Posted: Sat Oct 16, 2010 4:54 pm Post subject: Laptop supply for your car/airplane |
I just ran across this item on Ebay:
http://tinyurl.com/2cyx7c7
With an input from your 14v bus, it can be set up
to provide the typical 18-20 volts needed by many
laptops.
Bob . . . [quote][b]
sportav8r(at)gmail.com Guest
Posted: Sat Oct 16, 2010 5:24 pm Post subject: Laptop supply for your car/airplane |
Sounds like it may be useful for powering portable HF gear (the common 10 watt rice boxes) from Li-poly or Li-metal cells that don't readily supply 12.6-13.8v ganged as batteries. 85% efficiency is not stellar, but might still be better efficiency than a dropping regulator on a 16v pack...
-Bill Boyd
On Sat, Oct 16, 2010 at 8:51 PM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
[quote] I just ran across this item on Ebay:
laptops.
Bob . . . | Quote: |
ist" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
tp://forums.matronics.com
jdubner(at)yahoo.com Guest
Posted: Sat Oct 16, 2010 6:52 pm Post subject: Laptop supply for your car/airplane |
Sounds like it might even /be/ HF gear
That single-sided PCB with minimal filtering (judging only by the
pictures -- see http://tinyurl.com/2943gjk) probably radiates switching
transient energy through VHF and beyond.
Of course if used with a laptop PC as per Bob's original suggestion,
this point may be mute because the laptop has it's own issues. But I'd
be leery about using it around receiving equipment in an aircraft (or
elsewhere).
My $.02 -- YMMV.
Joe
Independence, OR
http://www.mail2600.com/position
http://www.mail2600.com/cgi-bin/webcam.cgi
Bill Boyd wrote:
| Quote: | Sounds like it may be useful for powering portable HF gear (the common 10
-Bill Boyd
> * http://tinyurl.com/2cyx7c7*
> laptops.
> Bob . . .
Posted: Sat Oct 16, 2010 7:25 pm Post subject: Laptop supply for your car/airplane |
Looks to be in a metal enclosure, though.
On Sat, Oct 16, 2010 at 10:49 PM, Joe Dubner <jdubner(at)yahoo.com (jdubner(at)yahoo.com)> wrote:
[quote] --> AeroElectric-List message posted by: Joe Dubner <jdubner(at)yahoo.com (jdubner(at)yahoo.com)>
That single-sided PCB with minimal filtering (judging only by the pictures -- see http://tinyurl.com/2943gjk) probably radiates switching transient energy through VHF and beyond.
Of course if used with a laptop PC as per Bob's original suggestion, this point may be mute because the laptop has it's own issues. But I'd be leery about using it around receiving equipment in an aircraft (or elsewhere).
My $.02 -- YMMV.
Joe
Independence, OR
-Bill Boyd
| Quote: | I just ran across this item on Ebay:
* [url=http://tinyurl.com/2cyx7c7*]http://tinyurl.com/2cyx7c7*[/url]
laptops.
http://forums.matronics.com
le, List Admin.
Posted: Sun Oct 17, 2010 5:12 am Post subject: Re: Laptop supply for your car/airplane |
Thanks for that link Bob. Now what we need is a source for the DC plug to fit into the laptop. Right now I use a 12vdc to 120vac inverter along with the laptop power brick. The disadvantage of that is having to carry around two inefficient boxes instead of one.
Joe
_________________ Joe Gores |
Eric M. Jones
Joined: 10 Jan 2006 Posts: 565 Location: Massachusetts
Posted: Sun Oct 17, 2010 5:17 am Post subject: Re: Laptop supply for your car/airplane |
Remember that anything using a hard drive depends on a little cushion of air between the read-write head and the disk. Using a HD above 10,000 feet cabin pressure is risky.
Apple, Maxtor and Seagate state 10,000 feet as the maximum operating altitude. Don't forget those IPods.
_________________ Eric M. Jones
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net |
email(at)jaredyates.com Guest
Posted: Sun Oct 17, 2010 5:47 am Post subject: Laptop supply for your car/airplane |
Fortunately many of the ipods have gone to flash memory I do believe. This is also the case for some of the smaller laptops.
Posted: Sun Oct 17, 2010 5:53 am Post subject: Laptop supply for your car/airplane |
I use an Igo power adapter that replaces the oem notebook supply. It can work off of regular ac, sae 12v jack, and even tha special plug on some of the airliners. It also can power two other devices (cell phones etc) from the same one input. The tips are interchangeable, so you can use the same supply for multiple computer types, one at a time of course. I travel extensively and have used the Igo in all sorts of interesting situations, and the whole package isn't much larger than my OEM adapter was in the first place.
On Oct 17, 2010, at 9:12, "user9253" <fran4sew(at)banyanol.com> wrote:
Joe
Joe Gores
http://forums.matronics.com/viewtopic.php?p=316026#316026
N20DG
Joined: 02 Jan 2008 Posts: 61 Location: lancaster, texas
Posted: Sun Oct 17, 2010 6:14 am Post subject: Laptop supply for your car/airplane |
Try E-Bay there are some power supply's that have universal connection and the price is right for scavenging whatever you need
Try this link to see one. I use this one with my laptop in the car
http://cgi.ebay.com/UNIVERSAL-Power-Supply-AC-DC-Adapter-ACER-HP-Laptop-/160350558034?pt=Laptop_Adapters_Chargers&hash=item2555a35752
Looks like you might have to copy&paste it
Dick
In a message dated 10/17/2010 8:18:01 A.M. Central Daylight Time, fran4sew(at)banyanol.com writes:
| Quote: | --> AeroElectric-List message posted by: "user9253" <fran4sew(at)banyanol.com>
Joe
Joe Gores
http://forums.matronics.com/viewtopic.php?p=316026#316026===============================================
_-= = Use utilities Day ================================================ - MATRONICS WEB FORUMS ================================================ - List Contribution Web Site sp; ===================================================
Posted: Sun Oct 17, 2010 7:30 am Post subject: Laptop supply for your car/airplane |
At 10:22 PM 10/16/2010, you wrote:
| Quote: | Looks to be in a metal enclosure, though.
--> AeroElectric-List message posted by: Joe Dubner <jdubner(at)yahoo.com (jdubner(at)yahoo.com) > |
Hmmm . . . I thought I tiny-url'd the link to the
top address for the Ebay offering. Here's the
corrected link plus a couple others . . .
http://tinyurl.com/2wftqo9
http://tinyurl.com/2w22toe
http://tinyurl.com/33grzmg
Some of these are listed as fixed 24 volt output
but can certainly be 'jeeped' to lower their output
setpoint.
Astute observations. It's a pretty straightforward
experiment to survey for potential interference
problems . . . also not a big job to add enclosure
and line filtering should they prove necessary.
My suggestions about using the laptop were driven
more by the idea of using the computer for data
acquisition as opposed to in-flight entertainment
or generation of work product. Of course, altitude
limits conducive to hard drive functionality would
have to be observed. I'll order one of these puppies
with the idea of a permanent installation in my
travel vehicle.
Float Flyr
Posted: Sun Oct 17, 2010 7:46 pm Post subject: Laptop supply for your car/airplane |
There are a few netbooks out there that don't have hard drives... might be
an idea.
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
jimw_btg(at)earthlink.net Guest
Posted: Mon Oct 18, 2010 5:55 am Post subject: Laptop supply for your car/airplane |
Correct Noel,
There are several that are available with SSD eliminate the problem of the
HD at altitude, and from bouncing but we don't do that do we!!!!
Jim Wickert
Tel 920-467-0219
Cell 920-912-1014
pwmac(at)sisna.com Guest
Posted: Mon Oct 18, 2010 6:50 am Post subject: Laptop supply for your car/airplane |
Probably be a good idea to check the power consumption of the laptop.
Mine with a 17" screen draws 185 to 195 watts when used with an
inverter in my truck. More power is required for the dual hard drives
Paul
scott(at)n696js.com Guest
Posted: Tue Oct 19, 2010 10:14 am Post subject: Laptop supply for your car/airplane |
Actually hard drives are sealed units (air-tight). They are built in clean
rooms to exacting standards. The only thing that altitude will do is change
the air pressure outside causing strain on casing of the hard drive.
I have completely recovered data off of hard drives that were completely
immersed in floodwaters. Once a roof collapsed and flooded a data center -
the hard drives were removed from the servers, dried out, placed in fresh
servers, and spun right up.
Scott R. Shook
RV-7A (Building)
N696JS (Reserved)
Posted: Tue Oct 19, 2010 11:03 am Post subject: Laptop supply for your car/airplane |
At 01:10 PM 10/19/2010, you wrote:
--> AeroElectric-List message posted by: "Scott R. Shook" <scott(at)n696js.com>
Hmmmm . . . I can see that a drive might be liquid tight
for low pressure heads but they're not well 'sealed'
[img]cid:.0[/img]
Looking at the spacing between cover screws that hold
a thin sheet metal cover down against a gasket does not
suggest any ability to keep the drive interior from
exhausting at altitude. I've had one experience with
a data gathering task where I put my laptop in
the tail of a Beechjet. The intent was to stay below
10K feet. I had other equipment in the passenger
cabin too. During the flight, it was determined
that we needed to go up in altitude. Putting a
new hard drive in my laptop was a whole lot cheaper
than the cost of fuel and $time$ to land and
recover the un-protected computer.
After the flight, the hard drive was trashed
and could not be recovered. I seem to recall
foam-plugged vent holes in hard drives that
I've taken apart . . . but examination of
the WD and Maxtors laying around right now
failed to find one without tearing it apart.
This teardown article speaks to an on-purpose
hard drive vent.
http://www.pcdoctor-guide.com/wordpress/?p=595
63.51 KB |
13546 Time(s) |
Tim Olson
Posted: Tue Oct 19, 2010 11:17 am Post subject: Laptop supply for your car/airplane |
Definitely not true. They aren't sealed 100%, they have vents,
and over 10K' definitely does kill them. I had a couple
that wouldn't operate at 13K' one day. Switched to
SSD's because that's what you need over 10K. Yes,
sometimes it'll be fine, but sometimes it won't. And it
CAN damage the drive because the heads need to float on a
cushion of air, and even if it works, the cushion will
be less at altitude.
Air permeates the vents, even if water stays out
reasonably well.
Tim
Scott R. Shook
RV-7A (Building)
N696JS (Reserved)
longg(at)pjm.com Guest
Posted: Tue Oct 19, 2010 11:41 am Post subject: Laptop supply for your car/airplane |
I understand solid state drives do not suffer the same demise. Where I
live on the east coast 10k in light airplanes is a bit like going to the
moon, so not really a factor over here. Take a good backup before you
leave.
Glenn E. Long
