fuel valve with position both
Goto page 1, 2  Next
glastar(at)gmx.net
PostPosted: Thu Oct 14, 2010 12:36 pm    Post subject: fuel valve with position both Reply with quote
I might open Pandoras box here but it's not about primer so lets try:
On my high wing Glastar I have a left/both/right fuel valve and it is
used most of the time in the both mode, except when on the ground
(crossfeed risk) or on low fuel situations.
Now on low wing airplanes I see the left/right only, what is the reason
for it (I guess there must be a technical reason behind that)?
ok I get my firesuite out before I get the flames
Werner
pitts_pilot(at)bellsouth.
PostPosted: Thu Oct 14, 2010 12:48 pm    Post subject: fuel valve with position both Reply with quote
No flames. Actually, it's a good question.
On the high wing, the valve is always under positive fuel pressure (in
any attitude but inverted .... Wink ) due to the head .... 5' maybe?
On the low wing, it would be possible to unport one tank feed ..... and
suck air.
Linn
reason for it (I guess there must be a technical reason behind that)?
Werner
bruce1hwjohnson(at)yahoo.
PostPosted: Thu Oct 14, 2010 12:57 pm    Post subject: fuel valve with position both Reply with quote
IM not sure why, but I miss that option.
Sent: Thu, October 14, 2010 1:32:34 PM
Subject: fuel valve with position both
--> RV10-List message posted by: Werner Schneider <glastar(at)gmx.net (glastar(at)gmx.net)>
On my high wing Glastar I have a left/both/right fuel valve and it is used most of the time in the both mode, except when on the ground (crossfeed risk) or on low fuel situations.
Now on low wing airplanes I see the left/right only, what is the reason for it (I guess there must be a technical reason behind that)?
ok I get my firesuite out before I nbsp; &nbs===================
glastar(at)gmx.net
PostPosted: Fri Oct 15, 2010 3:35 am    Post subject: fuel valve with position both Reply with quote
Thanks Linn,
I agree, on a high wing the fuel pressure is higher, but on a low wing
you still pressurize the tanks as well so you should be fine? Unporting
would only be possible on a very low fuel level or uncoordinated flight
I plan to add low fuel warnings as well (have them in my Star as we have
a SB concerning the same problem).
Will see if we get deeper into that "why".
Cheers Werner
Glastar HB-YKP flying
RV-10 #41122 waiting for shipping
suck air.
Linn
> Werner
PostPosted: Fri Oct 15, 2010 3:47 am    Post subject: fuel valve with position both Reply with quote
On 10/15/2010 7:31 AM, Werner Schneider wrote:
Thanks Linn,
Unporting would only be possible on a very low fuel level or
have a SB concerning the same problem).
Well, you already did!!
I'm not sure how much 'usable fuel' you will get ...... the valve is
mounted at the top of the tunnel ..... run that station out to the wing
tank and see how much fuel you leave in the tank. Better to just take a
pass on the 'both' valve.
Linn
Cheers Werner
> <pitts_pilot(at)bellsouth.net>
> suck air.
> Linn
>> Werner
glastar(at)gmx.net
PostPosted: Fri Oct 15, 2010 4:40 am    Post subject: fuel valve with position both Reply with quote
Hello Linn,
no, my valve will be on the bottom of the tunnel (Andair Valve with
extension) and I have still the head pressure of the tank vents.
As I have still time until I'm there I will do a bit of geometry to see
where I end.
Werner
> Thanks Linn,
Linn
> Cheers Werner
>> suck air.
>> Linn
>>> Werner
kevino
PostPosted: Fri Oct 15, 2010 5:26 am    Post subject: Re: fuel valve with position both Reply with quote
I have some experience on this topic. During phase 1 testing on my 10 i ran a tank dry over airport and had an engine failure. Was unable to get other tank on line due to air in system. Dead stick landing. no issues. discovered that the vans fuel valve which was left, right and aux was allowing the good tank to still draw air due to being slighty out of the detent position. lousy detent on vans valves. replaced valve with andair. no further issues. not a fan of cheap valves on low wing airplanes. you cannot use a valve with both on low wing.
Kevin
dave.saylor.aircrafters(a
PostPosted: Fri Oct 15, 2010 6:15 am    Post subject: fuel valve with position both Reply with quote
Werner,
The head pressure from your Glastar tanks is many times the pressure
from the fuel vent. If it weren't, high-wings on "Both" would be
running out of gas all the time.
Head pressure tries to push fuel back into the empty tank, against
vent pressure. That works in a high-wing because you have a couple
feet of rise. In a low-wing airplane there isn't enough pressure
difference between an empty tank and a partially-full tank to favor
the fuller tank. The pump pulls from the path of least resistance,
which is the air in the empty tank. Lots of people have tried a
"Both"position in RVs and other low wings. It doesn't work out.
You'll build a safer plane if you stick with Left-Right-Off. I didn't
have much low-wing time before my 10 and while it is something else to
do, switching back and forth isn't that big a deal. Plus it really
keeps you cognizant of your fuel situation.
Dave Saylor
AirCrafters
140 Aviation Way
Watsonville, CA 95076
831-722-9141 Shop
831-750-0284 Cell
On Fri, Oct 15, 2010 at 5:36 AM, Werner Schneider <glastar(at)gmx.net> wrote:
Hello Linn,
where I end.
Werner
>> Thanks Linn,
> Linn
>> Cheers Werner
>>> suck air.
>>> Linn
>>>> Werner
Tim Olson
PostPosted: Fri Oct 15, 2010 7:50 am    Post subject: fuel valve with position both Reply with quote
Also, a side "benefit" to the low wing's limitation against "both" position is that it reinforces better fuel management practices....and allows you to always know the remaining fuel.
Anybody notice that the rv-10's with presumably nearly 100% equipage of fuel computers and flow meters, has basically never had an off-airport landing (that we know of) due to poor fuel planning? Let's keep it that way....we have the tools, if we use them.
Tim
On Oct 15, 2010, at 4:31 AM, Werner Schneider <glastar(at)gmx.net> wrote:
Thanks Linn,
I agree, on a high wing the fuel pressure is higher, but on a low wing you still pressurize the tanks as well so you should be fine? Unporting would only be possible on a very low fuel level or uncoordinated flight
I plan to add low fuel warnings as well (have them in my Star as we have a SB concerning the same problem).
Cheers Werner
> suck air.
> Linn
>> Werner
stein(at)steinair.com
PostPosted: Fri Oct 15, 2010 8:34 am    Post subject: fuel valve with position both Reply with quote
It is possible to have a "both" fuel system, but in low wing planes as
others have said it's difficult because the fuel is at/near/below the
engine. While at rest gravity would naturally keep the tank levels
balanced, in the air it's a different story. It's not just about the tanks
being pressurized/vented, but for a "both" selection they need to be
pressurized equally. You'll notice that in most high wing airplanes with a
both selection, the vents of the two tanks are tied together...in a low wing
plane if you didn't have the two tank vents tied together, then one tank
will likely have a slightly higher pressure than the other...which mean fuel
will be routed from that particular tank and possibly run empty before
sucking gas out of the other tank; and you could have an engine sucking air
with one wing tank being completely full. It could also cause fuel from one
tank to be routed to the other and then overboard. Even though the tanks
are vented and "pressurized", it's likely not enough to cause sufficient
fuel flow to the engine without and electric or fuel driven pump (which you
can get by without on many high wing planes). Remember, we're as much
"sucking" the fuel from the tanks as we are pushing when the level of the
tanks is below the engine.
Anyway, There are ways to do it but none as simple as just doing it the way
Van's says. There have been various people who've re-invented the wheel on
van's fuel system, but out of the 7000+ flying RV's, the standard way of
doing it has been proven as reliable and functional.
My 2 cents as usual!
Stein
kevino
PostPosted: Fri Oct 15, 2010 9:35 am    Post subject: Re: fuel valve with position both Reply with quote
One other point. I dont have it with me but believe the manual on the air flow performance fuel pump has a specific warning on introducing air into the system could cause an air lock.
Kevin
pilotmelch(at)omnav.com
PostPosted: Fri Oct 15, 2010 10:07 am    Post subject: fuel valve with position both Reply with quote
This can be simply explained with an analogy.
Picture yourself with two glasses of beer above your head, with a tube
coming out the bottom of both running to a Y and a single tube then running
into your mouth. Once you start sucking a little, you'd get some beer, and
wouldn't need to suck much more after that (or at all). Essentially both
glasses are gravity feeding the single tube, and until they both run empty
you'll get a constant flow of beer.
Now do the same thing, but put the glasses down to your knees. Nothing is
automatically filling the single tube after the Y. In fact, gravity will
attempt to equalize the amount in each glass so their levels remain the
same, but gravity can't fill the tube running up to your mouth higher than
the top level in the glasses down at your knees. You must suck, and
continue to do so to get beer. The further from your mouth, the harder
you'll need to suck. If you get ahead of gravity's ability to even the
glasses, and you empty one of them ahead of the other, your required sucking
will suck air (likely a mix of mostly air and some beer). Either way, your
required constant flow of beer has been interrupted and that's bad.
John Melchert
N316PT RV-10 (building, QB fuse)
Eden Prairie, MN
robin(at)PaintTheWeb.com
PostPosted: Fri Oct 15, 2010 10:25 am    Post subject: fuel valve with position both Reply with quote
I am grabbing 4 beers and trying this now!
Burp,
PostPosted: Fri Oct 15, 2010 12:17 pm    Post subject: fuel valve with position both Reply with quote
required constant flow of beer has been interrupted<<
And I thought running out of gas was bad...that's just unthinkable.
Dave Saylor
AirCrafters
140 Aviation Way
831-722-9141 Shop
831-750-0284 Cell
On Fri, Oct 15, 2010 at 11:04 AM, John Melchert <pilotmelch(at)omnav.com> wrote:
John Melchert
Eden Prairie, MN
rv10(at)colohan.com
PostPosted: Fri Oct 15, 2010 12:39 pm    Post subject: fuel valve with position both Reply with quote
I've not played with the combination of beer and hoses since college -- but in my experience, when you run beer through a funnel and tube, you can get all sorts of vapor lock problems with excessive foaming, no matter if you use gravity or suck it uphill.
Perhaps you can avoid these problems by only using fuel that doesn't contain alcohol?  Smile
Chris
On Fri, Oct 15, 2010 at 11:04 AM, John Melchert <pilotmelch(at)omnav.com (pilotmelch(at)omnav.com)> wrote:
[quote]--> RV10-List message posted by: "John Melchert" <pilotmelch(at)omnav.com (pilotmelch(at)omnav.com)>
John Melchert
Eden Prairie, MN
http://forums.matronics.com
le, List Admin.
glastar(at)gmx.net
PostPosted: Fri Oct 15, 2010 1:02 pm    Post subject: fuel valve with position both Reply with quote
Many thanks for the many and valuable comments.
A both position would work, if each tank would have a single fuel pump
before the fuel valve in the cases described, this would grant a fuel
flow secured after unporting and switching valve.
I agree left right demands a constant fuel management (which puts more
load in difficult situation) but makes a bigger awareness of fuel remaining.
A lot of fuel (or beer) for thoughts and good technical arguments.
Thanks again to the group for filling that gap of my missing knowledge.
I probably will go the Andair fuel pump way as it looks to be the better
technology with much less connections then the ES Airflow one.
br
Werner
Stein
PostPosted: Fri Oct 15, 2010 1:26 pm    Post subject: fuel valve with position both Reply with quote
You're welcome. It's why we're here.
I see what you mean. Having a pump (actually two) in the wing root at
the lowest point would solve the problem that didn't exist before the
'both' position was selected. However, now we've added two pumps
(weight), wire (weight) and switches (more weight) to solve a problem
that really shouldn't exist.
remaining.
As I see it, switching tanks every 15 minutes to 1/2 hour is a whole lot
safer than turning on the pumps. However, if you'll forget to switch
tanks ...... maybe the switches will end up in the same category. From
experience, I can tell you that running a tank dry on takeoff (doing
T&Gs) in the pattern will get your attention. That was when I was a
baby pilot. Another educational experience.
I noticed that there are a lot of beer experts on this list. Very Happy
If we really did.
better technology with much less connections then the ES Airflow one.
Not sure what that means. Razz
Best of luck.
Linn
br
Werner
> tanks
> with a
> low wing
> mean fuel
> sucking air
> from one
> tanks
> (which you
> the
> the way
> wheel on
> Cheers,
> Stein
Jim Combs
PostPosted: Tue Oct 19, 2010 3:50 pm    Post subject: fuel valve with position both Reply with quote
Here is my solution to the "hard to feel detent" on the Vans fuel selector.  I made two stops using tubing and countersunk screws.  Now the fuel is easily positioned from one fuel tank to the other even in the dark.
Jim Combs - N312F
 Filesize:  116.12 KB
 Viewed:  14942 Time(s)
RV-10 -> N312F - Flying as of 12/2008
Bob Turner
PostPosted: Tue Oct 19, 2010 5:26 pm    Post subject: Re: fuel valve with position both Reply with quote
If the fuel line ruptures up in the engine area, how do you turn the fuel off? Try to feel between the detents?
As many do not know, starting about 2 and a half years ago, Vans began sending a different fuel valve arrangement out with kits. There is now a spring loaded, lift-to-turn, handle with positive detents. IMHO it also looks a whole lot nicer than the old handle.
Bob Turner
RV-10 QB
speckter(at)comcast.net
PostPosted: Wed Oct 20, 2010 4:53 am    Post subject: fuel valve with position both Reply with quote
Jim, how do you turn off the fuel in an emergency?
Gary Specketer
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jim Combs
Sent: Tuesday, October 19, 2010 7:47 PM
Subject: Re: Re: fuel valve with position both
Jim Combs - N312F
Goto page 1, 2  Next
Page 1 of 2
