Dennis Thate
Posted: Thu Nov 18, 2010 8:22 pm Post subject: Kolb Firestar Winter storage |
I've just purchased a Kolb Firestar / Rotax 503 ULDCDI , I'm putting it in Winter storage. What is the best protocal for storing the Rotax 503UL DCDI for five months ?
rickofudall
Posted: Thu Nov 18, 2010 8:53 pm Post subject: Kolb Firestar Winter storage |
Dennis, Get a spray can of misting oil from the local boat shop. Warm the engine to operating temp, shut it down, remove air filter(s), restart engine and bring throttle up to about 3000 RPM, spray misting oil into carb throats until engine dies. Remove a spark plug from each cylinder and spray oil into cylinders. Replace plugs, seal exhaust with a small rubber ball when it's cool enough not to melt the ball. I use a piece of thick plastic over each carb throat ( a zip lock freezer bag is perfect material ) and put air filter(s) back on. See two stroke Operations Manual 11.1.3, page 11-2 for more detailed instructions, but this will get you in the ball park.
Rick Girard
On Thu, Nov 18, 2010 at 10:22 PM, Dennis Thate <retroman(at)frontier.com (retroman(at)frontier.com)> wrote:
| Quote: | --> Kolb-List message posted by: "Dennis Thate" <retroman(at)frontier.com (retroman(at)frontier.com)>
http://forums.matronics.com/viewtopic.php?p=319987#319987
="_blank">www.aeroelectric.com
ooks.com" target="_blank">www.buildersbooks.com
et="_blank">www.homebuilthelp.com
le, List Admin.
Zulu Delta
Kolb Mk IIIC
582 Gray head
4.00 C gearbox
3 blade WD
Thanks, Homer GBYM
It is not bigotry to be certain we are right; but it is bigotry to be unable to imagine how we might possibly have gone wrong.
- G.K. Chesterton
by0ung(at)brigham.net Guest
Posted: Fri Nov 19, 2010 7:21 am Post subject: Kolb Firestar Winter storage |
I bought a plane so I could go all 12 months of the year,,, unlike boating when there was ice on the lake.. the best thing is to use the plane in the winter and give the engine a good exercise on a regular basis. short of that,,,,, the fogging oil is a real good alternative.
body
Dennis Thate
Posted: Fri Nov 19, 2010 12:53 pm Post subject: Re: Kolb Firestar Winter storage |
by0ung,
Our Midwest Winters are very bitter, I prefer not to fly open Cockpit in them. I admire the pilots that do.
Dennis
45.35 KB |
27352 Time(s) |
Posted: Fri Nov 19, 2010 1:49 pm Post subject: Kolb Firestar Winter storage |
by0ung,
Dennis
probably not much worse than here in northern ut,,,, guess that is why I put on the full enclosure and heater. I have gone out when outside temps hover round 20, 10 when I landed,,,, but days up in the high 30s and low 40s are much preferred.
boyd
zeprep251(at)aol.com Guest
Posted: Fri Nov 19, 2010 6:34 pm Post subject: Kolb Firestar Winter storage |
Boyd,
Ship it down to Rick Neilsen in Fla.He'll keep it warm for you.
G.Aman
Posted: Sat Nov 20, 2010 9:04 am Post subject: Kolb Firestar Winter storage |
Boyd,
G.Aman
guess if i were not a scardi cat... and most of all if i were retired and had the time... I would fly it down and keep it warm with rick... should have done it last year when my son was in the keys.
boyd
neilsenrm(at)gmail.com Guest
Posted: Sat Nov 20, 2010 2:56 pm Post subject: Kolb Firestar Winter storage |
Boyd
Hey just a bunch of short hops strung together. It is certainly nice to be retired so time isn't an issue. It's been in the low 80s and sunny in Florida. Come on down.
I will miss not having my Kolb down here this winter but not that $300/ month hanger charge. I think it will be cheaper to rent this winter. Tuesday I'm scheduled to get checked out in a Sport Cruiser (this is the new Piper LSA). It will not be anything like a Kolb but it is flying and a bit faster.
Gary when you get down here we will need to schedule a flyin. If we can get Buford to leave his home airport again we may be able to talk George A in to joining us????
Rick Neilsen
Redrive VW Powered MKIIIC
On Sat, Nov 20, 2010 at 12:02 PM, b young <by0ung(at)brigham.net (by0ung(at)brigham.net)> wrote:
[quote] B oyd,
G.Aman
boyd
.com/" target="_blank">www.buildersbooks.com
rickofudall
Posted: Sat Nov 20, 2010 3:49 pm Post subject: Kolb Firestar Winter storage |
Rick, You'll like the Piper. Very light handling. I wonder how they set the prop. The Sport Cruiser dealer in Wichita had both his aircraft set so that the 912 could only turn 5200 RPM on take off, but the EFIS showed a nice 138 kt cruise. Not exactly LSA legal, but it sure was fun.
Rick Girard
On Sat, Nov 20, 2010 at 4:48 PM, Richard Neilsen <neilsenrm(at)gmail.com (neilsenrm(at)gmail.com)> wrote:
| Quote: | Boyd
Rick Neilsen
| Quote: | B oyd,
G.Aman
boyd
Zulu Delta
Kolb Mk IIIC
582 Gray head
4.00 C gearbox
3 blade WD
Thanks, Homer GBYM
- G.K. Chesterton
Posted: Sat Nov 20, 2010 4:06 pm Post subject: Kolb Firestar Winter storage |
Boyd,
Just rubb'in it in a little.Packing up the Mk3 and heading south in about 10 days.Tell Becky, Marj says hi.
G.A.
Posted: Sat Nov 20, 2010 4:10 pm Post subject: Kolb Firestar Winter storage |
Rick, Sounds good to me.See you in a couple weeks
G.A.
Posted: Sat Nov 20, 2010 4:36 pm Post subject: Kolb Firestar Winter storage |
Boyd
Rick Neilsen
just need someone to donate say half a mil... d find a way to get more than 1% interest in the bank.... i would have retired last week.
boyd
beauford
Posted: Sat Nov 20, 2010 6:41 pm Post subject: Kolb Firestar Winter storage |
Brother Rick…
I have a car…and a truck. In the event the Nazi 447 will not start…or the Kleenex Kolb will not fly because my butt and the Macanudo stogie are too heavy… will come anyway…
p.s. Brother Alexander is known to be a sucker for these events…
Beauford
FF-076
Brandon, FL
If you forward this e-mail, please remove my name before sending it... I promise to do the same for you...
Thanks...
From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of b young
Sent: Saturday, November 20, 2010 7:33 PM
Subject: Re: Kolb Firestar Winter storage
Boyd
Rick Neilsen
boyd
http://forums.matronics.com[/url]=====[/b][b]
Dennis Thate
Posted: Sat Nov 20, 2010 7:57 pm Post subject: Re: Kolb Firestar Winter storage |
by0ung
Have to admit...this does look like fun
47.44 KB |
27314 Time(s) |
Posted: Sat Nov 20, 2010 8:58 pm Post subject: Kolb Firestar Winter storage |
Ohooooo.......
Gasp...
Is that frozen water?????
Some time in my past I remember bone chilling Michigan winters. I have a pair of frozen water skies that I built for my MKIIIC. I used water skies that I glued and screwed a chunk of 2X4 to with blocking for support. The hinge is a standard door hinge with the hinge pin replaced with a bolt for easy (sort of) removal. The skies were attached just inside the wheels just above the ground so that the plane would roll on a hard surface yet slide in deep snow. The pictured restraining cables keep the skies restrained to a limited movement yet allow rotation and movement over snow banks. The bungee shown was doubled and kept the ski tips up in flight. The aluminum tangs shown fit in front and back of the lower wing strut fittings on the fuselage.
Rick Neilsen
1st Redrive VW Powered MKIIIC
On Sat, Nov 20, 2010 at 10:57 PM, Dennis Thate <retroman(at)frontier.com (retroman(at)frontier.com)> wrote:
236.29 KB |
27311 Time(s) |
elleryweld(at)aol.com Guest
Posted: Sun Nov 21, 2010 6:04 am Post subject: Kolb Firestar Winter storage |
it is Dennis that's my old Firestar & the skis I built for it winter flying is the best
Ellery Batchelder Jr.
Posted: Sun Nov 21, 2010 7:44 am Post subject: Kolb Firestar Winter storage |
p.s. Brother Alexander is known to be a sucker for these events…<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
Beauford
what do you mean..... if the 447 wont start? i thought the kleenex flying machine used a rubber band.
LOL
boyd
Posted: Sun Nov 21, 2010 8:06 am Post subject: Kolb Firestar Winter storage |
--> Kolb-List message posted by: "Dennis Thate" <[url=mhtml:{5AC3E496-28A9-4636-8462-BD772D208FC1}mid://00000194/!x-usc:mailto:retroman(at)frontier.com]retroman(at)frontier.com[/url]>
by0ung
| Quote: | >>>>>>>>>>>>>>>>>>>>>>
have to admit,,, i have never tired skis..... thought about it a bunch.
boyd young
utah
pj.ladd(at)btinternet.com Guest
Posted: Mon Nov 22, 2010 3:12 am Post subject: Kolb Firestar Winter storage |
have to admit,,, i have never tired skis.>>
Hi,
I have a friend, a CFI of a local ultralight school who told me that in his youth he tied the bumpers (fender?) of a car to the undercariage.
This was in a particularly hard winter and he wanted to visit his girl friend on the other side of the valley.
Of course this was in olden times when they were a separate item which could be easily unbolted from the car, not moulded into the body as they are now.
Cheers
Pat
Dennis Thate
Posted: Tue Nov 30, 2010 2:25 pm Post subject: Re: Kolb Firestar Winter storage |
I found this excellent video on Winter Storage of Rotax Aircraft engines.
http://www.mefeedia.com/watch/26641749
_________________ Both optimists and pessimists contribute to our society. The optimist invents the airplane and the pessimist the parachute. ~Gil Stern |
