jsbougher(at)yahoo.com Guest
Posted: Tue Aug 24, 2010 2:56 am Post subject: GPS outage in fiberglass plane |
I fly a purchased Velocity. I'm about 1/3 through Bob's book and generally not good with electrical issues - hence the book. What I have learned is that there is a lot of knowledge on this board.
I have the following problem. On the ground, panel mounted Garmin 430 and portable Garmin 396 work fine. Take-off and fly for 20-45 minutes and I lose GPS signal on both almost simultaneously. Sometimes I get GPS signal back, sometimes I don't. Sometimes when I get GPS signal back it is intermittent. When I look at the 396 GPS page, it doesn't show ANY signal on ANY satellite. Sometime around touchdown I get GPS back ... I'm not really looking until taxiway, so don't know when, but ON the ground GPS seems to always be able to acquire.
Two recent sample flights.
Depart both GPSs working, then 40 minutes into flight, both drop GPS at about same time. This is a 2:20 flight. After another 30 minutes, 430 picks up satellites and maintains through rest of flight. The 396 doesn't pick up satellites until back on the ground.
Return flight, both GPSs working on ground. Sometime around 30-40 minutes into flight, both drop GPS at about same time. After 1 hour - 1:15, the 396 reacquires satellites. The 430 never reacquires until back on ground.
Notes:
* The 396 is new to me. I had borrowed it previously on occasion and had similar occurrence twice. This was a few years back and, if I recall, both occurrences were an hour or more into flight.
* The 430 was recently upgraded from 430 to 430W, but I'm still flying on the 430 antenna. As stated above, had problem before, but it seems MUCH more consistent now.
* I had flight following on one of these occurrences and asked center if there was know problem. Answer was NO and about 3 planes on station reported no problems.
* Both flights above, there was much humidity in the air and I was under a lowish cloud deck. I don't recall conditions on previous events.
* I've tried using 396 plugged into cigarette lighter and running only on battery and it makes no difference.
Any thoughts?
Jeff
rlborger(at)mac.com Guest
Posted: Tue Aug 24, 2010 5:07 am Post subject: GPS outage in fiberglass plane |
Jeff,
First, you need to upgrade the antenna on the 430 to a WAAS antenna and ensure the antenna cable length is correct for proper performance of the 430.
Now, on to the GPS signal problem. Some questions:
1. What are you using for the 396 antenna? Rod attached to the 396 or a remote antenna? If a remote antenna, what type?
2. Are the two units using a single antenna or do each have their own antenna?
3. How and where is/are the antenna/s located and mounted?
4. How is/are the antenna/s cabling routed? Looking for pinches or other defects in routing which could cause intermittent failures.
5. What is the condition of the antenna cable connection to the GPS units?
Perhaps answers to these will help the troubleshoot.
Good luck,
Bob Borger
Europa Kit #A221 N914XL, XS Mono, Intercooled 914, Airmaster C/S
http://www.europaowners.org/forums/gallery2.php?g2_itemId=60232
http://www.biplaneforumgallery.com/index.php?cat=10046
Europa Flying!
3705 Lynchburg Dr.
Corinth, TX 76208
Home: 940-497-2123
Cel: 817-992-1117
On Aug 24, 2010, at 5:54, Jeffrey Bougher wrote:
| Quote: | I fly a purchased Velocity. I'm about 1/3 through Bob's book and generally not good with electrical issues - hence the book. What I have learned is that there is a lot of knowledge on this board.
Notes:
Any thoughts?
Jeff
jay(at)horriblehyde.com Guest
Posted: Tue Aug 24, 2010 6:15 am Post subject: GPS outage in fiberglass plane |
Something else that you might want to look at is the antenna cable length; in the MGL instrument this is a very specific length that comes already prepared with the antenna. The instructions say not to cut this but to bundle it; some people do cut the cable and shorten it but this seriously degrades the performance of the GPS as the cable is a tuned length.
Not sure if this applies to other GPS makes but its likely, so check that the cable is as per the original factory specification.
Jay
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert Borger
Sent: 24 August 2010 03:05 PM
Subject: Re: AeroElectric-List: GPS outage in fiberglass plane
Jeff,
Good luck,
Bob Borger
Europa Flying!
3705 Lynchburg Dr.
Corinth, TX 76208
Home: 940-497-2123
Cel: 817-992-1117
Notes:
Any thoughts?
Jeff
| Quote: | | href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-Listhref="http://forums.matronics.com">http://forums.matronics.comhref="http://www.matronics.com/contribution">http://www.matronics.com/contribution |
grosseair(at)comcast.net Guest
Posted: Tue Aug 24, 2010 6:39 am Post subject: GPS outage in fiberglass plane |
I don't think it would affect the 396, but I don't understand why your
avionics shop would leave the original antenna in place. It is not the
same as the antenna for the 430W and I'm surprised it works at all.
John Grosse
Jay Hyde wrote:
a tuned length.
Jay
*From:* owner-aeroelectric-list-server(at)matronics.com
[mailto:owner-aeroelectric-list-server(at)matronics.com] *On Behalf Of
*Robert Borger
*Sent:* 24 August 2010 03:05 PM
*To:* aeroelectric-list(at)matronics.com
*Subject:* Re: GPS outage in fiberglass plane
Jeff,
of the 430.
antenna?
Good luck,
Bob Borger
Europa Flying!
3705 Lynchburg Dr.
Corinth, TX 76208
Home: 940-497-2123
Cel: 817-992-1117
back on ground.
Notes:
Any thoughts?
Jeff
*href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-List*
*href="http://forums.matronics.com">http://forums.matronics.com*
*href="http://www.matronics.com/contribution">http://www.matronics.com/contribution*
Kellym
Posted: Tue Aug 24, 2010 7:06 am Post subject: GPS outage in fiberglass plane |
The most common cause of loss of satellites (besides military jamming)
is com or nav frequencies that interfere from other radios in the
cockpit. The AC20-138A for GPS install calls out the frequencies that
must be tested before a unit can be signed off in the aircraft.
On 8/24/2010 7:24 AM, John Grosse wrote:
<grosseair(at)comcast.net>
John Grosse
> Jay
> *Robert Borger
> Jeff,
> of the 430.
> antenna?
> units?
> Good luck,
> Bob Borger
> Europa Flying!
> 3705 Lynchburg Dr.
> Corinth, TX 76208
> Home: 940-497-2123
> Cel: 817-992-1117
> acquire.
> Notes:
> events.
> Any thoughts?
> Thanks,
> Jeff
KCHD |
sportav8r(at)gmail.com Guest
Posted: Tue Aug 24, 2010 7:08 am Post subject: GPS outage in fiberglass plane |
Jeff, I've had interference issues when two GPS active patch antennas were co-located on the glareshield - neither would acquire until one was turned off or moved a good bit away. I figured out what was up when I added the second GPS antenna (for an APRS tracker) and the Garmin 296 suddenly went "blind." Locating the tracker GPS puck antenna in the aft baggage area (perhaps 3.5 feet line of sight from the Garmin antenna) has completely solved the issue. Just a thought. Not sure why your problem only appears once airborne - that is most curious.
Bill Boyd
RV-6A
On Tue, Aug 24, 2010 at 6:54 AM, Jeffrey Bougher <jsbougher(at)yahoo.com (jsbougher(at)yahoo.com)> wrote:
[quote]I fly a purchased Velocity. I'm about 1/3 through Bob's book and generally not good with electrical issues - hence the book. What I have learned is that there is a lot of knowledge on this board.
Notes:
Any thoughts?
Jeff
tim2542(at)sbcglobal.net Guest
Posted: Tue Aug 24, 2010 7:14 am Post subject: GPS outage in fiberglass plane |
First, the 430W antenna is not compatible with the 430 and the fact that you had a problem before pretty much narrows it down to a bad and/or incorrect antenna. Where are your antennas located? What else is in close proximity to the them? I would suggest you make sure you have the correct antenna for each unit and it is placed where it will not be next to other electrical devices and has a good view of the sky. Fiberglass should only attenuate the signal very slightly and for our purposes can be considered not there. Assuming there is not some kind of special coatings on the glass. I’m just guessing here but could you have the 2 antennas mixed up?
Tim Andres
(rnbraud(at)yahoo.com)
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Jeffrey Bougher
Sent: Tuesday, August 24, 2010 3:54 AM
Subject: GPS outage in fiberglass plane
Notes:
Any thoughts?
Jeff
| Quote: | | http://www.matronics.com/Navigator?AeroElectric-List | 0123456789
Checked by AVG - www.avg.com
11:34:00
mrspudandcompany(at)veriz Guest
Posted: Tue Aug 24, 2010 8:05 am Post subject: GPS outage in fiberglass plane |
| Quote: | On Tue, Aug 24, 2010 at 6:54 AM, Jeffrey Bougher <jsbougher(at)yahoo.com (jsbougher(at)yahoo.com)> wrote:
Jeff
| Quote: | My thought would be to operate your GPS on it's inernal battery, and when it fails, turn off your master switch to kill everything electrical, so the only thing still running is the engine. If the GPS comes back, then it is probably something in the panel, if it doesn't start working then the problem may be in the GPS. If it is in the panel, you can then go through a process of elimination by restoring power to the panel and shutting down each electronic device individually until the problem goes away.
Roger
| [quote][b]
Posted: Tue Aug 24, 2010 12:55 pm Post subject: GPS outage in fiberglass plane |
Nope, separate antennas. This is what baffles me. The only think they share in common is that they are GPSs, they are made by Garmin and they are in my plane :^). That is why I made sure on one trip that the 396 was not even plugged into the cigarette lighter - still lost signal at same time as 430.
Jeff
Cc: Jeffrey Bougher <jsbougher(at)yahoo.com>
Sent: Tue, August 24, 2010 7:24:46 AM
Subject: Re: GPS outage in fiberglass plane
Since both units drop out at the same time, Jeff, I will assume that they share the same antenna and thus lose signal somehow, probably due to vibration. Can you please confirm that the 430 and 396 are using the same antenna?
Thanks.
Simon Ramirez
Oviedo, FL USA
On 8/24/2010 6:54 AM, Jeffrey Bougher wrote: [quote] I fly a purchased Velocity. I'm about 1/3 through Bob's book and generally not good with electrical issues - hence the book. What I have learned is that there is a lot of knowledge on this board.
Notes:
Any thoughts?
Jeff
dave.gribble(at)mchsi.com Guest
Posted: Tue Aug 24, 2010 1:43 pm Post subject: GPS outage in fiberglass plane |
I had a similar problem with my 496. It worked perfectly, but every once in a while would lose sall atellites and they would stay gone (no signal bars) for minutes at a time - even many minutes.
I didn't spend a lot of time worrying about it since my plane is VFR and I can live without the GPS in the local area. One time I was far from home and it happened and that is how I stumbled on the problem. I had to revert to VOR navigation and while I was tuning the NAV radio I noticed that I could make the GPS signal come back. I noticed that when I tuned the NAV2 VOR receiver in my plane to 114.1 (or any frequency around it) that would completely kill the GPS. All other VOR frequencies worked fine. Sometimes it would be completely killed, and sometimes small bars would remain.
What must be happening is that the local oscialltor in the TKM nav radio must have a harmonic that lands right on the GPS frequency. You could watch the signal bars go away on the GPS when you tuned the NAV radio. The handheld antenna on the 496 wasn't helping things, since I was able to show that that was how the interference was getting into the GPS.
I suspect some other piece of equipment in your plane is interfering with your GPS. When the GPS(s) fail, start turning things off or tuning them to different frequencies. You'll find it.
Good Luck,
dave
rmitch1(at)hughes.net Guest
Posted: Tue Aug 24, 2010 2:22 pm Post subject: GPS outage in fiberglass plane |
Also the coax on the 430w is much higher quality shielding than that a called out in the 430 install. If you don't have the 430w antenna, you really don't have a 430w!
Bob Mitchell
Twin comanche 42tp
Garmin 430w
Garmin 496
Sent from my iPad
Good Luck,
dave
Posted: Wed Aug 25, 2010 3:10 am Post subject: GPS outage in fiberglass plane |
Wow, thanks for all the comments and suggestions ... I had to get a notepad out to write them all down. I think I have answers to most questions. To troubleshoot, two suggestions that I'm definitely going to follow are:
1) Move the 396 antenna further from 430 antenna - I'll stick in armpit pocket in back seat - nothing but think fiberglass and some fabric between it and sky.
2) Next time it occurs, try changing radio frequencies one by one, I will include transponder. If this doesn't work, try killing each radio sequentially to see if that helps.
3) If above doesn't work, kill all electric and see if 396 picks up satellites.
Now, to answer a few questions and see if this brings more light to the problem:
* When I had 430W upgrade, I got new antenna. The puck mount is a smidge different so I need to modify mount on plane. Avionics shop said 430 would work fine with old antenna, but it wouldn't be a 430W.
* The 430 antenna is mounted directly under the front access panel. It is probably within 1 foot of battery and ELT antenna. The 396 antenna is a Garmin remote antenna and sits on the glare shield - maybe 2 feet horizontally from the 430 antenna.
* The 430 antenna has a pretty straight shot directly to radio. Cable was fabricated by avionics shop. It was replaced about 5 years ago when I had complete GPS failure due to bad wire ... mode this time is different (intermittent). The 396 antenna is also 5 years old, but in a little worse shape since it is not mounted and gets handled much more. The
* The 396 antenna sits immediately next to the XM antenna on the glare shield. Both are routes somewhat haphazardly around the edge of the glareshield. I would say they are trapped between edge of glareshield and sidewall, but they are not pinched. The 396 cable has never been modified
Final note, my experience means that I don't really trust GPS. I've stayed pretty good at flying VORs and always have 2 flight plans on my knee board - direct and VOR. Fortunately, I have a DME which makes VOR flying much easier. Unfortunately I don't have an RNAV like I used to have in my Cessna. I LOVED the RNAV and was going to put one in my Velocity, but had several people tell me they were maintenance nightmares. So far, the 430 has been the most troublesome part of my aircraft ownership experience. When it works it is all sugar and sunshine, when it goes out, it back to the VORs.
Notes:
Any thoughts?
Jeff
Posted: Wed Aug 25, 2010 6:41 am Post subject: GPS outage in fiberglass plane |
I'd note that in the case of the 430W antenna (I understand you are
using 430 antenna), a minimum level for the antenna coax is specified.
A straight shot may not be ideal. The length of cable in all GPS
antenna seems to be something to pay attention to (either reference
installation manual or leave supplied coax alone and coil as required).
I'm amazed at your experience because it's so different from mine. I've
been using GPS since the very beginning (racing gliders adopted it day
one because it circumvented some competitive rules regarding on board
navigation). Equipped my Maule with a certified Garmin 300XL (crude by
430 standards), got my rating, and logged plenty of actual behind it.
Still have a 396 in the Maule which was a signicant upgrade to the 300XL
panel. All of the above has performed flawlessly from day 1. The 300XL
was professionally installed. The rest of it was pretty ad hoc. I'm
looking forward to limiting my ground based NAV to proficiency work in
an almost flying RV10.
You are really going to like your setup once you get it working reliably.
Bill
| Quote: | Wow, thanks for all the comments and suggestions ... I had to get a
to follow are:
satellites.
the problem:
more. The
modified
> acquire.
> Notes:
> Any thoughts?
> Thanks,
> Jeff
Radioflyer
Posted: Fri Aug 27, 2010 7:39 am Post subject: Re: GPS outage in fiberglass plane |
This has been an interesting discussion to read through. I've had similar experiences with a Garmin 296 that had me baffled for a while. I first used my unit extensively on a Florida to Boston cross country flight in a LongEZ. Maybe I experienced a very brief lost of signal, but it was of no consequence. The unit provided excellent service.
Then I started using it in a C172 and noticed a troubling occurence of dropouts. Tried new software, and different antenna. Eventually, I got to associate the dropouts with specific routes, some of which had known large ground antenna installations, so I thought it was just groundstation intereference. But no one I talked to seem to be experiencing GPS problems in the area. I have used the unit in another Cessna and while the dropouts were not at all as frequent, they still occurred unpredictably. I had lost faith in my GPS.
I had learned from various sources that the navcoms could jam the GPS. So after reading this thread, I finally took the time to check this out. I had just come back from a flight during which the GPS performed flawlessly. While on the tiedown, with engine and everything running, I started to tune in the various com frequencies I use in my area. With the GPS screen set to show the sat reception bars, I quickly found that the bars would quickly pulse down to nothing when the frequency was set between 119.200 to 119.5. This was even without transmitting and it was dramatic. As it turns out, I am usually tuned within this frequency range when flying the routes I had associated with GPS loss.
Since the G296 seems to work well in the LongEz, but with dropouts in the Cessna, the problem is with the Cessna radio and not the GPS. Not surprisingly, different radio installations have different RF signatures and tolerances. Maybe the Cessna radio is out of spec, maybe not, but it is good to know finally, what is causing my dropouts. Now if I'm lost and the GPS drops out, I know I can change frequencies or turn off the avionics and get re-oriented.
--Jose
james(at)etravel.org Guest
Posted: Fri Aug 27, 2010 7:53 am Post subject: GPS outage in fiberglass plane |
Interesting stuff. That's worth everyone with a GPS tucking away in
the "for future reference" part of the brain. Thanks for taking the
time to report this info.
James
On Fri, Aug 27, 2010 at 4:39 PM, Radioflyer <skyeyecorp(at)airpost.net> wrote:
I had learned from various sources that the navcoms could jam the GPS. So after reading this thread, I finally took the time to check this out. I had just come back from a flight during which the GPS performed flawlessly. While on the tiedown, with engine and everything running, I started to tune in the various com frequencies I use in my area. With the GPS screen set to show the sat reception bars, I quickly found that the bars would quickly pulse down to nothing when the frequency was set between 119.200 to 119.5. This was even without transmitting and it was dramatic. As it turns out, Â I am usually tuned within this frequency range when flying the routes I had associated with GPS loss.
--Jose
http://forums.matronics.com/viewtopic.php?p=310285#310285
checkn6
Posted: Sat Aug 28, 2010 7:12 am Post subject: Re: GPS outage in fiberglass plane |
I agree, but I am going to go one small step further and do the frequency test while on the ground the next time I go to the airport. I too have had GPS drop-out for brief periods and just thought that I had gotten a bum deal on EBAY on my little hand held Garmin 196. I still have a plan A and plan B since my little GPS is more for informational purposes only and is really a plan C.
Thanks for starting this thread.
My wife thinks I'm nuts for reading this "boring stuff" but I love learning new things and once again I found a little gem to check on.
Chris
[quote="james(at)etravel.org"]Interesting stuff. That's worth everyone with a GPS tucking away in
James
Tundra10
Joined: 14 Jun 2010 Posts: 102 Location: Scarborough, Ontario
Posted: Sun Aug 29, 2010 6:29 am Post subject: GPS outage in fiberglass plane |
I will add another data point concerning radios interfering with GPS
reception.
I recently installed a Garmin 430W in my Cessna 172 (probably doubled
its value, but the unit will be removed for installation into the
airplane I am building).
I worked with an avionics shop that was willing to supervise me doing
much of the work as a learning experience - and it was !
The Garmin installation manual cautions against installing the GPS
antenna within 4 feet of other antennas. The cabin roof of the Cessna
makes that goal impossible to meet.
For simplicity, we chose to re-use the same mounting location as the
old GPS antenna, which is a foot away from the antenna of the King
KX-175B radio.
There are a number of tests required in the Garmin installation
manual, including transmitting with each radio on the following
frequencies for 35 seconds, while watching the satellite reception
screen:
121.150, 121.175, 121.200, 121.225, 121.250
131.200, 131.225, 131.250, 131.275, 131.300, 131.325, 131.350
In my case the 131MHz frequencies interfered. Not just slightly, but
completely killed reception of all GPS satellites. The strength bars
went to zero immediately. The 430W required more than a minute to
recover after unkeying the transmitter.
I swapped the COM antennas between the 430W and the KX-175B. The 430W
produced a cleaner transmission that did not interfere with GPS
reception. The transmissions of the KX-175B, with the antenna now 3
feet away from the GPS antenna, only slightly interfered (lost 10-20%
of signal strength) and did not prevent reception from even the
marginal satellites. So problem simply resolved.
Where I fly, I rarely use frequencies in the 131MHz range, so without
doing this test I might have happily flown for quite a number of
hours, only to be confounded with lack of GPS navigation at some
future point.
I recommend everyone perform this test, since it is so quite and easy to do.
Jeff Page
Dream Aircraft Tundra #10
Kellym
Posted: Sun Aug 29, 2010 7:04 am Post subject: GPS outage in fiberglass plane |
Keep in mind that it is not just transmitting that creates
interference. Having the radio simply tuned to a frequency and turned
on can also cause the problem. There are also nav frequencies that need
to be checked. They are not in the AC, but this site has more detail of
documented issues for specific radio models:
http://www.scn.org/~bk269/gps.html
On 8/29/2010 7:26 AM, Jeff Page wrote:
reception.
KX-175B radio.
screen:
future point.
to do.
Jeff Page
KCHD |
raymondj(at)frontiernet.n Guest
Posted: Sun Aug 29, 2010 12:53 pm Post subject: GPS outage in fiberglass plane |
Slightly off topic. Does anyone have any info on similar problems
occurring on GPS caused by marine radios? Any info would be appreciated.
Raymond Julian
Kettle River, MN
On 08/29/2010 09:26 AM, Jeff Page wrote:
reception.
KX-175B radio.
screen:
future point.
to do.
Jeff Page
