quote]--> Zenith750-List message posted by: rayj <raymondj(at)frontiernet.net (raymondj(at)frontiernet.net)>
I weighing my options for engines right now and would like some input from those who are doing the same or have already made their decision.
I'm considering the big 3 and leaning towards the 3300. Seems like the best cost/weight/power/ease of installation combination.
Looking forward to any comments except that I should retire this list and post somewhere else.
Raymond Julian
Kettle River, MN
om" target="_blank">www.aeroelectric.com
ooks.com" target="_blank">www.buildersbooks.com
et="_blank">www.homebuilthelp.com
le, List Admin.
st" target="_blank">http://www.matronics.com/Navigator?Zenith750-List
http://forums.matronics.com
Posted: Fri Dec 31, 2010 11:24 am Post subject: Engine choice |
Dave,
Thanks for the reply.
I looked at the O200 lightweight that Zenith lists and the cost and the
fact that they don't have a FWF kit pushed me towards the 3300. I
looking for as much of a "tab A in slot B" assembly process as I can find.
Rereading my last post I should have said Rotax, Jab, and Cont because
those are the ones that seem to have been developed for the 750.
Raymond Julian
Kettle River, MN
On 12/31/2010 12:23 PM, Dave wrote:
for your situation.... But if it were my choice I would use an O-200.
Reliable, proven, available, sometimes cheap. their low-revving power is
ideal for a draggy slow aircraft.
Posted: Fri Dec 31, 2010 11:45 am Post subject: Engine choice |
There are apparently a number of FWF packages from the factory that for some
reason are not listed on the web site (Rotax for one). Give them a call.
-- Craig
dave.go
Posted: Fri Dec 31, 2010 11:51 am Post subject: Engine choice |
I understand, there is where the "best for your situation" comes in. One can
get uncertified O-200's or ones in need of service or in unknown condition
so inexpensively that I could never overlook them. They are simple in the
extreme and easy to service. If you cannot achieve the "extremely
inexpensive" position with it then other options become more attractive.
Posted: Fri Dec 31, 2010 12:02 pm Post subject: Engine choice |
Craig,
I emailed about it and they offer a cowl and engine mount for the O200,
they have a full FWF for the 3300, and I'll have to do some more digging
about the rotax.
My 1st choice is Corvair, but I'm concerned about how the use of an auto
conversion will affect the resale value, if it comes to that. My future
is unpredictable, so if I am going to move forward facing that
unpredictability I want to have selling as an option.
Raymond Julian
Kettle River, MN
-- Craig
Posted: Fri Dec 31, 2010 12:39 pm Post subject: Engine choice |
I'm afraid you have to put resale value aside, regardless of your engine
choice. Look through Branstormers and there are all kinds of experimentals
for sale at below what the builders have in them.
Also (having owned but not flown Corvair, Jabiru and Rotax engines on Zenith
aircraft) you will have a hard time meeting your desire for a "tab A in slot
B" FWF. You can get close but if you read through the engine-specific lists
you see a lot of tinkering is required. Part of this is the "Internet
effect" - only those with problems post messages. But none of these FWF kits
are a slam-dunk. On the Jabiru you get to fiddle with the cooling and carb.
In a slow flying plane like the 750 cooling is an issue. If you ask William
Wynne I don't think he ever achieved adequate cooling on the Corvair-powerd
701.
I'm putting a Rotax on my 701 but it might be underpowered for the 750. Of
course I live at 7000 ft and am surrounded by 10,000 ft peaks so I am more
sensitive to power needs.
Also pay attention to weight and balance. Getting accurate data is hard but
with the wrong engine you can end up with a plane that is not very useful.
The best thing to do is get real W&B numbers from flying 750.
If I was in your shoes and expected to fly below 5000 ft I would look hard
at the Rotax. There is a lot of plumbing to hook up. But it is light, there
are thousands flying and it will run cool at low speeds. I know of two that
have flown around the world (one with legs of 23+ hours).
If you choose to build a non-LSA 750 (via the new gross limit) you will have
more choices. But I suspect that a non-LSA 750 would be harder to sell.
If your future is uncertain then rent. You can get a lot of hours in a
Cessna 150 for the price of a 750.
-- Craig
Posted: Fri Dec 31, 2010 12:42 pm Post subject: Engine choice |
This is what Jon Croke wrote about the factory FWF packages for the 750 in
September:
"I just called Zenith and talked to Shirley... I didn't realize it was not
listed on the website - you are correct - I could not find it either!
It IS available directly from Zenith (manufactured by Zenair, not Can-zac)
for the current price of $6125.
Also, the Jabiru FWF is now to be purchased directly from Zenith, as well as
the Continental (but that one is only prop, mount, baffle)
Of course, the Rotax engine is available from Zenith... but just like
seafood, the price is "market price" - ask your waiter."
-- Craig
Posted: Fri Dec 31, 2010 8:33 pm Post subject: Engine choice |
Craig,
You bring up some interesting points. Unfortunately, renting a 150 isn't
and option. I'll keep doing my research.
Does anybody know right off hand if Zenith usually has any show specials
at Air Venture? Same question for Rotax, Jab, and Cont.
Raymond Julian
Kettle River, MN
701.
-- Craig
Posted: Fri Dec 31, 2010 8:34 pm Post subject: Engine choice |
Ken,
Thanks for the suggestion. I'll take a look.
Raymond Julian
Kettle River, MN
On 12/31/2010 01:12 PM, Ken Ryan wrote:
| Quote: | Recommend you look over the Jabiru list archives before making your
decision.
Raymond Julian
Kettle River, MN
le, List Admin.
buells2t
Posted: Fri Dec 31, 2010 10:40 pm Post subject: Engine choice |
I'm in the same spot trying to decide which engine. I'm not far along in my build so I have some time. I'm leaning toward the 3300 as well. Seems like a good bang for the buck. I have read most of the issues owners have had and have heard that the new cowl fixes most of the cooling issues. I have a friend flying a 3300 in a Bush Caddy and he loves it.
Hard to beat the reliability and reputation of an 0200, but 3300 weighs less with more power too.
The Rotax seems like a good option, but pricy to buy, pricy to maintain. I'm taking 2 Rotax classes in late February maybe I will feel differently after.
Anyone on the list have a flying 750?
What are you running?
On Dec 31, 2010, at 8:30 PM, rayj <raymondj(at)frontiernet.net> wrote:
Craig,
You bring up some interesting points. Unfortunately, renting a 150 isn't and option. I'll keep doing my research.
Does anybody know right off hand if Zenith usually has any show specials at Air Venture? Same question for Rotax, Jab, and Cont.
Raymond Julian
Kettle River, MN
> 701.
> -- Craig
Posted: Fri Dec 31, 2010 11:13 pm Post subject: Engine choice |
Mike,
From what I've read it sounds like Jab knows what the solution is. The
problem is whether or not it can be implemented. My gut feeling is that
Zenith has the problem solved or they wouldn't be advertising it as a
designed to fit option.
People are talking about the O200. The one Zenith lists on their web
site it the NEW O200 Lightweight. New from Cont. for the lsa market.
Cont has a good rep but is seems like there's usually a few bugs in any
new product. Zenith doesn't have a FWF package yet but they say they
are developing one.
I'm not in a big hurry to make a decision myself. I'm hoping to decide
by Oshkosh and maybe be able to take advantage of a show special.
I'd be interested to hear what you think after your classes. I've heard
rumors that you have to take a class to work on your engine, even if
it's in an experimental.
Raymond Julian
Kettle River, MN
On Dec 31, 2010, at 8:30 PM, rayj<raymondj(at)frontiernet.net> wrote:
> Craig,
> Raymond Julian
> Kettle River, MN
>> 701.
>> -- Craig
Posted: Fri Dec 31, 2010 11:33 pm Post subject: Engine choice |
The price of the Rotax and the Jabiru tend to be driven by the exchange rate
of the Euro and the Aus dollar, respectively.
The price of a Jabiru may be going up as Jabiru itself and the company that
actually makes the engine (www.camit.net) are located in Bundaberg,
Australia and probably under water from the massive flooding.
-- Craig
nsmit(at)nc.rr.com Guest
Posted: Sun Jan 02, 2011 5:10 pm Post subject: engine choice |
Raymond,
I'm building a 750 and have started rebuilding a Corvair engine for mine. Go
to FlyCorvair.com, which is William Wynne's site and the person who has been
working with these engines for aviation use for possibly two decades. My
reasons are that the engine has a mature history and the kinks have been
worked out for aviation use. It is very close to the same weight as an
O-200, air cooled, and direct drive. I'm not going this route, but you can
buy a complete firewall forward package from William Wynne - engine mount to
propeller - although he usually encourages people to build their own in
keeping with experimental aviation's educative principle. It is cheaper than
a certified engine to purchase and the long-term running costs will be
significantly better. Because complete firewall forward development has
been done, it makes completion that much more straightforward for builders
like myself, because I don't have to reinvent the wheel. (I'm not getting
anything for this mention, by the way.)
Norman
Garner, NC
Posted: Sun Jan 02, 2011 5:56 pm Post subject: engine choice |
I have a couple of Corvairs and a manual sitting here. I was planning on
using one in a 750 when I started. I'm not sure how having an auto
conversion will affect my resale, If I have to sell it.
Raymond Julian
Kettle River, MN
On 01/02/2011 07:08 PM, Norman Smit wrote:
Raymond,
Norman
Garner, NC
jd(at)lawsonimaging.ca Guest
Posted: Mon Jan 03, 2011 7:26 am Post subject: engine choice |
Sorry about letting that "Probable Spam" in the subject line of my last post live on!
Some email servers add that to the subject to flag possible spam. I should have noticed it
and removed it (which I have now done).
On 01/03/2011 10:02 AM, j. davis wrote:
Regards, J.
- flying Sonex #325 C-FJNJ, Jab 3300a, Prince P-Tip, Aerocarb
- restoring the 'Johnston Special'
- former C-IGGY CH701 owner/builder, starting CH750 soon
- http://cleco.ca
| J. Davis, M.Sc. | (computer science) |
| *NIX consulting, SysAdmin | email: jd at lawsonimaging.ca |
On the other hand... You have different fingers.
--- Steven Wright
