MHerder
Joined: 11 Feb 2008 Posts: 143 Location: Fort Worth TX
Posted: Thu Nov 18, 2010 6:41 pm Post subject: Engine Shut Down |
Manual on my 3300 says just turn the ignition off to shut it down... Any reason why we should or shouldn't be shutting it off buy shutting off the fuel?
| - The Matronics JabiruEngine-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
_________________ Zodiac 601 HD
Jabiru 3300
Wood Sensinich 64x47
Finally Flying |
Lynn Matteson
Posted: Thu Nov 18, 2010 7:24 pm Post subject: Engine Shut Down |
With a "normal" 3300 using a Bing carb, it would take a little while
to burn the fuel in the float bowl down enough to kill the engine. If
you had a Rotec TBI installed, shutting off the fuel supply would
stop the engine in about 5 seconds. I'm getting to the point that I
can shut off the fuel about 20 feet before my normal stopping (in
front of the hangar) point, and the prop stops when I stop the plane
from rolling.
Lynn Matteson
Jabiru 2200, #2062
Sensenich 62"x46" Wood (summer)
Rotec TBI-40 injection
Status: flying...1068 hrs (since 3-27-2006)
On Nov 18, 2010, at 9:41 PM, MHerder wrote:
Quote: |
<michaelherder(at)beckgroup.com>
One Rivet at a Time!
http://forums.matronics.com/viewtopic.php?p=319979#319979
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
zeprep251(at)aol.com Guest
Posted: Fri Nov 19, 2010 6:34 pm Post subject: Engine Shut Down |
Mike,
If you have a mixture control on your carburetor you could shut it off that way.But if you want to kill it by turning off the fuel selector,be prepared to wait for a couple minutes for the fuel bowl on the Bing to run dry. General aviation engines run a couple hundred degrees higher cylinder head temps and would run on with out spark ignition,you had to starve it of fuel to kill it.
G.Aman Jabiru 2200A 600 hrs
flyadive(at)gmail.com Guest
Posted: Sat Nov 20, 2010 2:56 pm Post subject: Engine Shut Down |
G.Aman:
You are misinformed.
1 - IF the cylinders did "run a couple hundred degrees higher cylinder head temps and would run on with out spark ignition,"<-- Quoted from G.Amam. You wound have a condition of PRE-IGNITION which would surely be there even a few hundred degrees still hotter DURING NORMAL RUNNING. If this occurred you surely would have a rough running engine. And quickly on it way to the grave.
2 - When you make the statement: "General aviation engines run a couple hundred degrees higher cylinder head temps", I am forced to think you are comparing aviation to automotive. Auto engines generally run HOTTER than aircraft engines...
Lets define a few things here. When you say hotter WHAT are you measuring, CHT?
Well there are very few air cooled auto engines out there. Only one comes to mind, the old VW. They were rear mounted, not a very good place for air flow cooling. Yet, they ran very well. So well that they have been used in aviation.
The newer engines of today run hotter than aviation engines for one simple reason: They have higher compression ratios. Most aircraft engines run 7:1, 7.5:1, 8:1. 8.5:1 and there are a few that are 9 & 10:1. Cars start around 10:1 and go up to 12.5:1 for normal production cars. SO, how do they stay cool running? They are liquid cooled. There are some aviation engines that are co-cooled -liquid and air.
So, lets measure something else... EGT.
What is the limiting factor in leaning an engine? Nonuniform air-fuel flow to all cylinders. I say Non Uniform because once you peak one cylinder you stop there. (I am not going to get into LOP & ROP since we are talking carborated engines.) And deforming of the metal. Oh, lets not forget Pre-Ignition. Most engine savvy pilots will not go above 1450 F on EGT and the normal range is usually 1200 to 1400 F. This is done for longevity of the engine.
So maybe the question should be: Why CAN'T we shut down an aircraft engine like a car?
Because car engines are not built like aircraft engines. When you shut down a car engine you shut down all sorts of electrical things, Timing, Computer, Fuel Pump, Air/Fuel Valves and of course the spark. Being that there is a fuel pump and Air/Fuel Valves and most of todays cars are fuel injected... I guess you could say you are shutting the car the same as 'most' a planes.
Loaded Question: If the flash point of gas is so low, below that of internal CHT why do we not Pre-Ignition all the time?
Barry
On Fri, Nov 19, 2010 at 9:27 PM, <zeprep251(at)aol.com (zeprep251(at)aol.com)> wrote:
[quote]Mike,
Posted: Sat Nov 20, 2010 3:12 pm Post subject: Engine Shut Down |
Martin,your right,I should said when the engine is hot
My Beech 35,although injected with a mixture/ fuel cut off had a red line cyl head temp of 435F.My Jabiru runs well under 300f, red lined at 325.Maybe the difference between cast and machined billet heads limits the temps some.Should not have an issue with moving the prop and having it start accidentally ,takes about 300rpm to fire the solid state pickup coil.but the issue was shutting the Bing equipped engine down fuel wise.My Jabiru runs on 100LL as well.
Thanks G.A.
Posted: Sat Nov 20, 2010 4:25 pm Post subject: Engine Shut Down |
Barry
You are absolutely right.What could I have been thinking.
BobsV35B(at)aol.com Guest
Posted: Sat Nov 20, 2010 8:04 pm Post subject: Engine Shut Down |
Good Evening All,
Above all we must remember that the internal combustion engines all run by the same rules whether they drive a lawn mower or are 3350s on a DC-7. The differences are in the details, but the principles do not change. EGTs are NOT the Holy Grail and the actual temperatures do not make any difference at all. They can serve a very important duty in telling us how our engines are doing if we understand that they are relative and not absolute.
LOP is best for longevity if you have adequate distribution. You can get good distribution with a float carburetor or fuel injection, but it is easier to get with fuel injection. The devil is in the details. They are all marvelous things to behold. Don't get blinded by old wives tales. Study the available knowledge and make your own decisions as you learn.
Happy Skies,
Old Bob
In a message dated 11/20/2010 9:42:35 P.M. Central Standard Time, aerobiz1(at)gmail.com writes:
[quote]Hi again G.A.
Re shutdown :
It is not so much the temperature of the cylinder head, but more the glowing embers of carbon or even a spark plug that will keep an engine running - albeit roughly - when you turn the ignition off. That's why we use the lean cut-off on traditional aircraft engines. Starve the critter.....
At other times :
On a Jabiru, with its need to spin fast to get the ignition to fire, you would not expect a broken earth lead - making the ignition always hot - to be so much of a danger than it would be on a Lycoming with its impulse-coupled magneto.
Pull through one blade, as slow as you lie, and you can easily fire the engine up.
So there is a few techniques to shutting your engine down. If you don't have a mixture cut-off like you would with a Rotec TBI or Aerocarb or regular Lycoming type carb or fuel injection system, you can simply turn the ignition off and hope that there are no glowing embers in a combustion chamber, (if there is, push the throttle full open - often the technique used on Gypsy Majors in Austers and Tiger Moths) or you can turn the fuel valve off and wait for the Bing float bowl to empty.
Realistically, just turn the ignition off.....
Martin
On Sun, Nov 21, 2010 at 9:09 AM, <zeprep251(at)aol.com (zeprep251(at)aol.com)> wrote:
[quote] Martin,your right,I should said when the engine is hot
Thanks G.A.
aerobiz1(at)gmail.com Guest
Posted: Sat Nov 20, 2010 9:46 pm Post subject: Engine Shut Down |
Well said Bob,
Cheers
Martin
On Sun, Nov 21, 2010 at 2:01 PM, <BobsV35B(at)aol.com (BobsV35B(at)aol.com)> wrote:
[quote] Good Evening All,
Happy Skies,
Old Bob
In a message dated 11/20/2010 9:42:35 P.M. Central Standard Time, aerobiz1(at)gmail.com (aerobiz1(at)gmail.com) writes:
Re shutdown :
At other times :
Martin
Thanks G.A.
Float Flyr
![](images/avatars/6347796944bf72a583fa4.jpg)
Posted: Sun Nov 21, 2010 6:53 am Post subject: Engine Shut Down |
Martin:
You have #2 backward. A broken P-Lead won’t allow the ignition to be grounded out... therefore not allowing the pilot any other method of stopping the engine other than fuel starvation. It will start just fine.
Noel
From: owner-jabiruengine-list-server(at)matronics.com [mailto:owner-jabiruengine-list-server(at)matronics.com] On Behalf Of Martin Hone
Sent: November 19, 2010 11:22 PM
Subject: Re: Engine Shut Down
Hi G.A.
I wouldn;t be too sure about that. I think you will find that the CHT's of any well running Continental or Lycoming are pretty much the same as for a well running Jab. That would be between 300 and 380 degrees F in my experience. The reason these engines use idle mixture cut-off is
1. Because they can
2. A broken 'P' lead won't allow the engine to fire if the prop is moved
3. Highly leaded fuels provide more material that can glow in the combustion chamber and will keep the engine running-on even if the mags are switched off.
Cheers
Martin
On Sat, Nov 20, 2010 at 12:27 PM, <zeprep251(at)aol.com (zeprep251(at)aol.com)> wrote:
Mike,
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Float Flyr
Posted: Sun Nov 21, 2010 8:01 am Post subject: Engine Shut Down |
Barry:
I think you answered your own question. The fuel injectors are electrically operated. They spray a fine mist of fuel into the cylinders just before the spark is given. Spraying cold fuel into the cylinder at that time causes the cylinder to cool a little ( may or may not be appreciable ) but also it means there isn’t any fuel there detonate. Anti knock detectors will also adjust the timing of the fuel injection to prevent knocking.
Noel
Barry
Mike,
Kitfox III-A
Posted: Sun Nov 21, 2010 12:25 pm Post subject: Engine Shut Down |
Hi Noel,
You are correct. What I was trying to say was that a broken 'P' lead would prevent you shutting down the engine,
Cheers and thanks
Martin
On Mon, Nov 22, 2010 at 12:50 AM, Noel Loveys <noelloveys(at)yahoo.ca (noelloveys(at)yahoo.ca)> wrote:
Martin:
Noel
From: owner-jabiruengine-list-server(at)matronics.com (owner-jabiruengine-list-server(at)matronics.com) [mailto:owner-jabiruengine-list-server(at)matronics.com (owner-jabiruengine-list-server(at)matronics.com)] On Behalf Of Martin Hone
To: jabiruengine-list(at)matronics.com (jabiruengine-list(at)matronics.com)
Subject: Re: JabiruEngine-List: Engine Shut Down
Hi G.A.
1. Because they can
Cheers
Martin
Mike,
Posted: Sun Nov 21, 2010 3:40 pm Post subject: Engine Shut Down |
Noel:
So how do you explain it for NON-Fuel Injected engines?
Or engines WITHOUT anti-knock equipment?
And even those fuel injected engine WITHOUT electric injectors?
Remember... I said it was a LOADED QUESTION
Barry
On Sun, Nov 21, 2010 at 10:56 AM, Noel Loveys <noelloveys(at)yahoo.ca (noelloveys(at)yahoo.ca)> wrote:
Barry:
Noel
Barry
Mike,
dave.go
Posted: Sun Nov 21, 2010 5:09 pm Post subject: Engine Shut Down |
The autoignition temp of gasoline is just below 500 deg., below that it needs an ignition source. So maybe the answer is that flash point is not autoignition temp.
Quote: |
Noel
Barry
Posted: Mon Nov 22, 2010 5:25 am Post subject: Engine Shut Down |
Very Good Dave:
Wait for it....
Wait for it....
BUT!
The internal temps of a cylinder are higher than CHT readings. BUT! You do have about 60% of the question answered.
Think of it this way... What would cause the flash point to change?
Before I give the answer, lets try another question?
Sort of a HINT
At what Temperature does water boil?
And remember this is a Loaded / Trick Question AND remember who is asking it
Barry
On Sun, Nov 21, 2010 at 8:06 PM, Dave <d.goddard(at)ns.sympatico.ca (d.goddard(at)ns.sympatico.ca)> wrote:
[quote] The autoignition temp of gasoline is just below 500 deg., below that it needs an ignition source. So maybe the answer is that flash point is not autoignition temp.
Quote: |
Quote: |
Noel
Barry
_blank">www.aeroelectric.com
.com" target="_blank">www.buildersbooks.com
="_blank">www.homebuilthelp.com
ist" target="_blank">http://www.matronics.com/Navigator?JabiruEngine-List
Kayberg(at)aol.com Guest
Posted: Mon Nov 22, 2010 5:41 am Post subject: Engine Shut Down |
At the risk of messing up a perfectly good teacher-pupil exchange along with some drama, could the word be "pressure'?
Pressure would increase the temperatures a la diesel.
However, Jabiru engines dont seem to diesel or at least I have never heard of one doing it. And neither do Rotax 912s....which have even higher compression.
Tell me again why we are even bothering to discuss Ly-Con's ?
Doug k.
In a message dated 11/22/2010 8:25:31 A.M. Eastern Standard Time, flyadive(at)gmail.com writes:
Quote: | Very Good Dave:
Wait for it....
Wait for it....
BUT!
Sort of a HINT
Barry
Quote: | The autoignition temp of gasoline is just below 500 deg., below that it needs
Posted: Mon Nov 22, 2010 6:14 am Post subject: Engine Shut Down |
Good Morning Doug k.
You asked: "Tell me again why we are even bothering to discuss Ly-Con's ?"
Because we are here to learn and all Otto Cycle engines have the same principles of operation. If you are a trained engineer with many years of hands on development of this art, this is probably a waste of time. However, for those of us who are still learning, we need to understand how the problems have been solved in the past so that we can do a better job of understanding the variances in our Jabiru engines.
All part of the learning process.
Make any better sense that way?
Happy Skies,
Old Bob
Legend Cub
Jabiru 3300
(Not mine, my granddaughter's.)
In a message dated 11/22/2010 7:41:23 A.M. Central Standard Time, Kayberg(at)aol.com writes:
Quote: | At the risk of messing up a perfectly good teacher-pupil exchange along with some drama, could the word be "pressure'?
Doug k.
Posted: Mon Nov 22, 2010 6:37 am Post subject: Engine Shut Down |
Old Bob, yours is a thoughtful answer.
However, how far back do we need to go? There are literally volumes written about Otto Cycle and many many engineers who delight in sharing their knowlege.....
And when you compare one engine design to another, many other possiblites emerge. For example, is the Jabiru more like your lawn mower or more like a Lycoming? Your lawn mower is not shut off by leaning the mixture, just by grounding the equivalent of a P-lead. In that sense a Jabiru is more like your lawn mower. (unless you have an electric one...but that uses a switch also)
I am just hoping this thread does not turn into an engineers nightmare.
Doug Koenigsberg
In a message dated 11/22/2010 9:14:46 A.M. Eastern Standard Time, BobsV35B(at)aol.com writes:
Happy Skies,
Old Bob
Legend Cub
Jabiru 3300
Posted: Mon Nov 22, 2010 7:05 am Post subject: Engine Shut Down |
Good Morning Doug,
Agreed! In fact we often err in many operations because "It has always been done that way."
Shutting down the engine by taking away it's fuel is just one of those habits that do not necessarily serve any real purpose. When doing repetitive flights such as passenger hops and Young Eagle flights some engines start a lot easier if the switch is used for that purpose. I find no heartburn at all when I shut down the Jabiru by turning off the ignition switch.
We could probably write volumes about all of the Old Wives Tales concerning piston engine operation.
All part of our continuing education!
Happy Skies,
Old Bob
PS As for the lawn mower and Lycoming, they both suck, push, bang, and blow! <G>
In a message dated 11/22/2010 8:38:05 A.M. Central Standard Time, Kayberg(at)aol.com writes:
Doug Koenigsberg
Float Flyr
Posted: Tue Nov 23, 2010 8:50 am Post subject: Engine Shut Down |
Ok but you did ask about fuel injected engines..
With non-injected engines they will “ping” just about all the time but you will only be able to notice it when the rpm and load are in specific quantities. For instance a friend of mine many years ago had a Ford 500 with the 390 4bbl., dual low resistance exhausts and mo doubt a few other goodies on it. It had a real problem for we idiot speed demons, it backfired like a mule after 90 mph. That was long before it really got producing what it could. After trying everything to stop the backfiring my friend finally got rid of the car. Several years later the Royal Newfoundland Constabulary had the same problem with a factory built hotrod they got from GM. The Constab, had their own fuel supply so they knew it was high octane. GM technicians from the factory spent two weeks working on the car until they had exhausted ( pardon the pun) every possibility. One of the technicians then sent a sample of the fuel back to GM for a flash test.... It was low-low octane. The Constabulary then decided to test all the high octane tanks in the area, of some fifty tanks tested only one actually had high octane fuel. The Constabulary then charged their test lab with fixing octane numbers and sent notification to all the oil companies servicing the province with warning that their fuel would be tested on a regular basis. The reply they got form their supplier was that they would no longer do octane testing for the Constabulary.
The reason conventionally aspirated direct drive aircraft engines get away, most of the time, with lower octane fuel is they are specifically tuned to operate at high throttle settings for extended periods of time. They are also designed to mostly work at lower rpm with a much flatter torque curve than a conventional auto engine. Of course those engines are only certified to use specific fuels so the question is a bit mute. They are also generally high displacement for the power they deliver. The interesting thing with the big radials is they develop so much heat they actually change shape in different phases of flight. Descent is a particularly touchy time as it is dangerous to allow the engine to cool too much as you may need the power on short notice and drawing power form a cold engine is a recipe for not too much fun.
There are also many large air-cooled gear driven radial engines which rev to the territory of the 912 and it was not uncommon for them to blow jugs on flights even with the certified fuels. In fact there used to be a running joke that you could always tell the mechanic at an airport because he was the one who drove the biggest, most expensive or fastest car. He made his money replacing cylinders on corn cob radials. ;->
Back from the diversion.... The engines we use (912 UL etc.) are designed to operate efficiently in the extended rpm envelope using fuels of lower octane. Those engines which use higher compression ratios and/or turbo charging ( 914 etc.) are designed to operate on higher octane no lead auto fuels. This is great as long as such fuels are available. The problem we are now coming into is the extended use of ethanol, both as an oxidizer and an octane booster... don’t start me on that one!
Noel
From: owner-jabiruengine-list-server(at)matronics.com [mailto:owner-jabiruengine-list-server(at)matronics.com] On Behalf Of FLYaDIVE
Sent: November 21, 2010 8:08 PM
Noel:
Barry
Barry:
Noel
Barry
Mike,
Kitfox III-A
