bringing Pitot and static tubes into fuselage
graeme bird
PostPosted: Thu Oct 21, 2010 12:26 am    Post subject: bringing Pitot and static tubes into fuselage Reply with quote
Advice sort on the best place to bring the pitot and static lines (plus strobes) into the fuselage from the port wing. Concerned about reducing structural strength at the wrong point. Am tempted to bring in way back near the flap control rod opening as is tidy for the cockpit.
Graeme Bird
kit4 (Wagstaff) TBD
Kit 1 G-UMPY - Mono Classic/XS 912S, Woodcomp G(@)gdbmk.co.uk
graeme bird
PostPosted: Wed Oct 27, 2010 12:35 pm    Post subject: Re: bringing Pitot and static tubes into fuselage Reply with quote
I didnt get any response on this, was it a stupid question? I still cant find out where they are supposed to come through.
Advice appreciated.
Graeme Bird
kit4 (Wagstaff) TBD
rlborger(at)mac.com
PostPosted: Wed Oct 27, 2010 1:17 pm    Post subject: bringing Pitot and static tubes into fuselage Reply with quote
Graeme,
I understand there is no specific direction for the routing and exit of the pitot/static plumbing. It's pretty much what ever works best for you.
Check six,
Bob Borger
http://www.europaowners.org/N914XL
Europa XS, Short Wing, Intercooled Rotax 914
rlborger(at)mac.com
Cel: 817-992-1117
Advice appreciated.
Graeme Bird
rparigoris
PostPosted: Wed Oct 27, 2010 1:58 pm    Post subject: Re: bringing Pitot and static tubes into fuselage Reply with quote
Hi Graeme
You can look through this album for some ideas:
http://www.europaowners.org/forums/gallery2.php?g2_itemId=31838
Ira and Bobs routing are at the beginning.
My choice is scattered about the album a bit, but I ran 3 pneumatic hoses and wires on the port side and 1 pneumatic hose and wires on the starboard side.
They are just aft of the spars and sneak between the fuse and the fuel tank and poke out through the space between the headrest and fuse side.
Since I needed to get some of the port wires to the starboard headrest, I covered the wires with Teflon expando sleeve and snaked it above the fuel tank to the inside of the starboard headrest.
I considered the aft route, but couldn't make it work as well for me . If you do consider the aft route keep in mind weakening it may cause the rear liftpin socket.
Good luck
Ron Parigoris
Stbd 1 pneumatic hose and the other is for wires:
http://www.europaowners.org/forums/gallery2.php?g2_itemId=84429
Port 3 pneumatic:
http://www.europaowners.org/forums/gallery2.php?g2_itemId=84432
Port exiting between headrest and fuse:
http://www.europaowners.org/forums/gallery2.php?g2_itemId=31871
jan_de_jong(at)casema.nl
PostPosted: Wed Oct 27, 2010 3:45 pm    Post subject: bringing Pitot and static tubes into fuselage Reply with quote
This is still in the future for me, but I think my plan is:
- from wing conduit outlet behind the spar over the spar (under fairing)
to in front of spar
- connections in front of spar
- into fuselage behind seat
- up to window sill by headrest avoiding motorglider wings spoiler
actuator hole in the corner (fuselage side just below spar pin hole)
- join window sill conduit
I have the impression that this was once considered the standard way. It
may be in the manual somewhere.
Jan de Jong
Advice appreciated.
jrgowing(at)bigpond.net.a
Graeme
I placed my tube into the fuselage rear of the fuselage stiffener. Holding the tube in place alongside the stiffener, I added a cover rising to just under the fuselage side stiffener (door sill) of the fuselage where I made a triangular support for the sill which is also a tunnel for wiring and tubes which can go either way……
JR Kit 327 in OZ
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of graeme bird
Sent: Thursday, 28 October 2010 7:35 AM
Subject: Re: bringing Pitot and static tubes into fuselage
--> Europa-List message posted by: "graeme bird" <graeme(at)gdbmk.co.uk (graeme(at)gdbmk.co.uk)>
Advice appreciated.
Graeme Bird
http://forums.matronics.com/viewtopic.php?p=317245#317245
http://www.matron--> http://forums.matronics.com
_p; - List Contribution bsp;   -Matt Dralle, List href="http://www.matronics.com/contribution">http://www.matronics.com/c=================
Checked by AVG - www.avg.com
Version: 10.0.1152 / 10/26/10
europa471
PostPosted: Wed Oct 27, 2010 4:46 pm    Post subject: bringing Pitot and static tubes into fuselage Reply with quote
Graeme
Attached (I hope) is a page from what I believe was the final ¨Europa
News¨ from the old Company.
Lance Sandford in OZ
Advice appreciated.
Graeme Bird
 Filesize:  60.43 KB
 Viewed:  7206 Time(s)
Ivor Phillips
PostPosted: Thu Oct 28, 2010 1:55 am    Post subject: bringing Pitot and static tubes into fuselage Reply with quote
Hi Graeme
If you follow the workshop manual then the entry points for the Pitot/Static tube
Are self explanatory, A gentle curve to the front of the spar with entry between the spar and  forward pins,  It will be well away from any hard points,
Ivor
Pitot/static tube
Drill two 1/4” diameter holes through the port fuselage side midway between the forward wing
socket and the spar opening, making sure to keep them away from the seat belt mounting. These
holes are for the pitot/static tubes.
When rigging the aircraft the tubes will be led over the top of the spar tang
Page 27 - 22 Issue 2 Europa Build Manual
On 27 October 2010 21:35, graeme bird <graeme(at)gdbmk.co.uk (graeme(at)gdbmk.co.uk)> wrote:
[quote]--> Europa-List message posted by: "graeme bird" <graeme(at)gdbmk.co.uk (graeme(at)gdbmk.co.uk)>
Advice appreciated.
Graeme Bird
http://forums.matronics.com/viewtopic.php?p=317245#317========================
y Browse, Chat, FAQ,
="http://www.matronics.com/Navigator?Europa-List" target="_blank">http:=====
http://forums.mle, List Admin.
