rparigoris
Posted: Sat Sep 04, 2010 6:36 am Post subject: Please explain this connector. |
Hi Group
Can anyone explain:
**This connector to me?
**Exactly what type of wire the one is with the red translucent covering?
**Are these connectors and wire still commonly used today?
http://www.europaowners.org/forums/gallery2.php?g2_itemId=82207
Perhaps the jet was built in modular sections and uses these connectors to connect one section to the next?
Select Full size 2592 x 1944 for better resolution.
Thx.
Ron Parigoris
Posted: Sat Sep 04, 2010 9:36 am Post subject: Please explain this connector. |
At 09:36 AM 9/4/2010, you wrote:
| Quote: | --> AeroElectric-List message posted by: "rparigoris" <rparigor(at)suffolk.lib.ny.us>
Hi Group
Can anyone explain:
Select Full size 2592 x 1944 for better resolution. |
These are one of many examples of devices crafted for
the IWTS (integrated wire termination systems) used
in many military, aerospace and high-end industrial
applications. Here's a toggle switch fitted with
IWTS
[img]cid:.0[/img]
The idea behind it is to make as many of the system's
wire terminations with standard crimp tools as possible.
The terminal blocks you've found are just commoning points
for multiple branches of a circuit. Rather than crimp
on terminals and then attache with screws (ugh!) one
simple crimps on a pin (usually female) and stuffs
the pin into an environmentally sealed cavity to mate
with a captive pin therein.
Some of the earliest patents on this idea go back to
the 70's. Other products using this technology . . .
http://www.ducommun.com/pdf/jayel/10648.pdf
http://stevenengineering.com/tech_support/PDFs/31G-MS.pdf
42.93 KB |
5523 Time(s) |
rparigoris
Posted: Sat Sep 04, 2010 10:47 am Post subject: Re: Please explain this connector. |
Hi Bob
Thx. for the explanation on the connector.
Can you shed some light on the wire that has red translucent insulation?
" **Exactly what type of wire the one is with the red translucent covering? "
Ron Parigoris
