Off Topic - Looking for geared AC motor
rickofudall
PostPosted: Sat Dec 25, 2010 12:13 pm    Post subject: Off Topic - Looking for geared AC motor Reply with quote
Jerry, Try Surplus Center, I get a lot of things from them for shop projects. Be sure and take note of stock on hand if you don't plan to order right away, they could be out by the time you get back to them.
https://www.surpluscenter.com/home.asp
Rick Girard
On Fri, Dec 24, 2010 at 11:10 PM, jerb <ulflyer(at)verizon.net (ulflyer(at)verizon.net)> wrote:
--> Kolb-List message posted by: jerb <ulflyer(at)verizon.net (ulflyer(at)verizon.net)>
Hey folks there are a lot of resources on these list.  Anyone have or know of a source for an surplus (cheap is good) geared down 120V AC motor of 1/4-1/3 HP.  Inline or right angle gear box will work - need a shaft output of around 20-43 (desired) or 80-100 RPM.  This in not for an aviation orientated project.  I can't justify the cost of a new unit for its intended use.
If so please email direct.  Thanks,
jerryb
om" target="_blank">www.aeroelectric.com
ooks.com" target="_blank">www.buildersbooks.com
et="_blank">www.homebuilthelp.com
le, List Admin.
http://forums.matronics.com
Zulu Delta
Kolb Mk IIIC
582 Gray head
4.00 C gearbox
3 blade WD
Thanks, Homer GBYM
It is not bigotry to be certain we are right; but it is bigotry to be unable to imagine how we might possibly have gone wrong.
 - G.K. Chesterton
