woxofswa
Posted: Tue Aug 17, 2010 7:51 am Post subject: whizzo box dual power wires |
In the case of avionics that run dual power wires (supposedly to ease load in each wire), is it okay to terminate the two wires into a single connector to attach to c/b or should each have its own connector?
Thanks in advance.
_________________ Myron Nelson
Mesa, AZ
Flew May 10 2014 |
tim2542(at)sbcglobal.net Guest
Posted: Tue Aug 17, 2010 9:20 am Post subject: whizzo box dual power wires |
No expert here but I have the same question. I have seen harnesses made by a
pro shop recently and they just run one wire and a short jumper over to the
second pin at the distal end. I'm thinking they want to reduce the load on
the pin, not so much the wire. In some cases like the GRT stuff and some
Garmin the extra pins are to accommodate separate busses and are diode
isolated from one another.
Tim Andres
Posted: Tue Aug 17, 2010 10:12 am Post subject: whizzo box dual power wires |
At 10:51 AM 8/17/2010, you wrote:
Multiple wires in to a single crimp are entirely
acceptable. See:
http://aeroelectric.com/articles/multiplewires/multiplewires.html
. . . although you probably don't need to to
to this effort to make sure that two wires get
properly inserted to equally share the wire-grip
space.
