rparigoris
Posted: Fri Nov 12, 2010 12:10 pm Post subject: Pressure sender bleeding |
There has been a suggestion to bleed the oil pressure sender:
"the suggestion of dripping oil into the line from the 912's port over to the firewall-mounted sensor worked just fine"
I have a concern that with my UMA differential pressure sender for my 914 that there will be the same fuel in the line for a long time (differential is fuel pressure going to the carbs over airbox pressure).
Instead of bleeding the line with Mogas, I could use 100LL which would probably be a better choice.
I am wondering if there is a better fluid to use for bleeding other than 100LL?
Thx.
Ron Parigoris
