Picture size.
teamgrumman(at)YAHOO.COM
PostPosted: Fri Sep 10, 2010 10:29 am    Post subject: Picture size. Reply with quote
The pics were taken with my iPhone. Then, iPhoto imports them. Then I attach them to the email. They show up as roughly 1 meg files. I have a 24 inch iMac. The pics fit my screen just fine.
Pic of worlds most expensive Cheetah panel.
Sent: Fri, September 10, 2010 3:54:21 AM
Subject: Re: Power Flow. This fills the old hole.
--> TeamGrumman-List message posted by: "grumpyparts" <i.r.m(at)btinternet.com (i.r.m(at)btinternet.com)>
Thanks Cliff, glad I'm not the only one having that problem. Wanted to mention it before but thought may be I'm the only one viewing these posts on the forum site. Tip if using IE go to View, zoom, and reduce to about 25%, don't forget to put it back to 100% or you won't be able to read anything.
When I post pictures on the forum I go to the trouble to ensure the picture size stays within the normal viewing area without having to scroll.
Whilst I'm on my shop box could we try and keep the topic title the same, any slight change in the title causes another topic to be raised on the forum which makes following a subject some what tiresome.
<a target="_blank"
 Filesize:  350.41 KB
 Viewed:  1853 Time(s)
haveblue1(at)mac.com
PostPosted: Fri Sep 10, 2010 1:46 pm    Post subject: Picture size. Reply with quote
Gary,
iPhone 4 photo?
Awesome panel, by the way! I've never looked behind the panel, so I'm guessing that the higher position of the AI and the DG are due to the control column running below. Is this correct?
Bruce
From: grumpyparts <i.r.m(at)btinternet.com (i.r.m(at)btinternet.com)>
To: teamgrumman-list(at)matronics.com (teamgrumman-list(at)matronics.com)
<Corls_panel.jpg>
PostPosted: Sat Sep 11, 2010 9:04 am    Post subject: Picture size. Reply with quote
Oddly enough, the AI & DG locations are based on the sizes of the original AN AI & DG used in planes made in the 60s. There is no reason for them to be higher.
Sent: Fri, September 10, 2010 2:43:35 PM
Subject: Re: Picture size.
Gary,
iPhone 4 photo?
Bruce
<Corls_panel.jpg>
