Engine Thrust Angle: Page two. Leveling the plane
teamgrumman(at)yahoo.com
PostPosted: Fri Nov 05, 2010 8:29 pm    Post subject: Engine Thrust Angle: Page two. Leveling the plane Reply with quote
I leveled my plane today. Not a simple feat. Turns out, I needed about 4 inches under the main gear plus a jack under the tail tie down to lift it an additional 3 inches. Then, I removed air from the right tire to level it side-to-side.
 Filesize:  59.29 KB
 Viewed:  984 Time(s)
 Filesize:  55.65 KB
 Viewed:  984 Time(s)
 Filesize:  44.31 KB
 Viewed:  984 Time(s)
 Filesize:  47.32 KB
 Viewed:  984 Time(s)
 Filesize:  37.64 KB
 Viewed:  984 Time(s)
 Filesize:  44.07 KB
 Viewed:  984 Time(s)
 Filesize:  54.87 KB
 Viewed:  984 Time(s)
 Filesize:  47.33 KB
 Viewed:  984 Time(s)
