romeo.victor(at)t-online. Guest
Posted: Mon Nov 01, 2010 12:18 am Post subject: AW: Canopy Skirt Buzz... |
Use felt, it doesn't hurt the painting and slips over the surface.
-----Ursprüngliche Nachricht-----
Von: owner-rv8-list-server(at)matronics.com
[mailto:owner-rv8-list-server(at)matronics.com] Im Auftrag von Vince Himsl
Gesendet: Sonntag, 31. Oktober 2010 19:43
An: rv8-list(at)matronics.com
Betreff: RE: Canopy Skirt Buzz...
I use the more expensive p-channel door seal from Home Depot, meaning it is
not. Trick is, I heat the tape glue with a heat gun before applying it. Same
for Velco. Stuff doesn't budge.
You could use the 1/4 inch sound damping foam (sandwich of foil, foam, glue)
from ACS on the underside of the turtle deck to stiffen up it up. Come to
think of it, this may be just that, a turtle deck problem rather than a
canopy skirt problem.
My skirt doesn't buzz either. But then, I used super sound proofing and the
above mentioned foam wherever I suspected 'oil canning' might be a problem.
Vince H.
Washington State
RV8 69.5 hours & still stalling on the wheel pants, fairings, and paint.
| | - The Matronics RV8-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
