tach drive cover
pilotdds(at)aol.com
PostPosted: Sun Nov 28, 2010 5:24 pm    Post subject: tach drive cover Reply with quote
Anybody know where to find a cover for the tach drive on the lycoming engines.Also how about 5/8 or 3/4
blast tubes that can be riveted to the engine baffling-thanks
Ron B.
PostPosted: Sun Nov 28, 2010 6:07 pm    Post subject: Re: tach drive cover Reply with quote
Aircraft Spruce, P/N 10-06754. As for blast tube flanges, I machined my own out of alum. stock. If you are not capable, any shop with a lathe should should do.
Ron
n223rv(at)wolflakeairport
PostPosted: Sun Nov 28, 2010 6:09 pm    Post subject: tach drive cover Reply with quote
http://www.averytools.com/prodinfo.asp?number=6346
On Nov 28, 2010, at 8:19 PM, pilotdds <pilotdds(at)aol.com (pilotdds(at)aol.com)> wrote:
[quote] Anybody know where to find a cover for the tach drive on the lycoming engines.Also how about 5/8 or 3/4
Strasnuts
PostPosted: Sun Nov 28, 2010 6:10 pm    Post subject: tach drive cover Reply with quote
Andair sells one on aircraft spruce. Expensive though.
On Nov 28, 2010, at 18:19, pilotdds <pilotdds(at)aol.com (pilotdds(at)aol.com)> wrote:
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours
rv10builder(at)verizon.ne
PostPosted: Sun Nov 28, 2010 8:11 pm    Post subject: tach drive cover Reply with quote
Mine was provided by America's Engine when I asked the question.
I used the tubes at HD that can be located in the plumbing department0 basic irrigation tubes. Same thing I used for the wiring too.
Pascal
Sent: Sunday, November 28, 2010 5:19 PM
Subject: tach drive cover
href="http://www.aeroelectric.com">www.aeroelectric.com
href="http://www.buildersbooks.com">www.buildersbooks.com
href="http://www.homebuilthelp.com">www.homebuilthelp.com
href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List
martinaerodrome(at)gmail.
PostPosted: Mon Nov 29, 2010 7:01 am    Post subject: tach drive cover Reply with quote
The covers are available from Klaus Savior (at) Lightspeed engineering in Califorinia, telephone 805 933  3299.  He makes the best electronic ignition systems.  I have dual lightspeeds on my RV8.   2000 plus hours and no problems.  I live in wisconsin and find that cold starts  zero and lower are a no problems.  The engine starts like your car.  NO PREHEATING  ETC.
Dick Martin
RV8 N233M
the fast one
On Sun, Nov 28, 2010 at 7:19 PM, pilotdds <pilotdds(at)aol.com (pilotdds(at)aol.com)> wrote:
"_blank">www.aeroelectric.com
.com/" target="_blank">www.buildersbooks.com
="_blank">www.homebuilthelp.com
get="_blank">http://www.matronics.com/Navigator?RV10-List
ttp://forums.matronics.com
Bill Schlatterer
PostPosted: Tue Nov 30, 2010 6:27 pm    Post subject: tach drive cover Reply with quote
Avery for Tach covers and this is what I did on the blast tubes. I think it's a 1 inch hole, and then a 1 inch snap bushing which just happens to have a groove that snaps into the grooves in 3/4 blast tubing. Perfect and you can't pull it out!
Just one way?
Bill S
7a inspection next week
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of pilotdds
Sent: Sunday, November 28, 2010 7:19 PM
 Filesize:  81.02 KB
 Viewed:  7424 Time(s)
 Filesize:  61.04 KB
pilotdds(at)aol.com
PostPosted: Tue Nov 30, 2010 7:52 pm    Post subject: tach drive cover Reply with quote
Bill,
Thank you for the advice. That is the neatest job I have ever seen on the baffling. Love how you sealed it with angle and bolts. I wish I hadn't already placed 100 pop rivets per Van's plans. I would definitely copy you. I will use your advice on the snap bushings and again - my compliments on the neat baffling and seal.
Jim RV 10 728DD 300 hours # 2 under construction
