Roger Lee
Posted: Fri Sep 03, 2010 12:16 pm Post subject: Rotax 912 gearbox pictures |
Hi Guys,
I don't remember if I posted these pictures? If I did disregard.
Binder3.PDF |
1.21 MB |
587 Time(s) |
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
rickofudall
Posted: Fri Sep 03, 2010 1:44 pm Post subject: Rotax 912 gearbox pictures |
Okay, Roger, I'll bite. I don't see any evidence that there is lead packing in the clutch teeth and the interior of the gearbox housing appears clean, BUT, it also appears to not have had any oil in it. From all the rust on bearings, prop shaft, and gears it seems this was a gearbox stored improperly.
Rick Girard
On Fri, Sep 3, 2010 at 3:16 PM, Roger Lee <ssadiver1(at)yahoo.com (ssadiver1(at)yahoo.com)> wrote:
Zulu Delta
Kolb Mk IIIC
582 Gray head
4.00 C gearbox
3 blade WD
Thanks, Homer GBYM
It is not bigotry to be certain we are right; but it is bigotry to be unable to imagine how we might possibly have gone wrong.
- G.K. Chesterton
Roger Lee
Posted: Fri Sep 03, 2010 2:27 pm Post subject: Re: Rotax 912 gearbox pictures |
Hi Rick,
This gearbox has 30 minutes on it. It was a prop strike on a new plane and sent in for inspection and a dye test. The rust looking areas are actually Rotax factory use of Copper anti-seize for a lube during assembly.
When I get one in with a lot of 100LL use at about 800+ hrs. I'll try and remember to post a picture.
Tucson, Az.
Cell 520-349-7056 |
