David X
Joined: 10 Jan 2006 Posts: 154 Location: Princeton, NJ, USA
Posted: Tue Jan 10, 2006 9:38 pm Post subject: Constant torque hose clamps |
I have a Rotax 912 engine in my 601XL. One of the oil hoses will leak where it connects to the oil cooler. It's a relatively new hose. I've retightened the clamp several times, but it will leak again after a few cross country trips. I've even replaced the clamp with a wider, stainless steel clamp with an internal sleeve.
I think it's a case of differential thermal expansion - the rubber hose and the stainless steel clamp don't expand equally - which deforms the hose over time ("cold flow").
I was thinking of trying a Breeze constant torque clamp (http://www.breezeclamps.com/ct.htm) and tightening it to about 40 inch pounds.
Has anyone else run into this sort of problem with hoses and was it solved using a spring clamp?
| - The Matronics Zenith-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
_________________ Zodiac 601 XL - CZAW Built - Rotax 912S
DO NOT ARCHIVE |
Bill(at)flyinmiata.com Guest
Posted: Tue Jan 10, 2006 10:09 pm Post subject: Constant torque hose clamps |
We use the breeze clamps in our turbo kits with good success. Probably
the ultimate in self adjustment would be spring clamps like the
factories use on modern cars. Can be a pain to deal with, but work very
well.
TurboDog's Dad
Bill Cardell
www.flyinmiata.com
1-800-FLY-MX5S
970-242-3800
Subject: Constant torque hose clamps
pounds.
