Albert Gardner
Posted: Mon Dec 06, 2010 8:27 pm Post subject: Step |
My left-side rear passenger was getting out of the plane after me and when he was on the step it broke at the upper weld. Only slight damage to the skin when the step pressed against the side before it broke completely off. Going to half to get access to the bolt to remove the remaining piece and repair it. I had already riveted the baggage floor on when the discussion began on this list about putting an access cover so you could get to the bolt but wish I had done that before. If I was starting over I think I would not only but an access cover there but put a nutplate there instead of a lock nut or maybe weld a nut on the bottom of the receptacle in the plane.
Albert Gardner
Yuma, Arizona
N991RV
RV-10 N991RV |
AirMike
Posted: Mon Dec 06, 2010 10:37 pm Post subject: Step |
I knew that this was a problem area (had a problem with my Piper) so I did the access plate hole which provides for access to the bolt - plus an inspection cover for annual
1.48 MB |
12762 Time(s) |
_________________ See you OSH '18
Q/B - sold. |
dlm46007(at)cox.net Guest
Posted: Tue Dec 07, 2010 12:35 am Post subject: Step |
Do you have a picture of panel and location?
thane
Posted: Tue Dec 07, 2010 5:37 am Post subject: Step |
Yep these steps from Vans are problematic, A Friend had his step on a RV-7 fail also. The welds are not strong enough!!
_________________ Working on finish kit: I hate fiberglass!! |
Andy Turner
Posted: Tue Dec 07, 2010 5:47 am Post subject: Re: Step |
Mike, did you trim the edge of the doubler adjacent to the outer floor rib, or did you run the doubler between rib and floor?
-Andy
_________________ Andy Turner |
Posted: Tue Dec 07, 2010 6:59 am Post subject: Step |
Wish I had done that. I bought 2 access plates from Vans but got lazy
and decided to "follow the plans". Perhaps a llusy excuse in this case.
Has anyone installed the plates after finishing the steps and floor?
Comment on difficulty - the timing is still good.
Bill "waiting for weekend warm-up for some more paint" Watson
On 12/7/2010 1:37 AM, AirMike wrote:
See you OSH '11
Q/B - flying 1 yr+
chuck(at)chuckdirect.com Guest
Posted: Tue Dec 07, 2010 3:17 pm Post subject: Step |
Yep, I agree. My friend across the hanger row had both of his steps crack at the upper weld; I had the passenger weld crack at the same spot on my ‘nine’. I removed mine (no small feat --- address this possibility during construction for access!!!) took mine to a real professional welder. Told him I wanted a gusset added for strength on the repair weld. He studied it for awhile and said he wouldn’t advise it. Something about transfer of force and it would just crack again somewhere else. He rewelded it and said I probably wouldn’t have any further cracks, and I haven’t.
Called Van’s and guess what? They hadn’t heard of the problem…
Chuck
Subject: Re: Step
Subject: Step
Albert Gardner
Yuma, Arizona
N991RV=====[b]
davidsoutpost(at)comcast. Guest
Posted: Tue Dec 07, 2010 6:37 pm Post subject: Step |
Posted: Tue Dec 07, 2010 7:41 pm Post subject: Step |
AirMike
Posted: Wed Dec 08, 2010 5:59 am Post subject: Step bolt access |
Attached is picture of the doubler plate for bolt access hole. the whole job took about 4 hrs in all. Remember that the side panel fits here so check and fit carefully. Note that the doubler is cut away. As I recall these are the same pieces as the pitot access plate on the wing.
1.37 MB |
12686 Time(s) |
Q/B - sold. |
Andy Turner
Posted: Wed Dec 08, 2010 6:40 am Post subject: Re: Step |
I installed my access covers last night, and they look just like the ones in the photos above. Only difference is that I put a bit of a joggle in the doubler where it runs under the rib, but perhaps that isn't necessary.
glastar(at)gmx.net Guest
Posted: Wed Dec 08, 2010 7:05 am Post subject: Step |
From what is looks they are the stall warning access parts VA-195C/D
see Section 19.
Werner
On 08.12.2010 14:59, AirMike wrote:
AirMike
Posted: Wed Dec 08, 2010 6:43 pm Post subject: Step bolt access |
I think that you are correct and the plates are actually from the stall warn access plate not the pitot access plate
Q/B - sold. |
rv10flyer
Posted: Thu Dec 09, 2010 7:43 am Post subject: Bad TIG welds and thin tubing. |
Just installed mine a few weeks ago. I will be buying some thicker round and streamline tubing when it breaks down the road. The welds did not have good penetration. Thicker tubing would also help prevent hole elongation. Van's probably saved us $10 and 2 lbs by using thinner materials.
_________________ Wayne G. |
