Michel
Posted: Thu May 04, 2006 9:24 am Post subject: Tundra tyres |
Hello Rex,
On May 3, 2006, at 7:54 PM, Rex Shaw wrote:
| Quote: | I think my tyres are 16.50 x 7 x8 but that's from memory.
I have just found somewhere, here in Norway, where I can get smooth
tyres that are 18 x 5.4 - 8. That's a bit smaller and narrower than 20
x 7 - 8. Do you think it's close enough?
| Quote: | Remember it's not really a bounce but we fly again if the tail wheel
does not touch
down at the same times as the mains
Exactly my feeling, Rex. The bounce has nothing to do with the
hardness of the tyres but rather from the increases AoA due to the main
hitting the ground first and inducing a nose-up as the tail goes down.
But, talking about pressure, my ChengShin tyres have "7 PSI OPERATING
PRESSURE" written on them. I think that's very little. I usually put 11
psi in them. I think they'll tolerate up to 20 psi, though.
Michel
roncarolnikko(at)hotmail. Guest
Posted: Thu May 04, 2006 11:11 am Post subject: Tundra tyres |
I wonder how the pressure change going to altitude affects them. I once
near exploded a candy bar wrapper at 12500 msl. Not a problem with 6 ply,
but a thought on lawn tractor tires such as ours. Ron NB Ore
| Quote: | From: Michel Verheughe <michel(at)online.no>
Subject: Re: Tundra tyres
Date: Thu, 4 May 2006 19:17:39 +0200
Michel
On the road to retirement? Check out MSN Life Events for advice on how to
get there! http://lifeevents.msn.com/category.aspx?cid=Retirement
rjdaugh(at)rapidnet.com Guest
Posted: Thu May 04, 2006 11:49 am Post subject: Tundra tyres |
Going to higher altitude is like putting a couple more PSI in the tires. If
you run the tires at 14 psi and the tires can handle 16 or 17 psi, don't
worry about them.
Randy
bmwebb(at)cox.net Guest
Posted: Thu May 04, 2006 2:01 pm Post subject: Tundra tyres |
I once had a Coke explode in a Herc at about 25,000ft. Scared crap outa us,
until we realized what it was. Sounded like a AAA shell going off.
BTW, all the tires in the military that I know of are filled with nitrogen.
Bradley
Richard Rabbers
Joined: 09 Jan 2006 Posts: 114 Location: Benton Harbor, MI - USA
Posted: Thu May 04, 2006 2:38 pm Post subject: Re: Tundra tyres |
| Quote: | | Bradley > all the tires in the military that I know of are filled with nitrogen. |
Nitrogen molecules are large than oxygen - so there would be less pressure loss via transmission of tube or tire.
_________________ Richard in SW Michigan
Model 1 / 618 - full-lotus floats (restoration) |
janderson412(at)hotmail.c Guest
Posted: Thu May 04, 2006 7:54 pm Post subject: Tundra tyres |
Ane fly high (10G) in a helicopter with pop out floats and the nitrogen
bottle vents on a hot day, being high in a heli is bad for nerves anyway,
then the hapens!!
Subject: RE: Tundra tyres
Date: Thu, 4 May 2006 17:58:09 -0400
Bradley
Posted: Fri May 05, 2006 2:57 am Post subject: Tundra tyres |
I bet that's fun to watch!
Posted: Sat May 06, 2006 12:33 am Post subject: Tundra tyres |
Yes, and you get the big icy cloud for around you feet too. Ses the heart
going...
Date: Fri, 5 May 2006 06:53:00 -0400
