Plane Power Alt.
trumanst(at)neitel.net
PostPosted: Tue Oct 05, 2010 2:21 pm    Post subject: Plane Power Alt. Reply with quote
Bob,
I bought a Plane Power alternator and want to install it on my Tri Q 200. I have the crowbar over voltage module, wired as per your recommendations. I will be replacing a ND IR atl. for various reasons. The Plane Power is also IR. Can I just hook the field wire to the same wire I have for the field wire on the old unit. Their instructions lead me to believe it to be that simple. I have a 5A circuit breaker in the current system, and that is what they call out. Am I missing something?
Thanks for all you do,
Kevin Boddicker
TriQ 200 N7868B 190 hrs
Luana, IA.
PostPosted: Tue Oct 05, 2010 7:21 pm    Post subject: Plane Power Alt. Reply with quote
At 05:17 PM 10/5/2010, you wrote:
Bob,
Last time I looked at the PP alternators, they
had crowbar ov protection built in . . . See:
http://plane-power.com/images/AL12_EI60%20Installation.pdf
are you using something different that does not
feature built in protection?
PostPosted: Wed Oct 06, 2010 4:53 am    Post subject: Plane Power Alt. Reply with quote
Yes,
I am using the basic Z-11, with a B&C over voltage/under voltage module wired to trip a 5A breaker. In case of an OV event the contactor in the B lead would open. Essentially I would have two OV systems. Both triggered by a 5A breaker. Is there any harm or potential harm in this?
Kevin
Bob,
PostPosted: Wed Oct 06, 2010 7:34 am    Post subject: Plane Power Alt. Reply with quote
At 07:50 AM 10/6/2010, you wrote:
Yes,
OV systems.
Why two ov systems?
No harm . . . but the rationale is mystifying.
PostPosted: Wed Oct 06, 2010 2:49 pm    Post subject: Plane Power Alt. Reply with quote
On Oct 6, 2010, at 10:32 AM, Robert L. Nuckolls, III wrote:
--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
--> AeroElectric-List message posted by: Kevin Boddicker <trumanst(at)neitel.net (trumanst(at)neitel.net)>
Yes,
Why two ov systems?
There is one built into my plane as it sits, using the module that I bought from B&C BC207-1 and AEC9034-1,
And there is one built into the new plane power alt. I have the module that will open the 5A breaker if there is an OV event with my current ND alt. The module is also used to test an OV event, and indicates low voltage.
Are you saying I should disconnect the OVM I got from B&C and just use the OV protection built into the Plane Power alt.
I don't know if I should remove the OVM I got from B&C, or leave it in place. If I leave it in place, I would have two sensors.
The OVM from B&C and what ever Plane Power uses. I will attach a pic of the OVM. Hope it gets through.
Kevin
[img]cid:9D18C803-9ED9-4C08-A474-71021EE65435[/img]
Bob . . . - The --> http://www.m &n -   &nbs --> http://www.matronics.com/co=================
 Filesize:  51.84 KB
 Viewed:  5193 Time(s)
PostPosted: Wed Oct 06, 2010 7:02 pm    Post subject: Plane Power Alt. Reply with quote
Yes,
Okay, since the PlanePower product is self contained
and features ov protection I recommend you remove the
previously installed system. I.e., install the PP
alternator per manufacturer's instructions.
bought from B&C BC207-1/AEC9034-1,
The BC207/AEC9034 is a simple OV/LV annunciator and has
no protective features. It was designed for very
small PM alternator/battery systems common to
the 2-cycle powered ultralights. In your case,
the OV warning would NEVER be expected to
operate because the ov protection system would
shut the system down so fast that you'll never
see an OV indication . . . only an LV indication
after the alternator is shut down.
That's the legacy crowbar ov protection module
produced first by AEC, then by B&C and now by
both companies. Yes, take that unit out along
with the associated b-lead contactor.
PostPosted: Thu Oct 07, 2010 4:38 am    Post subject: Plane Power Alt. Reply with quote
Bob,
You are a good teacher! That is exactly what I thought I should do, just looking for verification.
Again thanks a million for all you do and the help you offer to everyone. I am certain many others feel the same way.
Kevin Boddicker
TriQ 200 N7868B 190hrs
Luana, IA.
On Oct 6, 2010, at 9:59 PM, Robert L. Nuckolls, III wrote:
Yes,
There is one built into my plane as it sits, using the module that I bought from B&C BC207-1/AEC9034-1,
PostPosted: Thu Oct 07, 2010 7:07 am    Post subject: Plane Power Alt. Reply with quote
At 07:35 AM 10/7/2010, you wrote:
Bob,
I'm pleased that you find the service useful!
