Slow day --- and cracks in   the   horizon
GrummanDude
PostPosted: Tue May 02, 2006 10:12 am    Post subject: Slow day --- and cracks in   the   horizon Reply with quote
In a message dated 5/2/06 7:39:42 AM, gilalex(at)earthlink.net writes:
I always thought that the red stuff had a higher temperature rating...
OK, and, if it does have a higher temp rating .... then what? You aren't
going to put it on the exhaust because it will burn off in about 2 minutes.
Anywhere else would not be subjected to any more than 250 degrees. And the
orange stuff is ugly. If the engine catches on fire, the last thing you'll ever
care about is whether or not the silicone on your baffles is going to melt.
Gary
AuCountry Aviation
Home of Team Grumman
