Rainair
Posted: Sat Dec 04, 2010 11:38 am Post subject: Best Prop for HR 2 |
Hello,
what the best prop for HR2 ?
[F3YR-1ARF7693DF*1] Hartzell 3-Blade Propeller (D Twist)
[M2YR-1BF/8475D4] Hartzell 2-blade Propeller
[MTV-9-B/198-52] MT 3-bladed propeller
[MTV-9-B-C/C-198-52] MT 3-Bladed Propeller
Maybe important is the noise. Which db are the propellers ?
At germany i need 75 decibel
Which Prob to quiet down ?
Rainer
| | - The Matronics Rocket-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Rocket-List |
82.88 KB |
17353 Time(s) |
lessdragprod(at)aol.com Guest
Posted: Sat Dec 04, 2010 8:35 pm Post subject: Best Prop for HR 2 |
Hello Rainer,
The quietest propeller is probably the 4 blade propeller,
MTV-14-B/190-59b
with a 76" diameter (190cm diameter).
Jim Ayers
hr2pilot(at)aol.com Guest
Posted: Sat Dec 04, 2010 9:31 pm Post subject: Best Prop for HR 2 |
But it sucks for performans
On Dec 4, 2010, at 8:31 PM, Jim Ayers <lessdragprod(at)aol.com (lessdragprod(at)aol.com)> wrote:
[quote] Hello Rainer,
MTV-14-B/190-59b
Jim Ayers
sprocket(at)vx-aviation.c Guest
Posted: Sat Dec 04, 2010 10:43 pm Post subject: Best Prop for HR 2 |
I am looking for a 'firewall forward' equipment list for finishing my HR-II.
It would be handy to purchase all of the stuff at once rather than
discovering all the bits and pieces I need as I go and waiting for parts
orders.
Anyone have a definitive list?
John, what do you sell that I need?
Vern
Posted: Sun Dec 05, 2010 3:48 pm Post subject: Best Prop for HR 2 |
Hi John,
I didn't know that you've flown one of these Rocket 4 blade MT Propellers.
Rainer, in Germany, is likely going to be limited to 2500 RPM maximum.
An F-1 customer with the 3 blade Rocket propeller says the 4 blade MT Rocket propeller is 2 knots sower at 4,000'.
But faster at 9,500' and 10,500'.
John. I know this doesn't work for your typical flight. The highest altitude you reach being when you climb to pattern altitude.
Jim Ayers
Rainair
n395v
Posted: Fri May 13, 2011 5:01 am Post subject: Re: Best Prop for HR 2 |
I can't speak for a Harmon Rocket but a lot of F1s had a terrible vibration (prop-beat or whatever) that was intolerable with a 2 blade hartzell. Mine was one of them. Changed to a 3 blade MT (one of Jim's)
Problem was gone and plane was much quieter. It did however have measurable loss of performance in climb and cruise as well as top speed.
I think Tom Gummo has a 4 blade MT on his Harmon and I recall somewhere he called it the slowest Rocket in the West.
In my opinion the less blades the better for performance and cost. As to the manufacturer I have heard few complaints about Hartzell or MT. Never heard of the brand you are considering.
_________________ Milt |
stuart(at)stuarthutchison Guest
Posted: Fri May 13, 2011 5:27 am Post subject: Best Prop for HR 2 |
Should have better climb on 3 blades, but lower top speed (extra blade = more drag). 2 for go, 3 for show!
Kind regards, Stu
www.mykitlog.com/rockfly
On 13/05/2011, at 11:01 PM, "n395v" <Bearcat(at)bearcataviation.com> wrote:
Milt
http://forums.matronics.com/viewtopic.php?p=339741#339741
smokyray(at)rocketmail.co Guest
Posted: Fri May 13, 2011 6:45 am Post subject: Best Prop for HR 2 |
Best HR2 prop? The one that works:) seriously, the prototype HR2 has a Hartzell 2 blade sold by John. After testing 2 props on mine and chatting with other folks, here is my 2cents.
I had a "D" twist Hartzell 2 blade on mine optimized for 2500 RPM. Their is also a "J" twist optimized for 2350 RPM. Hartzell also makes a 2blade Blended airfoil prop for the Rocket currently flown by Tom Martin. The MT would be smoother but a bit slower at top end, the 3blade Hartzell is too heavy.
I would either go with the J twist or BA 2 blade from Hartzell purchased through Harmon (J) or Team Rocket (BA)
Smokey
On May 13, 2011, at 9:01, "n395v" <Bearcat(at)bearcataviation.com> wrote:
Milt
t.gummo(at)verizon.net Guest
Posted: Fri May 13, 2011 1:43 pm Post subject: Best Prop for HR 2 |
Guys,
I also have a thirty year old engine that I rebuilt. IO-540J4A5 is only 250
HP as well. So who knows what the real HP is? Jim tells me that I
just don't have the HP to use my prop properly.
Part of my slowest is that I built the plane myself and while it turned out
great, I clearly didn't know anything about getting speed out of an
aircraft.
I didn't have an vibration when I had a two blade Hartzell. In my case, the
three blade MT was as fast as the two blade Hartzell.
My four blade MT is slower as I used to cruise:
at 10,500 or 11,500 MSL
Full throttle.
RPM 2100
Leaned to 10.0 to 10.5 GPH
KIAS = 140 True = 180 Knots
with MT prop:
KIAS = 135 True = 170 Knots
For local flying, I really don't see much of a difference.
Numbers are from the top of my head but they are close.
Tom "GummiBear" Gummo
Major USAF Retired, F-4G Wild Weasel Instructor Pilot
Harmon Rocket II, N561FS, 390 hours of the biggest grin
Posted: Tue May 17, 2011 8:26 pm Post subject: Best Prop for HR 2 |
Message for John Harmon: Is your on-line ordering system up to date? It
appears to add tax to my shopping cart, even though I'm located in Canada.
I need to order some stuff, should I use your website or just contact you
via email?
Vern Little
