Questions about the 9005 Low Voltage Module
PostPosted: Sat Jan 01, 2011 9:56 pm    Post subject: Questions about the 9005 Low Voltage Module Reply with quote
[quote]At 09:53 PM 1/1/2011, you wrote: Today it was cold and rainy so I had great fun soldering the various bits onto the 9005 PCB for the low voltage module in the comfort of the heated workshop. When I got it all finished I made up a test lead out of a mating D-sub connector and two alligator clips. Pins 4,5, and 9 all are connected to the red alligator clip, while pins 3,6,7,8 and the test LED cathode are all connected to the black alligator clip. Pin 2 is connected to the test LED anode. My plan was to hook those alligator clips to the truck battery, such that the LED would flash with the engine off and extinguish with the engine on, since the voltage situation would mirror the airplane that doesn't happen to have a functioning alternator yet. Good plan . . . I don't think it is working correctly yet, and I was wondering if Bob or anyone else who has built one of these might have some suggestions. When I first apply the battery voltage with the truck engine off, the LED in the test harness and the LED on the PCB flash once, like Captain Ramius's "one ping only." <snip> Is it possible that a difference in current draw between this LED and the one originally supplied with the 9005 kits would cause this behavior? No. I should also add that I did not need the aux battery features so I omitted the three components Q114, R119, and Z118 as per the note in the documentation. No problem. With the device under test hooked to your battery in a non-running vehicle. Hook the minus lead of your voltmeter hooked to battery (-). Measure and record the voltages at the following test points: U107 Pin 1 U107 Pin 2 U107 Pin 3 U107 Pin 4 U107 Pin 7 U107 Pin 8 Also U110 Pin 1 U110 Pin 2 U110 Pin 3 U110 Pin 4 U110 Pin 5 U110 Pin 6 U110 Pin 8
Bob . . . //// (o o) ===========o00o=(_)=o00o========= < Go ahead, make my day . . . > < show me where I'm wrong. > ================================= [/b] [quote][b]
PostPosted: Mon Jan 03, 2011 6:36 am    Post subject: Questions about the 9005 Low Voltage Module Reply with quote
At 07:57 AM 1/2/2011, you wrote:
Thanks Bob! Here are the readings that I get. Battery Voltage this morning is 12.3.
U107 Pin 1: 0
U107 Pin 2: 2.38
U107 Pin 3: .68
U107 Pin 4: 0
U107 Pin 7: 11.24
U107 Pin 8: 11.49
U110 Pin 1: 0
U110 Pin 2: 10.77
U110 Pin 3: 0
U110 Pin 4: 11.49
U110 Pin 5: 7.66
U110 Pin 6: 10.78
U110 Pin 8: 11.49
Okay, all of the voltages you've measured are expected
values with one exception. Pin 3 of U107 voltage is
established by the voltage reference Z103 and SHOULD
be within 30 millivolts or so of 2.50 volts.
http://www.national.com/ds/LM/LM185-2.5.pdf
The fact that you're reading only .68 volts suggests
that Z013 is installed wrong. See data sheet for pinout
orientation . . .
[img]cid:.0[/img]
Note that the image is a BOTTOM view
of the device. The pictures for assembly of
the 9005 show the flat side of the device
pointed toward the power transistor location.
If you determine that the device IS
installed wrong you should consider the
best way to replace it. If you have the tools
and experience to removed parts from a plated
thru hole board, you have a high probability
of re-using the original part.
I very seldom pull a part off a board with
any notion of reusing it. The value of the
part is usually pretty small compared to the
value of the whole. I usually clip the leads
on the part to be removed so that they can
be taken out of the holes one at a time thus
minimizing hazard to the board.
 Filesize:  58.25 KB
 Viewed:  2897 Time(s)
PostPosted: Tue Jan 04, 2011 7:14 am    Post subject: Questions about the 9005 Low Voltage Module Reply with quote
At 09:28 PM 1/3/2011, you wrote:
That's great information, thank you for your help! I found the Digikey invoice and I think I might have ordered the wrong part.
The national part is the Digikey LM285Z-2.5-ND
The one that I ordered is made by ON Semiconductor, Digikey LM285Z-2.5GOS-ND.
http://www.onsemi.com/pub_link/Collateral/LM285-D.PDF
I don't think so. The LM series devices are National
Semiconductor originations. All competing manufacturers
have to put out a drop in duplicate of the part.
If the voltage at U107-3 had been zero or identical
to an adjacent pin, then I would suspect a solder
splash or an ECB defect often called a 'cat hair'.
The fact that your measurement is unique and way out
of whack for what the LM285 should present suggests
that neither event is in force. You might check
markings or color code for the R104 . . . make sure
it.s a 4.7K and not something higher. Also re-flow
the solder joins on R104. It's extremely rare that a
new part is bad out of the box so if the LM285 is
not installed wrong, we need to explore other possible
causes for U107-3 voltage not to be 2.50 volts.
Bob . . . [quote][b]
