Mags switches
graeme bird
PostPosted: Fri Nov 12, 2010 11:08 am    Post subject: Mags switches Reply with quote
I am confused I have a A510-2 keyed mag switch type from Aircraft spruce which I am trying to wire into my panel. However, for the Rotax I expected it to ground the mags when in the off and for them to be open when on. The switch seems to be the opposite. Am I mistaken? Or is this switch for Cessna mag types which operate differently?
Graeme Bird
kit4 (Wagstaff) TBD
Kit 1 G-UMPY - Mono Classic/XS 912S, Woodcomp G(@)gdbmk.co.uk
keithhickling(at)clear.ne
PostPosted: Fri Nov 12, 2010 8:48 pm    Post subject: Mags switches Reply with quote
Graeme,
I have the same switch (A510-2) wired as shown in the attached diagram.
The mags are earthed in the off position, not earthed in both and start
positions. Works fine. Is your switch different from this?
Keith Hickling,
76 Rockside Road,
Glenleith,
Dunedin 9010,
New Zealand.
+64 3 4679101.
Ignition_switch.doc
 Filename:  Ignition_switch.doc
 Filesize:  58 KB
 Downloaded:  341 Time(s)
graeme bird
PostPosted: Mon Nov 15, 2010 1:13 pm    Post subject: Re: Mags switches Reply with quote
Thanks for that, I have concluded the switch I have is just duff, it should have worked ok. Ha, took it apart and now I cant get it back together - its obviously quite old so I shall use separate switches as recomended by Rotax.
Ta
Graeme Bird
kit4 (Wagstaff) TBD
