jef.vervoortw(at)telenet. Guest
Posted: Sat Dec 04, 2010 8:40 am Post subject: disengage button on stick |
I have a wooden stick grip ( Custom Aircraft Grips through Vans) with just one push button for radio.
Would it be possible to mount an extra disengage button ( for Dynon autopilot) on such a stick grip.
Has anybody done that and satisfied?
Jef Vervoort, Belgium.
bicyclop(at)pacbell.net Guest
Posted: Sat Dec 04, 2010 9:03 am Post subject: disengage button on stick |
An alternative is to place a push button on the panel near the throttle. It will fall to hand very naturally there. I've had my autopilot disconnect there for years and never felt that it took me too long to get to when I needed it. Anytime I'm looking for the disconnect, I'm usually already reaching for the throttle. Also a good location for the flap switch.
Pax,
Ed Holyoke
On 12/4/2010 8:35 AM, Jef Vervoort wrote: [quote]
JohnInReno
Posted: Sat Dec 04, 2010 9:35 am Post subject: disengage button on stick |
On 12/4/2010 8:35 AM, Jef Vervoort wrote: | Quote: |
| I drilled a hole in the front to mount a second button. The top one is used for autopilot disconnect and the front button under the index finger is PTT.
John Morgensen
RV4 - purchased flying
RV9A - baffles
_________________ John Morgensen
RV-9A - Born on July 3, 2013
RV4 - for sale |
JOHN TIPTON
Joined: 17 Sep 2006 Posts: 239 Location: Torquay - England
Posted: Sun Dec 05, 2010 2:41 am Post subject: disengage button on stick |
I would be very careful of what buttons I put on the TOP of your grip, when reading the chart (for example), which can easily depress the disconnect at a time when you need the A/P most
tiethoff
Posted: Sun Dec 05, 2010 3:57 am Post subject: disengage button on stick |
I prefer to give the button a prominent and easy to reach place on the dashboard.
2010/12/5 JOHN TIPTON <jmtipton(at)btopenworld.com (jmtipton(at)btopenworld.com)>
[quote] I would be very careful of what buttons I put on the TOP of your grip, when reading the chart (for example), which can easily depress the disconnect at a time when you need the A/P most
Paul Valovich
Posted: Mon Dec 06, 2010 9:15 am Post subject: disengage button on stick |
I purchased 2 Infinity sticks for my RV-8A, planning to use all the switches for various HOTAS functions. I ended up using only the Coolie Hat trim switch, the trigger for PTT and the paddle switch for flaps. In the end, I felt the risk of inadvertent fumble fingers activating/deactivating other functions overrode any perceived convenience. However, other folks have utilized all the switches very successfully. As with most things in the homebuilt world, whatever you think works best for you.
