Bent tailwheel,
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Glasair-List
John Bolding
PostPosted: Sat Oct 30, 2010 4:41 pm    Post subject: Bent tailwheel, Reply with quote
Got a buddy with a II TD and 40 hrs total time, tailwheel assy bent to one
side, easy enough to fix and strengthen but is this a common problem? He
operates off grass but smooth.
John
- The Matronics Glasair-List Email Forum -
http://www.matronics.com/Navigator?Glasair-List
bgray(at)glasair.org
PostPosted: Sun Oct 31, 2010 7:18 am    Post subject: Bent tailwheel, Reply with quote
Yes.
Bruce
www.Glasair.org
robin02(at)mindspring.com
PostPosted: Sun Oct 31, 2010 11:16 am    Post subject: Bent tailwheel, Reply with quote
John, I built a Glasair 1 TD in 1984 and still fly it. The problem you described happened to me early on. I reinstalled the strut with the mill fiber as the manual indicated and added bi=directional cloth around the outside and onto the fuselage. It was probably 4-6 layers. No problems since. Robin Young 286YM.
----->Got a buddy with a II TD and 40 hrs total time, tailwheel assy bent to one
John
John Bolding
PostPosted: Sun Oct 31, 2010 12:06 pm    Post subject: Bent tailwheel, Reply with quote
Thanks for the reply Robin but the part that bent is the steel piece that
the wheel mounts in, any problems there?
Thanks John
PostPosted: Mon Nov 01, 2010 9:14 am    Post subject: Bent tailwheel, Reply with quote
John, the fork is not where the streeses showed on mine. I have gone to the Grove gear and increased my gross to 1900lbs from the original 1500lb. landing weight. Still there has been no problem. RObin
PostPosted: Mon Nov 01, 2010 9:23 am    Post subject: Bent tailwheel, Reply with quote
And I'll bet you make wheel landings rather than full stall.
Bruce
www.Glasair.org
PostPosted: Mon Nov 01, 2010 9:55 am    Post subject: Bent tailwheel, Reply with quote
Yep...all wheel landings. RObin
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Glasair-List All times are GMT - 8 Hours
