Fergus Kyle
Joined: 03 Jun 2007 Posts: 291 Location: Burlington ON Canada
Posted: Mon Aug 30, 2010 1:24 pm Post subject: Splicing small wires |
I cannot pretend to be so wise as some on the net, but I do have a small note to make when splicing the #18-on-down size wires, especially when in crowded corners – I seem to specialize in wiring myself into a spiralling corner.....
In radio I learned long ago you can’t find the size you need to join two wires. I hit upon the model aircraft shops for copper/brass tubing which is nesting in size around these smaller wires. It’s a pain to cut the tubing and smooth the ends so that fine wire can enter so I do this in tens at one time when the conditions dictate, either this or reading a good book. For a couple of bucks and a warder file plus small-tooth saw, you can have a pocketful of crimpable lengths just lying there waiting for redemption. The simple crimper slides easily into tight spaces, and we’re not welding power cable here.
Just a thought.
Ferg
Europa XS A064
wiring wiring wiring [quote][b]
brian.gowland(at)mypostof Guest
Posted: Mon Aug 30, 2010 11:47 pm Post subject: Splicing small wires |
Try rolling a small copper/ brass/ali tube under a sharp blade, for perfect results in seconds.
Brian
Hn700 Menestrel 11
