awcbs
Joined: 28 Sep 2010 Posts: 20 Location: kittanning, PA
Posted: Mon Oct 04, 2010 11:51 am Post subject: tail boom question |
after inspecting the pieces of the mark 3 extra kit I just purchased, It looks like the previous owner fitted the rudder and stabilizer on one end. then must of figured something wasn't right and took it off and fitted to the other end. so there are rivet holes it the end of the tube that attaches to the fuse. does any one see a problem with using the tube? any structural issues, not to worried about cosmetics as it looks like all the holes will be inside the cage. some have rivets put back in the holes
Posted: Mon Oct 04, 2010 12:05 pm Post subject: tail boom question |
Could it be that the holes were drilled for the forward attachment, and then dis-assembled so that the cage could be painted? Can you post photos?
Bill Sullivan
Windsor Locks, Ct
FS 447
awcbs
Posted: Mon Oct 04, 2010 6:22 pm Post subject: Re: tail boom question |
I'll take a few pics tomorrow, but the holes are in the same spot on both ends of the tube , and the number of holes match the other end with the tail on it.
Also it is a mark 3 Xtra, not extra, as I seem to have offended at least one member, and I figured out how to attach a signature to my messages.
Please bear with me as I go through the newbie stages, I will try to look like an expert by tomorrow. Wait that won't work, looks like I'm gonna be a newbie for a while yet, sorry.
hope my signature attaches
_________________ AJ Waldor
MK3C 503
Phantom 503
Rans S-9 Chaos 503 |
by0ung(at)brigham.net Guest
Posted: Tue Oct 05, 2010 4:45 pm Post subject: tail boom question |
how far are the holes from the end of the tube.... if they are within 1 inch of the end.... cut it off and drill new holes for the mounting ring to the cage.
does he have the hols drilled for the H section???? any extra holes in the area of the H section would be of greater concern to me.... i dont remember drilling any holes in the boom tube till i was ready to rig everything to the cage.
hope this helps
boyd young mkIII
do not archive.
awcbs
Posted: Tue Oct 05, 2010 6:26 pm Post subject: Re: tail boom question |
they are above the H-brace position, but definitely on top of the front of the H-brace.
194.27 KB |
8261 Time(s) |
191.37 KB |
8261 Time(s) |
184.51 KB |
8261 Time(s) |
228.64 KB |
8261 Time(s) |
228.64 KB |
8261 Time(s) |
MK3C 503
Phantom 503
awcbs
Posted: Tue Oct 05, 2010 6:32 pm Post subject: Re: tail boom question |
date on camera is wrong, but pic with the H-brace on top is approx. where it will sit inside the boom. the magic marker cross is aproxx. where the H=brace bolts go thru. thanks AJ
MK3C 503
Phantom 503
WhiskeyVictor36(at)aol.co Guest
Posted: Tue Oct 05, 2010 6:41 pm Post subject: tail boom question |
AJ,
It looks like they might have been the holes for the forward attachment of the vertical and horizontal stabilizers. Maybe the tail was out of plumb so he swapped ends to try again?
Bill Varnes
Original Kolb FireStar
Audubon NJ
In a message dated 10/5/2010 10:29:08 P.M. Eastern Daylight Time, awcbsone(at)windstream.net writes:
| Quote: | they are above the H-brace position, but definitely on top of the front of the H-brace.
