Sealant for header tank fittings
Goto page 1, 2  Next
kitfoxsport(at)verizon.ne
PostPosted: Mon Sep 27, 2010 12:59 pm    Post subject: Sealant for header tank fittings Reply with quote
I thought I had a good sealer for the header tank plastic to fittings, BUT as you can see from the attached photo. The tank has only been in use 3 months. Any idea on the best stuff to use
George
Kitfox Sport almost, but not yet!
 Filesize:  91.21 KB
 Viewed:  35195 Time(s)
larry huntley
PostPosted: Mon Sep 27, 2010 1:35 pm    Post subject: Sealant for header tank fittings Reply with quote
Proseal? Larry
Larry Huntley,Dundee,NY
Kitfox 4-1200 N234EE
EA81,AMAX Redrive Warp 3 blade
Vic Baker
PostPosted: Mon Sep 27, 2010 1:37 pm    Post subject: Sealant for header tank fittings Reply with quote
Yikes! John Mcbean can point you in the right direction. Used the sealant that came with my kit (2004 vintage) with success. Better check those fuel tank fittings also.
Vic Baker
S7 912S Warp
Carson City, Nv
Vic Baker
Series 7
Carson City, Nevada
Pat Reilly
PostPosted: Mon Sep 27, 2010 1:56 pm    Post subject: Sealant for header tank fittings Reply with quote
George, The absolute best sealer for that application is Dow 730 Aircraft Spruce p/n: 09-00383. I finally broke down and bought a tube and haven't had a leak since. The only draw back is cost. It's over a $100 for a 3 oz tube with shipping. I keep it in the
refrigerator and hope it lasts. Someone on this list recommended it. I tried everything else 1st.
Pat Reilly
Mod 3 582 REBUILT again
Rockford, IL
On Mon, Sep 27, 2010 at 3:48 PM, Kitfox George <kitfoxsport(at)verizon.net (kitfoxsport(at)verizon.net)> wrote:
George
Pat Reilly
Mod 3 582 Rebuild
Rockford,IL
PostPosted: Tue Sep 28, 2010 1:54 pm    Post subject: Sealant for header tank fittings Reply with quote
Thanks for the great info!
George
Kitfox Sport, almost, but not yet!
Roger Lee
PostPosted: Tue Sep 28, 2010 8:33 pm    Post subject: Re: Sealant for header tank fittings Reply with quote
A very good product that some of the race car driver's use, auto mechanics, aviation mechanics and SLSA Mfg's is "Hylomar" Universal Blue gasket and joint sealing compound.
Use a film on the bulkhead plates,t gaskets or fittings all the way around and both sides. This stuff is very sticky so what ever you touch it is there until you use a little lacquer thinner to remove it. Let it flash or dry for a few minutes and assemble. Do not apply a glob as it will squish out and get into the fuel system and it will cause you headaches. A little is good, a lot is not better. You can buy this Hylomar on line from several sources as it is very common. I tube should be plenty.
I use this on all my leaks as recommended by a few Mfg's and have never had a repeat leak.
Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056
Guy Buchanan
PostPosted: Wed Sep 29, 2010 7:44 am    Post subject: Sealant for header tank fittings Reply with quote
George,
After trying a half dozen sealants with the accompanying aggravation I finally broke down and bought the Pro-seal from ACS. It's the only one that I could get to work with 100LL.
Guy Buchanan Normal Guy Buchanan 2 13 2010-09-24T17:53:00Z 2010-09-24T17:53:00Z 1 30 173 1 1 202 14.00 <![endif]--> false false false false EN-US X-NONE X-NONE <![endif]--> <![endif]--> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin-top:0in; mso-para-margin-right:0in; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0in; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;} <![endif]--> <![endif]--> <![endif]-->
Guy Buchanan Kitfox IV-1200 / 582-C / Warp-3cs / 500+ hrs.[url=www.troop680.org][/url]
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
mikeperkins
PostPosted: Wed Sep 29, 2010 8:17 am    Post subject: Re: Sealant for header tank fittings Reply with quote
I used the Dow 730 sealant years ago after it was recommended to me by an aircraft-builder friend who worked for Dow. I managed to get Aircraft Spruce to stock it. Though it's expensive, I have not had a fuel leak on anything I've used it on, including tank cover plates and square-port fuel gauges. I saw another friend put it on a tank fitting and then pour fuel into the tank immediately, no leak. It's always worked well. I've had my tube for 20 years - it's still in the frig and still just as good as new. I look at the price like a complete "gasket kit" for a lifetime of fuel systems. Sky Geek has it today for $78.
dave
PostPosted: Thu Sep 30, 2010 1:27 am    Post subject: Re: Sealant for header tank fittings Reply with quote
I use daily plumbers putty goo in a can from home depot.
$4 or 5$ a can -- good for gas,diesel and oils read the can.
Never had a leak but it has solved many in 35 year and Hundreds of planes.
DO NOT use Teflon tape!!
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube
Pat Reilly
PostPosted: Thu Sep 30, 2010 6:40 pm    Post subject: Sealant for header tank fittings Reply with quote
Mike, Thanks for that recommendation a few months ago. Dow 730 was the only sealant that didn't leak on my plastic header tank. I have mine in the refrigerator on your advice. Wish I'd known about Sky Geek. A/C was $20 more.
Pat Reilly
Mod 3 582 Reuilt
Rockford, IL
On Wed, Sep 29, 2010 at 11:17 AM, mikeperkins <michael.perkins(at)rauland.com (michael.perkins(at)rauland.com)> wrote:
--> Kitfox-List message posted by: "mikeperkins" <michael.perkins(at)rauland.com (michael.perkins(at)rauland.com)>
http://forums.matronics.com/viewtopic.php?p=314111#314111
www.matronics.com/Navigator?Kitfox-List" target="_blank">http://www.matronics.com/Navigator?Kitfox-List
Matt Dralle, List Admin.
Pat Reilly
Mod 3 582 Rebuild
Rockford,IL
dholly
PostPosted: Sat Oct 02, 2010 4:45 pm    Post subject: Re: Sealant for header tank fittings Reply with quote
If you were to pose this question directly to Kitfox today their answer would be Permatex 9AR Tack & Seal Gasket Sealant. Worked for me.
 Filesize:  50.95 KB
 Viewed:  35116 Time(s)
-Kitfox III 582 Blue/C Grove Spring / Aerocet 1100 Amphibs
-Airdale Avid+ (project) TD / W.I.B. Gear
mikeperkins
PostPosted: Sun Oct 03, 2010 9:25 am    Post subject: Re: Sealant for header tank fittings Reply with quote
The datasheet for Permatex 9AR says it is not to be selected as a sealant for strong oxidizing materials. Unfortunately, that's what ethanol is.
http://www.permatex.com/documents/tds/automotive/80938.pdf
- Mike
dholly
PostPosted: Sun Oct 03, 2010 8:52 pm    Post subject: Re: Sealant for header tank fittings Reply with quote
Hey Mike-
I'm no chemist but see the data sheet you linked says:
"Chemical / Solvent Resistance
The product retains effective properties in contact with automotive fluids, such as motor oil, transmission fluids, alcohol and antifreeze solutions."
...and the card pack guide also says:
"A high tack, pliable gasketing sealant and plastic and metal pipe fitting sealant. Resists gasoline, gasohol, kerosene, oils, lubricants, water, antifreeze, and mild acids. Designed to resist high temperatures, vibration, fuels and oils of today's engines."
So... what to think? In any event, recommended by Kitfox and leak free to date (knock wood) on my M-III panel and wing tank fittings.
mikeperkins
PostPosted: Mon Oct 04, 2010 4:14 am    Post subject: Re: Sealant for header tank fittings Reply with quote
What do I think? I think the Permatex folks might have inadvertently contradicted themselves a little bit. But Permatex stuff always seems to work for what they advertise on the package. So maybe you've found a good, inexpensive fuel thread sealant! Thanks for passing that along.
Over the years, I've run many tests on different things in gasoline-filled jars. Most recently I made some little cork balls for sight-gauge floats and painted them with a dark polyurethane paint. Glad I tested them. The paint was fine, but the cork swelled such that the balls would have stuck in the sight tubes; back to the drawing board.
Tommy Walker
PostPosted: Mon Oct 04, 2010 7:21 am    Post subject: Re: Sealant for header tank fittings Reply with quote
Has anyone used SeaLube or Fuel lube for the tank fittings?
I've used it before and never had a problem.
http://www.aircraftspruce.com/catalog/cspages/ezturnlube.php
Tommy Walker in Alabama
Tommy Walker
N25A - Anniston, AL
Don McIntosh
PostPosted: Mon Oct 04, 2010 7:22 am    Post subject: Re: Sealant for header tank fittings Reply with quote
I used the Permatex 9AR and I am having to redo all the fittings. One at a time they each let go. I am using Pro Seal and it works well. I do use 100 LL so it may make a difference.
Don McIntosh
Kitfox Series 7
Jabiru 3300
lcfitt(at)sbcglobal.net
PostPosted: Mon Oct 04, 2010 12:42 pm    Post subject: Sealant for header tank fittings Reply with quote
I have used Fuel Lube and still do for the plumbing fittings. I didn't have
the poly header tank, though. Mine was an aluminum tank that a builder had
made up for several of us as I was finishing my first project.
Lowell
Sent: Monday, October 04, 2010 8:21 AM
Subject: Re: Sealant for header tank fittings
Tommy Walker
N8701 - Anniston, AL
http://forums.matronics.com/viewtopic.php?p=314615#314615
dholly
PostPosted: Mon Oct 04, 2010 7:44 pm    Post subject: Re: Sealant for header tank fittings Reply with quote
That's interesting. Both you and Guy burn 100LL and the 9AR failed... I burn mogas and so far so good. Sure does make one wonder.
mikeperkins
PostPosted: Tue Oct 05, 2010 12:54 pm    Post subject: Re: Sealant for header tank fittings Reply with quote
If it's all the same to you guys, I think I'll keep using my Dow 730. Seventeen years and not a hint of a leak.
Vic Baker
PostPosted: Tue Oct 05, 2010 1:11 pm    Post subject: Sealant for header tank fittings Reply with quote
I'm with Mike on this one. Just ordered the Dow 730. A fuel leak is
unacceptable.
Vic Baker
S7 912S Warp
Carson City, Nv
Vic Baker
Series 7
Carson City, Nevada
Goto page 1, 2  Next
Page 1 of 2
