alainchabert(at)wanadoo.f Guest
Posted: Thu Nov 04, 2010 10:43 am Post subject: Woodcomp SR2000 |
Hello sirs,
I see on the website Europa-Club, the different propellers choice,
Airmaster, woodcomp, Arplast, Warp drive, NSI....
I have woodcomp propeller SR2000 on my aircraft since 270 hours flight
with total satisfaction.
The French civil aviation require to me an approval document from Europa
or British administration.
Do you have an official approval document from Europa or British
administration to use this propeller on the monowheel model?
Thanks for your answer.
Excuse my poor english
Alain Chabert
Posted: Thu Nov 04, 2010 11:04 am Post subject: Woodcomp SR2000 |
Hello sirs,
Excuse my poor english ;°)
Alain Chabert
g-iani(at)ntlworld.com Guest
Posted: Thu Nov 04, 2010 12:35 pm Post subject: Woodcomp SR2000 |
Alain
I have attached a copy of the LAA (British Administration) which gives the
prop choice for the Europa.
The only standard approved prop is the ground adjustable Warp drive.
Everything else (see the bottom of the document) has to be done on an
individual application for each aircraft. I personally think this is
unnecessary bureaucracy but I have failed to persuade LAA to change it. LAA
claim they need to look at the combination of the aircraft, engine and prop
to approve the combination.
May I suggest you call Andy Draper at LAA and ask if he can help
Ian Rickard G-IANI XS Trigear, 300hours
Europa Club Mods Specialist
e-mail g-iani(at)ntlworld.com
Europa_Europa%20XS%20PTL_1.pdf |
1.09 MB |
592 Time(s) |
davidjoyce(at)doctors.org Guest
Posted: Fri Nov 05, 2010 1:37 am Post subject: Woodcomp SR2000 |
Alain, I attach a copy of my LAA Permit on which you will see that a
Woodcomp SR2000 or SR 3000 is approved, which may be enough for your
purposes. Regards, David Joyce
173.44 KB |
3335 Time(s) |
Posted: Sat Nov 06, 2010 10:54 am Post subject: Woodcomp SR2000 |
Ian and David
Thank you for your prompt reply.
I sent my application with a copy of the LAA permit, and I expect feedback.
I would not fail to keep you informed
Alain Chabert
