txpilot
Posted: Sat Sep 25, 2010 2:21 pm Post subject: Troubleshooting a Rotax generator |
I have a Zenith CH-701 with a Rotax 912ULS. My electrical system is based on the "Z-16" system diagram.
I'm getting set for my first flight when I noticed a generator failure. I've double-checked all of my wiring and verified no fuselinks have been blown. The alternator OV Disconnect relay is functioning fine. It seems it's down to a bad generator or a bad rectifier-regulator.
I'm wondering what's the best way to proceed with the troubleshooting. Could I connect a voltmeter to the generator cables and check for proper voltage? What would I expect for a functioning generator? (the installation manual indicates 250W AC output at full power). Any other suggestions on how to troubleshoot without replacing the generator?
Thanks for any help.
Dan Ginty
rickofudall
Posted: Sat Sep 25, 2010 5:30 pm Post subject: Troubleshooting a Rotax generator |
Dan, See the Rotax Heavy Maintenance Manual, Section 74-00-00, 3.7, page 16.
Rick Girard
On Sat, Sep 25, 2010 at 5:21 PM, txpilot <txpilot(at)consolidated.net (txpilot(at)consolidated.net)> wrote:
| Quote: | --> AeroElectric-List message posted by: "txpilot" <txpilot(at)consolidated.net (txpilot(at)consolidated.net)>
Dan Ginty
http://forums.matronics.com/viewtopic.php?p=313726#313726
le, List Admin.
Zulu Delta
Kolb Mk IIIC
582 Gray head
4.00 C gearbox
3 blade WD
Thanks, Homer GBYM
It is not bigotry to be certain we are right; but it is bigotry to be unable to imagine how we might possibly have gone wrong.
- G.K. Chesterton
Joined: 28 Mar 2008 Posts: 1961 Location: Riley TWP Michigan
Posted: Sun Sep 26, 2010 6:03 am Post subject: Re: Troubleshooting a Rotax generator |
Dan,
How did you notice a generator failure? Was the low voltage warning light on? Did you verify low voltage with a voltmeter? The low-voltage warning light could be lying.
My Rotax Heavy Maintenance Manual gives the resistance of the generator windings on page 64. With the master switch on and the engine off, remove the connector from the voltage regulator and check the resistance of the two generator yellow wires to ground. There should be infinite resistance to ground. Then measure the resistance between the two yellow generator wires. It should be less than one ohm. If more than one ohm, the relay contacts or generator winding is open.
If the resistance checks are normal, chances are that the generator is OK. You could also do an operational check. With the voltage regulator connector still unplugged, connect a voltmeter and a high wattage lamp to the two yellow generator wires and start the engine. The lamp should get brighter and the voltage should go up with RPM.
Joe
_________________ Joe Gores |
