LED as LV Annunciator
jonlaury
PostPosted: Sun Sep 05, 2010 7:42 am    Post subject: LED as LV Annunciator Reply with quote
I want to use an LED as a LV annunciator.
But from the products that AEC lists for driving LED's and what they do, I gather that using LED's over incandescent lamps can cause noise problems.
Does using a couple of LED's with the appropriate resistor create noise antagonists?
PostPosted: Sun Sep 05, 2010 9:39 am    Post subject: LED as LV Annunciator Reply with quote
At 10:42 AM 9/5/2010, you wrote:
--> AeroElectric-List message posted by: "jonlaury" <jonlaury(at)impulse.net>
You must be reading the information published
concerning noise issues on POWER SUPPLIES used
to excite high intensity arrays of LEDs.
[img]cid:7.1.0.9.0.20100905122859.01ec16d0(at)aeroelectric.com.0[/img]
In this case, it's the electronics that becomes a
potential antagonist for sensitive victims. It was
a potential cum reality that prompted a re-packaging
of the LuxDrive power supplies on a filter board
as shown above.
The LED is probably 10x noisier than other diodes . . .
but take that with a grain of salt. Virtually ALL electronic
devices passing current generate some noise. But
in the case of diodes, resistors and such, the amount
of is so tiny as to require special receivers
just to go find it . . . the garden variety
instrumentation system wont know it's there.
So install as many LEDs and companion resistors
as needed to meet your design goals. Noise potential
has no practical significance.
 Filesize:  95.14 KB
 Viewed:  3564 Time(s)
jonlaury
PostPosted: Sun Sep 05, 2010 12:16 pm    Post subject: Re: LED as LV Annunciator Reply with quote
Bob,
Thank you for that illumination. (I couldn't resist;-) Ohmy God! This is getting revolting! I seem stuck here no matter watt I do.
John
PostPosted: Sun Sep 05, 2010 12:26 pm    Post subject: LED as LV Annunciator Reply with quote
At 03:16 PM 9/5/2010, you wrote:
Bob,
Better to be "stuck" in the light as opposed to
wandering in the dark. We all started from right
where you are now.
