Dick Maddux
Posted: Fri May 06, 2011 4:33 am Post subject: Coffee holder |
I love coffee and was getting tired of balancing a large cup of coffee between my legs when going to early morning smooth air get together's so I came up with this idea after seeing a coffee holder in a Valor.
It is a folding drink holder attached with a screw to the bungee mount. I tapped the hole and it fits perfectly with no control interference. I have included a couple of pictures. That seat has been removed. The holder is to the left of the passenger stick.
I no longer have bungee's as I installed the "bush gear"so the former bungee mount worked well.
So, if you love coffee as much as I do,this gives you an idea (OK you can quit laughing now )
Dick Maddux
Fox 4
Milton,Fl
306.77 KB |
3740 Time(s) |
373.39 KB |
3740 Time(s) |
lcfitt(at)sbcglobal.net Guest
Posted: Fri May 06, 2011 7:35 am Post subject: Coffee holder |
Dick,
Great idea. I like the folding function.
Is your airplane always this neat and tidy? Looks better then brand new.
Lowell
Sent: Friday, May 06, 2011 5:17 AM
To: kitfox-list(at)matronics.com (kitfox-list(at)matronics.com)
Subject: Coffee holder
Dick Maddux
Fox 4
Milton,Fl
Pat Reilly
Posted: Fri May 06, 2011 2:48 pm Post subject: Coffee holder |
Dick, Did you apply for a patent yet? If you didn't, I'll bet McBean will have it on the next plane kit out. I would imagine something that inovative would triple his sales.
Pat Reilly
On Fri, May 6, 2011 at 7:17 AM, <Catz631(at)aol.com (Catz631(at)aol.com)> wrote:
| Quote: | I love coffee and was getting tired of balancing a large cup of coffee between my legs when going to early morning smooth air get together's so I came up with this idea after seeing a coffee holder in a Valor.
Dick Maddux
Fox 4
Milton,Fl
Pat Reilly
Mod 3 582 Rebuild
Rockford,IL
jdmcbean(at)kitfoxaircraf Guest
Posted: Fri May 06, 2011 5:00 pm Post subject: Coffee holder |
Actually would have to give the credit to Steve Kellender.. This was installed on his aircraft about 7 years ago.
Fly Safe !!
John McBean
Ph 208.337.5111
www.kitfoxaircraft.com
"The Sky is not the Limit... It's a Playground"
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Patrick Reilly
Sent: Friday, May 06, 2011 4:46 PM
Subject: Re: Coffee holder
Pat Reilly
Dick Maddux
Fox 4
Milton,Fl
Pat Reilly
Mod 3 582 Rebuild
Rockford,IL | Quote: | | http://www.matronics.com/Navigator?Kitfox-List | 01234567
70.17 KB |
3712 Time(s) |
65.86 KB |
3712 Time(s) |
