DAquaNut(at)aol.com Guest
Posted: Mon May 01, 2006 6:44 pm Post subject: 4130 gear legs |
In a message dated 5/1/2006 9:20:46 A.M. Central Standard Time,
tkrolfe(at)usadatanet.net writes:
And while Im at it, for those of you exploring alternative gear legs,
listen to what John H. is
trying to tell you!! I followed his lead and made tempered 4130 gear
legs for my FireFly and
have forgotten about them since. Land in farm fields quite a bit here
in "Amish" country.
Terry - FireFly #95
Terry,
I have just a little over 10 hours and 60 landings, Several with bounces
and have not bent a leg yet. Maybe the fact that I use the 6" wheels at low
pressure helps absorb the shock. I built 3 prs of 4130 heat treated legs for
the Firefly per your drawings, but have not needed them ---yet. Those
aluminum legs seem to be pretty tough, but If I ever bend one I have plenty
replacement 4130 axles waiting for duty!
Ed Diebel Firefly # 62 ( anticipating Monument Valley)
