donjohnston
Posted: Sun Dec 05, 2010 3:00 pm Post subject: OFF-ON-ON Toggle switch? |
I need a toggle switch for a fuel pump that will have an OFF, LOW and HIGH setting. I was thinking of a toggle switch that would be OFF in the down position, LOW in the middle and HIGH in the upper position.
But every toggle switch I've found is ON-OFF-ON. (OFF is the middle position)
Has anyone seen a toggle switch with an OFF-ON-ON configuration?
Don
dan(at)azshowersolutions. Guest
Posted: Sun Dec 05, 2010 3:15 pm Post subject: OFF-ON-ON Toggle switch? |
On-On-On...no wjires used on the bottom.
Ed Anderson
Posted: Sun Dec 05, 2010 3:21 pm Post subject: OFF-ON-ON Toggle switch? |
Don, if you type in Toggle Switch "off-on-on" in a google search window, you will find a large number of sources for the type switch you want.
Ed
Sent: Sunday, December 05, 2010 6:00 PM
To: <aeroelectric-list(at)matronics.com>
Subject: AeroElectric-List: OFF-ON-ON Toggle switch?
[quote] --> AeroElectric-List message posted by: "donjohnston" <don(at)numa.aero>
Don
http://forums.matronics.com/viewtopic.php?p=322386#322386
Support Your Lists This Month --
Get Some the Annual Contribution link Terrific Free www.aeroelectric.com
HomebuiltHELP Contribution Web bsp; ===========
Features Browse, Chat, http://www.matronics.com/Navigator?AeroElectric-List
bsp; via the ===========
_________________ Ed Anderson
Rv-6A N494BW Rotary Powered
Matthews, NC
eanderson@carolina.rr.com |
jloram
Joined: 07 Nov 2009 Posts: 54 Location: United States
Posted: Sun Dec 05, 2010 5:17 pm Post subject: OFF-ON-ON Toggle switch? |
At 05:12 PM 12/5/2010, you wrote:
| Quote: | --> AeroElectric-List message posted by: Dan Billingsley <dan(at)azshowersolutions.com>
On-On-On...no wjires used on the bottom. |
Very good Dan.
Don, the functionality you need can be configured
from a two-pole, three-position, progressive transfer
switch. An exemplar part is the B&C S700-2-10 switch
[img]cid:.0[/img]
Exemplar wiring for an off-on-on functionality
is illustrated in figures 11-1, and 11-16 through
11-18 of The 'Connection.
[img]cid:.1[/img]
52.63 KB |
17316 Time(s) |
31.12 KB |
17317 Time(s) |
JOHN TIPTON
Joined: 17 Sep 2006 Posts: 239 Location: Torquay - England
Posted: Mon Dec 06, 2010 1:08 am Post subject: OFF-ON-ON Toggle switch? |
Yes: you need: ON-ON-ON as many of us use for - Fuel pumps ie: Off - Fuel
pump - Fuel pump+Primer. or Battery/Alternator ie: Off - Battery -
Batttery+Alternator
John
dballin
Posted: Mon Dec 06, 2010 10:26 am Post subject: Re: OFF-ON-ON Toggle switch? |
If you want a Carling switch, I used Carling L52E166A77. It is a 24V light. If you need 12V just go to there website to configure it. The important part is the L52E. I am using it as a OFF-Low Boost-High Boost switch for my fuel pump.
Dan Ballin
Lancair Legacy
petehunt(at)earthlink.net Guest
Posted: Mon Dec 06, 2010 11:08 am Post subject: OFF-ON-ON Toggle switch? |
Bob, your embedded images are coming through on my daily summary as “Emacs!” and not as an image or a link.
70 Bytes |
17293 Time(s) |
Posted: Mon Dec 06, 2010 3:06 pm Post subject: OFF-ON-ON Toggle switch? |
At 01:00 PM 12/6/2010, you wrote:
| Quote: | Bob, your embedded images are coming through on my daily summary as
"Emacs!" and not as an image or a link.
Yeah, that's a quirk of how the system handles Eudora
postings in the digest mailings. See
http://www.matronics.com/forums/viewtopic.php?t=77725
I think you'll see them properly if you access the
forums threads from your browser . . . or shift from
the digest dump to individual messages.
