Larry's plane. Finally finished. Except for the cowling.
teamgrumman(at)yahoo.com
PostPosted: Sun Oct 31, 2010 11:07 am    Post subject: Larry's plane. Finally finished. Except for the cowling. Reply with quote
Clytie changed the tires on Larry's plane. I need to clean up the calipers and brakes and get them installed. Someone had installed a flexible brake line going to the caliper. Problem is, the way it's installed, there is a 4 inch loop of hose sticking above the caliper. Now I know why the wheel fairings weren't installed; they wouldn't fit.
Talked to Dave, the cowling should be done Wednesday or Thursday. This should be fun.
 Filesize:  70.26 KB
 Viewed:  923 Time(s)
 Filesize:  69.41 KB
 Viewed:  923 Time(s)
