dan(at)azshowersolutions. Guest
Posted: Mon Nov 01, 2010 8:10 pm Post subject: Z-16 |
I just received the S704-1 Alt OV disconnect relay from B&C. AFter searching
several sources, I think I know how to connect. The question I have is...as
there are two coil tabs, does it matter how the polarity is attached? Thanks
Dan
Posted: Tue Nov 02, 2010 12:16 pm Post subject: Z-16 |
Still no joy for answer to previous question below...?
----- Forwarded Message ----
From: Dan Billingsley <dan(at)azshowersolutions.com>
Sent: Mon, November 1, 2010 9:05:02 PM
Subject: Z-16
Dan
Posted: Wed Nov 03, 2010 6:05 am Post subject: Re: Z-16 |
Hi Dan,
I am not familiar with the S704-1 relay. But since nobody else answered, I will give it a shot. Polarity of the coil does not matter for most relays. If a relay has a built in diode, then polarity will matter. You could test the coil with an ohmmeter to see if the coil is short circuited with one polarity and not the other. Or you could put a small lamp in series with the relay. If the lamp gets brighter with one polarity compared to the opposite polarity, then there is a built in diode and the correct polarity is when the lamp is dim. Or you could power up the relay using a power supply with built in short circuit protection and see what happens. Or you could call B&C and ask them.
Joe
_________________ Joe Gores |
Posted: Wed Nov 03, 2010 7:06 am Post subject: Z-16 |
At 09:05 AM 11/3/2010, you wrote:
| Quote: | --> AeroElectric-List message posted by: "user9253" <fran4sew(at)banyanol.com>
Hi Dan,
I am not familiar with the S704-1 relay. But since nobody else answered, I will give it a shot. Polarity of the coil does not matter for most relays. If a relay has a built in diode, then polarity will matter. You could test the coil with an ohmmeter to see if the coil is short circuited with one polarity and not the other. Or you could put a small lamp in series with the relay. If the lamp gets brighter with one polarity compared to the opposite polarity, then there is a built in diode and the correct polarity is when the lamp is dim. Or you could power up the relay using a power supply with built in short circuit protection and see what happens. Or you could call B&C and ask them. |
Good put. I'm aware of no commercial-off-the-shelf relays
with built in diodes and only a few contactors with such
devices already installed. If they DO feature internally
wired diodes, the coil terminal polarity will be marked
and the device will probably have some symbolism or
text notification of the feature.
The "S704" is a catalog number for a "T91" style
SPDT relay first defined by Potter-Brumfield as
I recall . . . and later 'cloned' by many others
as popularity of this device soared.
[img]cid:.0[/img]
But it's nothing special. Any 12v, 30A, DPDT
relay will do the same job . . . including
this device from Radio Shack
[img]cid:.1[/img]
Catalog #275-226. Many of the BigBox auto parts
stores sell similar devices in peg-racked blister-
paks. It might be called a "headlight relay".
But its a sure bet than none will feature built
in diodes. Here's an exemplar part from the
AutoZone website:
http://tinyurl.com/24gobxs
Interestingly enough, AutoZone stocks a pre-terminated
diode assembly that can be added to this or similar
relays:
http://tinyurl.com/2cqrk4q
( -Thomas Paine 1776- )
27.81 KB |
8755 Time(s) |
11.18 KB |
8755 Time(s) |
Posted: Wed Nov 03, 2010 7:42 am Post subject: Z-16 |
| Quote: | Interestingly enough, AutoZone stocks a pre-terminated
relays:
Whew!!!! just noted that this part sells for
about $10. Go get your own 1N5402, 75-cent
critters from R-S . . .
[img]cid:7.1.0.9.0.20101103103656.01d20110(at)aeroelectric.com.2[/img]
12.36 KB |
8755 Time(s) |
Posted: Wed Nov 03, 2010 7:48 am Post subject: Z-16 |
Joe and Bob,
Thank you for your reply...I found it interesting that the relay had little to
no markings. It came with a sheet that identified a couple of contacts, yet left
the coil to one's imagination. This led me to believe that polarity is not an
issue. Again, thanks Joe for the reply and practicle things to try to make
determinations.
Best wishes, Dan
tim2542(at)sbcglobal.net Guest
Posted: Wed Nov 03, 2010 10:05 am Post subject: Z-16 |
I bought relays from NAPA, no diode but they do have resistors in the coil circuit. I don't have the part number with me but can get it.
Tim Andres
On Nov 3, 2010, at 8:04 AM, "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
[quote] At 09:05 AM 11/3/2010, you wrote:
| Quote: | --> AeroElectric-List message posted by: "user9253" <fran4sew(at)banyanol.com (fran4sew(at)banyanol.com)>
Hi Dan,
<263881f.jpg>
<263887d.jpg>
AutoZone website:
relays:
jonlaury
Posted: Thu Nov 04, 2010 6:46 am Post subject: Re: Z-16 |
Bob said:
| Quote: | I'm aware of no commercial-off-the-shelf relays
devices already installed. |
Check out http://www.texasindustrialelectric.com/relays.asp. They have several ice cube types w/diode, of varying capacity.
pestar
Joined: 11 Apr 2007 Posts: 61 Location: Auckland, New Zealand
Posted: Thu Nov 04, 2010 11:49 pm Post subject: Re: Z-16 |
Go to http://www.narva.com.au/products/browse/relays, they have a range of relays with the diode built in at low cost. I am using them for OV protection as per Bobs diagrams.
Yep I know it is down under but the relays are manufactured in Europe.
Cheers
Peter Armstrong
