Roger Lee
Posted: Thu Dec 16, 2010 7:59 am Post subject: Rotax Oil Filters changing, new part number assigned |
Revision #2
New oil filter part number correction
by XatorMan under ROTAX PRESS RELEASESRotax has just released the informaiton on the oil filter minor changes. In the release they inadvertently gave out the wrong part numbers. Owners and operators and service providers will be recieving the new filters under 2 different part numbers, depending on the ordering scope. (by bulk or individual) Please note the following change from the release of December 3rd.
Part number 825710 and 825712, changed to 825010 and 825012 respectivly. This will be the new numbers the filter will be supplied with.
It is worth repeating that all users should check the installaitons and confirm that the small change in the length of the filter, as shown in the drawing supplied from December 3rd, be verified. While it is not anticipated that this will have any ill effects the clearance, especially to the exhaust system on number 2 cylinder, has to be considered.
Contact your independent Rotax distributor or independent Rotax Service Centre for any additional information.
Revision #1
by XatorMan under ROTAX PRESS RELEASESRotax; BRP-Powertrain, is making a minor change on the oil filter for ROTAX 912 and 914 Series engines.
Production of the current oil filters part no. 825704 and 825706 has been discontinued, once stock is depleted they will be not longer available.
The replacement filters will have a new part no. 825710 and 825712, internally they are the same and they have been approved from engineering, however one small change has to be noted. The overall length has increased about 3.5 mm ( .138″ ) due to the production process. For detailed dimensions see attached sketch.
OEM and end use customers need to check and make sure they have clearance and make any necessary changes to accommodate this new filter. The part will be coming in the first quarter of 2011.
New production filter for 9 Series Rotax engines, early 2011
new oil filter, rotax
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
