dlm34077
Posted: Sat Aug 21, 2010 2:38 pm Post subject: Egt probes (GRT) |
Another probe failed this morning. That makes 5 failures in 310 hours TTSN. This cylinder has not failed earlier so it was probably the lower quality probe. I will swap it out next week with an Electronics International to determine whether they are a better solution. They claim that the probe will last 2000 hours. My EGTS are operated usually between 1200-1420 F. For brief moments during leaning, some may range from 1420-1450 but are immediately brought under 1420 with mixture control. My usual cruise provides EGT range from 1375-1420. Yet probes have failed five times: cylinders 1(once), 2(twice), 6 (once) and now 3. Four failures occurred between 200-300 hours TTSN. I am installing an EI P-110; I had EI engine instrumentation for my Glastar and in 530 hours had no failures of either EGT or CHT probes.
Kellym
Posted: Sat Aug 21, 2010 4:08 pm Post subject: Egt probes (GRT) |
I don't recall the exact hours in service, but have had no failures on
the fast response EI EGT probes on my 200hp Mooney running cruise EGTs
in the 1350-1500 range, mounted exactly 1.5" from the cylinder flange of
exhaust stack. Installed them several years ago. Only failures have been
a couple leads/connections from the probes, easily fixed with new
connector and crimper.
On 8/21/2010 3:34 PM, DLM wrote:
| Quote: | Another probe failed this morning. That makes 5 failures in 310 hours
KCHD |
