601 XLB for Rent?
MHerder
PostPosted: Sun Aug 22, 2010 6:51 pm    Post subject: 601 XLB for Rent? Reply with quote
Are any flight schools renting out a 601XLB for training? Just curious. Trying to get some Zodiac time.[/b]
Zodiac 601 HD
Jabiru 3300
Wood Sensinich 64x47
Finally Flying
LHusky
PostPosted: Sun Aug 22, 2010 7:37 pm    Post subject: 601 XLB for Rent? Reply with quote
Dragonfly Aviation in Northern California had 2 of them. I just do not know if they have had the upgrade yet. I know one of them was a factory built, so it may be back online. I plan on calling them soon to get about 5 hours in before I test mine out!
In a message dated 8/22/2010 7:53:50 P.M. Pacific Daylight Time, michaelherder(at)beckgroup.com writes:
--> Zenith601-List message posted by: "MHerder" <michaelherder(at)beckgroup.com>
One Rivet at a Time!
http://forums.matronics.com/viewtopic.php?p=309829#309829===============================================
_-= Use the ties Day ================================================ - MATRONICS WEB FORUMS ================================================ - List Contribution Web Site sp;   ===================================================
psm(at)att.net
PostPosted: Sun Aug 22, 2010 7:43 pm    Post subject: 601 XLB for Rent? Reply with quote
Hi guys,
I too would like to get some time in before my first test flight. I'm not ready yet, but I hope to be getting there soon.
I hope folks will publish information about XL rentals available on this list. I'm sure lots of folks would love to get a checkout in the next year.
Paul
Camas, WA
From: owner-zenith601-list-server(at)matronics.com [mailto:owner-zenith601-list-server(at)matronics.com] On Behalf Of LHusky(at)aol.com
Sent: Sunday, August 22, 2010 8:30 PM
Subject: Re: 601 XLB for Rent?
======================= - MATRONICS WEB FORUMS ======================= - List Contribution Web Site sp; =
Terry Phillips
PostPosted: Sun Aug 22, 2010 9:25 pm    Post subject: 601 XLB for Rent? Reply with quote
Paul Hamilton offers both rental and instruction in a 601XLB in the Reno area.
http://sportaviationcenter.com/pilot-training/aircraft-rental/
Since E-AB's cannot be used for rentals, all rentals and instruction and
rental must be done in S-LSA's which are subject to the mandatory upgrade
under the SAIB. Hence any 601XL/650 available for rental or instruction
must be XLB's.
See also
http://www.youtube.com/watch?v=DGNeEqOaru8 and
http://www.youtube.com/watch?v=a-1z3n1NHmg
Terry
Terry Phillips
ttp44~at~rkymtn.net
Corvallis MT
ZU-601XL/Jab 3300 s .. l .. o .. o .. w build kit - Tail & flaps are done;
Upgrading wings & ailerons per the AMD Safety Directive
http://www.mykitlog.com/N47TP/
Terry Phillips
Corvallis, MT
ttp44<at>rkymtn.net
Zenith 601XL/Jab 3300 slow build kit - Tail feathers done; working on the wings.
DaveG601XL
PostPosted: Mon Aug 23, 2010 2:48 am    Post subject: Re: 601 XLB for Rent? Reply with quote
It looks like there is still one in Holland, Michigan.
http://www.tulipcityair.com/home.aspx
David Gallagher
Cincinnati, OH area
skyriderekm
PostPosted: Mon Aug 23, 2010 10:33 am    Post subject: Re: 601 XLB for Rent? Reply with quote
Dave and all,
You are correct. Tulip City Airport DOES have a CH601XL-B. I just received information from them stating the aircraft HAS been upgraded. Here's their website: www.tulipcityair.com
I know I will be heading up there next spring when I'm closer to completing my CH650. I'm working on the upgrade right now. (Thanks Tim Juhl for your help getting me started again!)
Tailwinds
Larry Hursh
Edwardsburg, MI
Will be Corvair 2700cc powered.
mhubel
PostPosted: Mon Aug 23, 2010 11:36 am    Post subject: 601 XLB for Rent? Reply with quote
You might consider looking for a Piper Sport. It is almost identical
to the un-modified 601XL but with different hinges for control surfaces
and a different (and weaker) nose wheel. Other than having to be more
careful to keep the nose up until the speed bleeds down, it handles the
same.
Mark Hubelbank
NorthEast Monitoring
2 Clock Tower Place
Suite 555
Maynard, MA, 01754 - USA
mhubel(at)nemon.com
978-443-3955
Mark Hubelbank
N708HU
CH601XL
Jabiru 3300
Rotec TBI 40-3 carb
Sensenich ground adj prop.
240 hr TAF
Pictures at photo.hubbles.com
Davcoberly(at)wmconnect.c
PostPosted: Mon Aug 23, 2010 12:54 pm    Post subject: 601 XLB for Rent? Reply with quote
Also for even another option I took my transition training in a Remos GX it
has a stick control and has very close airspeeds to the 601XL even though
it is a high wing aircraft it worked for me. David Coberly 601XLB / Corvair
