bilhicks(at)swbell.net Guest
Posted: Sat Aug 14, 2010 11:27 am Post subject: Starting problems |
Couple of us with dual mags, no impulse couplers, slick start on io540 d4 a5, are having starting problems on both cold and hot starts. Engine eventually starts just as you release key from start position. We have checked the slick start and it is putting out spark. Any one have similar situation and if so did find a fix?
Bob Turner
Posted: Sat Aug 14, 2010 12:40 pm Post subject: Re: Starting problems |
ACS site says it works with "impulse coupled, or retard breaker, mags...". Do you have some form of retarded timing on your mags, for start?
_________________ Bob Turner
RV-10 QB |
Kelly McMullen
Posted: Sat Aug 14, 2010 12:47 pm Post subject: Starting problems |
Since this should be the same wiring as the old Bendix Shower of
Sparks, or retard breaker system, the start circuit goes through a
second set of points, the retard points that activate at TDC. If those
points aren't opening and closing correctly, or aren't hooked up via
what looks like a second "P lead" which will have a smaller dia
connector, then you aren't getting a spark during cranking. Your
symptoms are a classic on retard breaker system. When you release the
key from start position it goes back to normal firing of both mags and
is starting on that. When you are cranking only the left mag that has
the retard breaker points is supposed to fire, and only at TDC. You
have something that is preventing that firing from happening at TDC.
Either the ignition switch isn't wired correctly, or the retard points
aren't opening correctly.
I'd go back to the documentation for your left mag, your Slick Start
documentation, and the wiring diagram for the ignition switch and
verify all of it. I don't know, perhaps the slick start is supposed to
fire both mags, maybe it can do it without using the retard breaker
points, but you need to verify that it is being triggered at TDC, and
that there is spark at the plugs at TDC. If it only fires when you
release the start key, that is not happening.
On Sat, Aug 14, 2010 at 12:24 PM, William Hicks <bilhicks(at)swbell.net> wrote:
A&P/IA, EAA Tech Counselor
KCHD |
Posted: Sat Aug 14, 2010 12:58 pm Post subject: Starting problems |
No first hand experience, but I'm betting that the starter is drawing
down the battery voltage so that the Slickstart doesn't get it's full
share. Measure the voltage at the Slickstart while cranking. If you
didn't run a ground wire from the battery to the engine compartment, you
might entertain doing that now. If you have the normal Vans
installation, check for a good connection at the battery ground to the
airframe ....... get rid of the paint under the lug.
Linn
Posted: Sat Aug 14, 2010 1:08 pm Post subject: Starting problems |
Kellt and Bob's post got me to thinking ..... it could be that the engine cranking speed is higher than the Slickstart wants for retarded spark.
Linn
Kelly McMullen wrote: [quote] | Quote: | --> RV10-List message posted by: Kelly McMullen <apilot2(at)gmail.com> (apilot2(at)gmail.com)
On Sat, Aug 14, 2010 at 12:24 PM, William Hicks <bilhicks(at)swbell.net> (bilhicks(at)swbell.net) wrote:
| Quote: | --> RV10-List message posted by: William Hicks <bilhicks(at)swbell.net> (bilhicks(at)swbell.net)
| [b]
Kelly McMullen
Posted: Sat Aug 14, 2010 1:17 pm Post subject: Starting problems |
That is possible. I have no problems with the traditional Bendix
vibrator Shower of Sparks on my old Mooney with a Skytec high speed
starter. In fact it starts just fine, hot or cold unless the head
space and timing are not correct between the ears of the pilot.
On Sat, Aug 14, 2010 at 2:07 PM, Linn Walters <pitts_pilot(at)bellsouth.net> wrote:
| Quote: | Kelly and Bob's post got me to thinking ..... it could be that the engine
Linn
KCHD |
Posted: Sat Aug 14, 2010 1:19 pm Post subject: Starting problems |
Engines with SlickStart get really hard to start when the retard points get worn. That can happen on some mags with very little time in service, i.e., as little as 100 hours. Check the condition of the retard points and time them per the instructions. Even retarded as much as one or two degrees after TC should be OK.
Dave Saylor
AirCrafters
140 Aviation Way
Watsonville, CA 95076
831-722-9141 Shop
831-750-0284 Cell
On Sat, Aug 14, 2010 at 12:24 PM, William Hicks <bilhicks(at)swbell.net (bilhicks(at)swbell.net)> wrote:
[quote] --> RV10-List message posted by: William Hicks <bilhicks(at)swbell.net (bilhicks(at)swbell.net)>
Couple of us with dual mags, no impulse couplers, slick start on io540 d4 a5, are having starting problems on both cold and hot starts. Â Engine eventually starts just as you release key from start position. Â We have checked the slick start and it is putting out spark. Â Any one have similar situation and if so did find a fix?
" target="_blank">http://www.matronics.com/Navigator?RV10-List
MS -
e -
     -Matt Dralle, List Admin.
kdbelue(at)charter.net Guest
Posted: Sat Aug 14, 2010 2:46 pm Post subject: Starting problems |
I had the same starting problem. I found that the start switch was wired wrong so the retard breaker was not working and both mags fired at 25 BTDC. Rewired switch and it starts correctly.
Kevin
On Aug 14, 2010, at 4:17 PM, Dave Saylor <dave.saylor.aircrafters(at)gmail.com (dave.saylor.aircrafters(at)gmail.com)> wrote:
[quote]Engines with SlickStart get really hard to start when the retard points get worn. That can happen on some mags with very little time in service, i.e., as little as 100 hours. Check the condition of the retard points and time them per the instructions. Even retarded as much as one or two degrees after TC should be OK.
Dave Saylor
AirCrafters
140 Aviation Way
831-722-9141 Shop
831-750-0284 Cell
On Sat, Aug 14, 2010 at 12:24 PM, William Hicks <[url=mailto:bilhicks(at)swbell.net]bilhicks(at)swbell.net (bilhicks(at)swbell.net)[/url]> wrote:
| Quote: | --> RV10-List message posted by: William Hicks <[url=mailto:bilhicks(at)swbell.net]bilhicks(at)swbell.net (bilhicks(at)swbell.net)[/url]>
MS -
e -
