Door Lock
Lew Gallagher
PostPosted: Fri Aug 13, 2010 11:51 am    Post subject: Door Lock Reply with quote
OK, here's another gizmo.
I got tired of trying to track down another same keyed lock for the passenger door (I'm not sure why Van's only gives you a keyed ignition, baggage door, and one passenger door -- and everybody is playing dumb about finding another lock to match the key number) ... so here's a simple and cheap solution.
It may have been done before but I just did this: The pictures are of a slice of angle iron with one leg trimmed to slide between the inner door handle (Van's stock handles) and the lock button, and the other leg is a little larger than the end of the handle so that it can be removed easily. All this does when inserted from inside the plane is to prevent the release button from being pushed from the outside (or the inside), effectively locking the passenger door. Then just lock the pilot door from the outside.
Done. Debate whether you want to fly with it locked or not, with or without large or small passengers, Wes won't.
Later, - Lew
 Filesize:  24.09 KB
 Viewed:  9222 Time(s)
 Filesize:  25.91 KB
 Filesize:  45.73 KB
 Filesize:  33.6 KB
non-pilot
crazy about building
NOW OFICIALLY BUILDER #40549
Fly off completed !
Eric_Kallio
PostPosted: Fri Aug 13, 2010 11:57 am    Post subject: Re: Door Lock Reply with quote
Very simple solution, but through Aircraft Spruce I ordered 3 lock sets keyed the same as my ignition. Were they not able to help you?
Eric Kallio
rv10builder(at)verizon.ne
PostPosted: Fri Aug 13, 2010 12:24 pm    Post subject: Door Lock Reply with quote
"and everybody is playing dumb about finding another lock to match the key
number) ... so here's a simple and cheap solution."
Another easy solution I'll throw out there- (courtesy of William Curtis-
check his website for pictures) go to your local lowes /depot and buy all
the locks you want. In the back of each lock box is the key code, get the
boxes with the same key code and .. gee look at that all the locks work with
the same key Wink
I think your design is swift! I however just drilled a 1/16 hole in the
lock button and put a clip in there, does the same basic thing, but your
design is a lot more solid than my pin.. for sure..
now if I can remember where that pin went
Pascal
Sent: Friday, August 13, 2010 12:51 PM
Subject: Door Lock
and cheap solution.
from the outside.
Later, - Lew
non-pilot
Fly off completed !
http://forums.matronics.com/viewtopic.php?p=308703#308703
http://forums.matronics.com//files/lock4_small_164.jpg
http://forums.matronics.com//files/lock3_small_100.jpg
http://forums.matronics.com//files/lock2_small_351.jpg
http://forums.matronics.com//files/lock1_small_333.jpg
Lew Gallagher
PostPosted: Fri Aug 13, 2010 12:36 pm    Post subject: Re: Door Lock Reply with quote
Yes, I checked into the Lowe's /HD lock sets, but the keys won't match the ignition key. I left Wes to check with Van's about getting another lock to match the ignition -- he implied that their response was that it couldn't be done and nobody mentioned Spruce ... and I really didn't want to put another hole in a door anyway!
Later, - Lew
non-pilot
Fly off completed !
PostPosted: Fri Aug 13, 2010 12:51 pm    Post subject: Door Lock Reply with quote
your solution is better anyway!
Sent: Friday, August 13, 2010 1:36 PM
Subject: Re: Door Lock
Later, - Lew
non-pilot
Fly off completed !
http://forums.matronics.com/viewtopic.php?p=308712#308712
eagerlee
PostPosted: Tue Aug 17, 2010 8:36 pm    Post subject: Re: Door Lock Reply with quote
here's a slight twist on the same strategy. A block that is hinged to the release button so you can pivot it into or out of position and you won't lose it.
 Filesize:  62.11 KB
 Viewed:  9143 Time(s)
 Filesize:  35.51 KB
eagerlee
PostPosted: Tue Aug 17, 2010 8:37 pm    Post subject: Re: Door Lock Reply with quote
 Filesize:  62.11 KB
 Viewed:  9142 Time(s)
 Filesize:  35.51 KB
