philperry9(at)gmail.com Guest
Posted: Fri Nov 12, 2010 2:37 pm Post subject: Wheel Bearings and Grease |
I'm getting close to being on the gear and I noticed Vans calls for Aeroshell #5 within the plans. So that's what I purchased from ACS and it came in today.
Just a few minutes ago I noticed the Cleveland wheels in the finish kit have Mobil Aviation SHC 100 already in the bearings. (Not sure if they're packed though)
What does one need to know of or be cautious of when mixing grease types?
Phil
Strasnuts
Joined: 10 Feb 2009 Posts: 502 Location: Salt Lake City, UT
Tim Olson
Posted: Fri Nov 12, 2010 3:08 pm Post subject: Wheel Bearings and Grease |
Phil,
Normally I don't stray from Aviation grade on products. I use
aviation grade oil. Aviation grade brake fluid, and
on my prop I use Aviation grade grease.
On the wheels though, I went out and shopped at the local
stores and saw what they had, and got a semi-synthetic
grease that I use instead. I first got the specs for Aeroshell
to know what I needed to match. Temp ranges in particular,
and everything else. I found an exact or almost exact match
in the semi synthetic high performance wheel bearing grease
that I can buy in the store. The nice thing is, it's
cheaper, it's available, and I don't have to worry about
mixing or running out when I'm in the middle of an
unplanned wheel-pull. Whereas everything else that uses
grease deserves the right grease, wheel bearings are still
pretty much wheel bearings, so since we're experimental,
I step out and use a good quality grease that I can
get without the hassle. On the prop, I'd NEVER substitute.
I wouldn't mix greases...you just never know. Not saying
you should follow what i did, either, but IMHO, if there
is a place to change grease, that would be it. I use
a grease gun with the big tubes, and a cone shaped packer
that you inject them with. It's nice when/if I waste some
I don't feel so bad since I can always buy another
tube for $3 or whatever it is....and I keep extras at
home and the hangar for the cars too.
Tim Olson - RV-10 N104CD
On 11/12/2010 4:30 PM, Phillip Perry wrote:
Quote: | I'm getting close to being on the gear and I noticed Vans calls for
it came in today.
Phil
Kellym
Posted: Fri Nov 12, 2010 4:51 pm Post subject: Wheel Bearings and Grease |
Don't mix. Don't use automotive. Only aircraft wheel bearing grease is
formulated to handle the instantaneous spool up when you land. You
already have the Aeroshell. Clean out the other grease and use it. Esp
for Texas and other southern climes. I understand using something
different for cold country.
Phil
KCHD |
