Albert Gardner
Posted: Mon Aug 23, 2010 10:36 pm Post subject: Day 21 |
[quote]Well we got the tail cone joined up today and are working on the rear window. Plans say to drill the roll bar with #40 and then tap them 6-32. Tap drill for 6-32 is #37, does #40 work OK?Albert GardnerRV-10 N991RVYuma, AZ [b]
| - The Matronics RV12-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RV12-List |
_________________ RV-9A N872RV
RV-10 N991RV |
hufise(at)hotmail.com Guest
Posted: Tue Aug 24, 2010 1:06 am Post subject: Day 21 |
Normal 0 21 false false false MicrosoftInternetExplorer4 <![endif]--> <![endif]--> st1\:*{behavior:url(#ieooui) } <![endif]--> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Normale Tabelle"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} <![endif]-->
Hi Albert Gardner
i have an 6-32 NC Tap kit it contains an #36 Drill.
You can try to use the #40, do not use to mach force for the Tap after the "knack" i think you have a big problem to remove the Tap.
Greetings from Switzerland with the lucky metric system.
Daniel Schmid
RV-12 empennage Kit, wait for build advisor
To: rv12-list(at)matronics.com
Subject: Day 21
Date: Mon, 23 Aug 2010 23:36:28 -0700
.ExternalClass p.ecxMsoNormal, .ExternalClass li.ecxMsoNormal, .ExternalClass div.ecxMsoNormal {margin-bottom:.0001pt;font-size:12.0pt;font-family:'Times New Roman','serif';} .ExternalClass a:link, .ExternalClass span.ecxMsoHyperlink {color:blue;text-decoration:underline;} .ExternalClass a:visited, .ExternalClass span.ecxMsoHyperlinkFollowed {color:purple;text-decoration:underline;} .ExternalClass p {margin-bottom:.0001pt;font-size:12.0pt;font-family:'Times New Roman','serif';} .ExternalClass pre {margin-bottom:.0001pt;font-size:10.0pt;font-family:'Courier New';} .ExternalClass span.ecxHTMLPreformattedChar {font-family:Consolas;} .ExternalClass span.ecxEmailStyle20 {font-family:'Calibri','sans-serif';color:#1F497D;} .ExternalClass span.ecxEmailStyle21 {font-family:'Calibri','sans-serif';color:#1F497D;} .ExternalClass span.ecxEmailStyle22 {font-family:'Calibri','sans-serif';color:#1F497D;} .ExternalClass span.ecxEmailStyle23 {font-family:'Calibri','sans-serif';color:#1F497D;} .ExternalClass span.ecxEmailStyle24 {font-family:'Calibri','sans-serif';color:#1F497D;} .ExternalClass span.ecxEmailStyle25 {font-family:'Calibri','sans-serif';color:#1F497D;} .ExternalClass span.ecxEmailStyle26 {font-family:'Calibri','sans-serif';color:#1F497D;} .ExternalClass .ecxMsoChpDefault {font-size:10.0pt;} (at)page WordSection1 {size:8.5in 11.0in;} .ExternalClass div.ecxWordSection1 {page:WordSection1;} [quote]Well we got the tail cone joined up today and are working on the rear window. Plans say to drill the roll bar with #40 and then tap them 6-32. Tap drill for 6-32 is #37, does #40 work OK?Albert GardnerRV-10 N991RVYuma, AZ http://www.mathref="http://forums.matronics.com" target="_blank">http://forums.matron=====[b]
