Speedy11(at)aol.com Guest
Posted: Wed Sep 15, 2010 5:07 pm Post subject: Gell Coat Painting |
Bill,
I'm no expert in this area. Here is some info I found on the net. It is referring to boats, but the concept would be the same.
Stan
Use a GOOD primer sealer that is compatible with your Mfg's paint and you should have no problem. I am assuming here that you are painting the entire hull and not just a section, like say a center stripe.
The initial sanding will scuff open the gelcoat allowing the primer sealer to adhere, which becomes your foundation for the top coat.
Here is the process I have used in the past, with good results
1) Wash boat thoroughly with dish soap and sos pad. Dry boat
2) mask off areas not to be painted - carefully. Cover areas not to be painted with poly. (Essentially wrap the boat and trailer everywhere but the hull)
3) Solvent wipe with Xylene. Constantly rotate through rags (those painters rags at HD are cheap you know). Wipe in a straight line as per the products instructions.
1, 2, and 3 are complete - call it a night and have adult beverage
4) Next day. Sand gel coat with 200 grit paper to break off outer surface. Here you really just want to scuff it. Use a sanding block to prevent gouging.
5) Fill any dents, dings, gouges etc with either epoxy or marine bondo. Let filler dry and relax with adult beverage.
6) After filler dries sand smooth and re-inspect hull carefully for any irregularities. NOW is the time - do not cut corners. Wipe down with tack cloth.
7) Spray on primer (use HPLV). There maybe a learning curve here, so practice. Let primer dry while having adult beverage
Sand out primer with 200-220. Wipe down with tack cloth. Spray on second coat of primer. Let primer dry while having adult beverage.
9) Bring in the trigger man for the finish coat. Solvent wash and wipe down with tack cloth - trigger man sprays boat. Let paint dry 24 hours while having adult beverage with trigger man.
10) 24 hours later - LIGHTLY sand with 300 grit paper. Solvent wipe and wipe down with tack cloth. Trigger man shoots second coat. Second coat dries while having adult beverage.
11) 24 hours later VERY LIGHTLY sand with 300 grit paper (you are near the end here). Solvent wipe and wipe down with tack cloth. Trigger man shoots final coat. Celebrate with many adult beverages (if you can still lift your arms)
12) Let dry 24-36 hours and buff to remove any ornage peel effect. Some say you can check the hull and only do this as needed, the boats I did were smaller so I just did the entire thing. If you are not comfortable with a DA buffer - hire this out - Burn in will ruin all your work in no time.
Some will say wet sand in step 4
Dear Builder Buds, I'm down to painting wing tips and not sure what to san
d the jell coat with to get the primer to stick. What grit sandpaper will
rough it enough to allow the epoxy primer to adhere, but not eat into the
hard coating ? Best regards, Bill of Georgia RV-8a, N228WP reserved, pain
ting in prep for final assembly
japhillipsga(at)aol.com Guest
Posted: Wed Sep 15, 2010 7:47 pm Post subject: Gell Coat Painting |
Stan, thanks for the info. I have painted the whole plane piece by piece minus the tips, rudder and elevators. I'm prepping them all to be finished this weekend. At least I can hope big. I really want done with this phase. Then I can move my efforts solely to the hanger for final assembly. My buddy Tony is mounting his 8a's wings on Sat. so I'll have to help. See your flying. I envy you and hope to be flying along before year's end. Course, I have to finish this damned painting. Best regards, Bill
