eric hendriks
Posted: Wed Dec 29, 2010 12:17 am Post subject: AVGAS /mogas |
Hello
I can buy a Rotax 912 A2 who has 423 hr in 12 years.
The engine has always been run on avgas.
Can i switch without problems to Mogas because on my airfield there is no avgas available ?
Thank You
Eric hendriks
Roger Lee
Posted: Wed Dec 29, 2010 5:19 pm Post subject: Re: AVGAS /mogas |
Hi Eric,
Absolutely you can change and it will be for the better. If you are going to buy a 12 yr. old engine just peruse through the SB's for Rotax and make sure your up to date.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
Dick Maddux
Posted: Thu Dec 30, 2010 4:52 am Post subject: AVGAS /mogas |
Eric,
In addition to the good info Roger gave you ,you might want to clean out all the lead residue in the oil tank. It will be spread thru out the engine/gearbox internals but at least you can clean the oil tank/screen.
Dick Maddux
912UL
Milton,Fl
eric hendriks
Posted: Thu Dec 30, 2010 10:49 am Post subject: Re: AVGAS /mogas |
Hello
Thank You guys for your quick answers.
the engine is always been used in a certified aircraft so I think all the mod must have been done.
eric
eric hendriks
Posted: Mon Jan 03, 2011 8:41 am Post subject: Re: AVGAS /mogas |
| Roger Lee wrote: | Hi Eric,
Absolutely you can change and it will be for the better. If you are going to buy a 12 yr. old engine just peruse through the SB's for Rotax and make sure your up to date. |
Hello Roger
Thank You for Your reply.
Do You know what I should specially look at at the engine,weak points etc ?
Thank You
Eric
