Overhead Console Airflow
n223rv(at)wolflakeairport
PostPosted: Wed Aug 11, 2010 5:36 am    Post subject: Overhead Console Airflow Reply with quote
Another overhead console question:
Do you get enough airflow, and in the right location from the overhead console only? I am thinking of only using the overhead vents for the front seat..... Unless they don't have enough airflow or airflow not in the right places.....
drfred(at)suddenlinkmail.
PostPosted: Wed Aug 11, 2010 6:34 am    Post subject: Overhead Console Airflow Reply with quote
You need both. I would not jut put in the overhead. I just don't think
you would be happy in the long run. I still use the side vents for the
front seats the most.
Dr Fred.
pitts_pilot(at)bellsouth.
PostPosted: Wed Aug 11, 2010 6:44 am    Post subject: Overhead Console Airflow Reply with quote
No real world experience since I'm building, but I'm installing the normal front seat air vents, and adding the overhead console with air vents for front and rear seats.  Only one NACA scoop on the right side behind baggage area feeds the OH console (from other comments here).  I also covered over the rear side vents that appears to cool the belly buttons of the rear pass.  I'll be flying mostly in FL, and that means those draggy vents will be open most all of the time.  Plus the crappy little arm as a way of opening/closing the vent didn't strike me as aesthetically pleasing..
Linn
Michael Kraus wrote: [quote] Another overhead console question:
href="3D%22http://www.matronics.com/Navigator?RV10-List%22">http://www.matronics.com/Navigator?RV10-List
href="3D%22http://forums.matronics.com%22">http://forums.matronics.com
href="3D%22http://www.matronics.com/contribution%22">http://www.matronics.com/contribution
aerosport1
PostPosted: Wed Aug 11, 2010 7:23 am    Post subject: Overhead Console Airflow Reply with quote
I would not cover up the side vents. I have both overhead vents and side vents. Passengers like both of them. More vents the better.
Just my 2 cents worth after 135 hrs flying and one of the hottest summers in Ohio recently
Geoff
Geoff Combs
RV-10 QB N829GW
Flying 500 hrs
40033
robin(at)PaintTheWeb.com
PostPosted: Wed Aug 11, 2010 8:13 am    Post subject: Overhead Console Airflow Reply with quote
Agreed!
Robin
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Geoff Combs
Sent: Wednesday, August 11, 2010 8:23 AM
Subject: RE: Overhead Console Airflow
Geoff
[quote] [b]
jchang10
PostPosted: Wed Aug 11, 2010 9:07 am    Post subject: Overhead Console Airflow Reply with quote
Thanks for that feedback. I was just wondering about these factory vents. The rear side vents seem to point at the belly buttons. The front one seems to be aimed at ones crotch. I was wondering about eliminating those, but alas i'll leave them be.
It is strange to be hearing about heat waves in the rest of the world. The bay area and most of CA is having lower than average if not record low temperatures all summer long. We'll be lucky if we break 60F. Of course, weldon still skinned over quicker than I expected. Will have to change my routine on the next window.
Jae
40533
On 8/11/2010 9:11 AM, Robin Marks wrote: [quote] Message
Agreed!
Robin
Geoff
#40533 RV-10
First flight 10/19/2011
Phase 1 Done 11/26/2011
dmaib@me.com
PostPosted: Wed Aug 11, 2010 12:22 pm    Post subject: Re: Overhead Console Airflow Reply with quote
My overhead does not supply fresh air, only air conditioned air or just the blower fan.
I put in the upgraded aluminum front seat vents and am very happy with them. Those front seat vents are capable of bringing in a LOT of air and can be aimed where you want it. I would definitely keep them. I don't have passengers in the back seat too often, but have had no complaints about the rear vents. I installed the little knobs that Alex D. sells to open and close them. They work fine.
David Maib
RV-10 #40559
New Smyrna Beach, FL
rvdave
PostPosted: Wed Aug 11, 2010 2:56 pm    Post subject: Re: Overhead Console Airflow Reply with quote
So which are the better of the vents that Steinair sells for the overhead, the 1 1/4 or the 1 3/4, someone mentioned the smaller ones work better? Wouldn't the larger provide more air flow?
Dave Ford
Cadillac, MI
aerosport1
PostPosted: Wed Aug 11, 2010 3:03 pm    Post subject: Overhead Console Airflow Reply with quote
Dave use the smaller ones. That is what it was designed for they work great.
Geoff
Geoff Combs
President
Aerosport Modeling & Design
8090 Howe Industrial Parkway
Canal Winchester, Ohio 43110
614-834-5227p
614-834-5230f
www.aerosportmodeling.com
Geoff Combs
RV-10 QB N829GW
Flying 500 hrs
40033
dmaib@me.com
PostPosted: Wed Aug 11, 2010 4:07 pm    Post subject: Re: Overhead Console Airflow Reply with quote
Dave, I used vents that look like these http://www.aircraftspruce.com/catalog/appages/largealumav.php
However, I did not buy them from Spruce. I bought mine, in black, from Van's about 2 1/2 years ago. I looked on Van's site and they don't appear to offer them any more. They were an exact fit for the vent and they work great. I don't recall what I paid for them at Van's, but I believe they were still a little more expensive than Stein's vents. I can't find any photo's of mine installed, but they look great, work great, and don't leak. (I have put them through pretty serious rain tests) Shocked
David Maib
RV-10 #40559
dmaib@me.com
PostPosted: Wed Aug 11, 2010 4:17 pm    Post subject: Re: Overhead Console Airflow Reply with quote
I think it might depend on your panel design. I have a SteinAir RV-10 panel and used the larger vents I mentioned in my previous post. They fit perfectly. I suspect that some of the other custom panels out there might work better with a smaller vent.
$.02 worth
David Maib
RV-10 #40559
rvdave
PostPosted: Wed Aug 11, 2010 7:07 pm    Post subject: Re: Overhead Console Airflow Reply with quote
Geoff
Thanks Geoff, that's just what I wanted to know.
Dave Ford
Cadillac, MI
rbibb
PostPosted: Thu Aug 12, 2010 3:19 am    Post subject: Overhead Console Airflow Reply with quote
Where does the input for the airflow for vents in the upper console come
from? Are some NACA vents put somewhere in the tailcone area connected via
SCAT tubing to the rear of the overhead console through the rear baggage
area bulkhead?
Richard Bibb
571-379-3290 mobile
aerosport1
PostPosted: Thu Aug 12, 2010 4:45 am    Post subject: Overhead Console Airflow Reply with quote
Richard here are some pictures of what a lot of people are doing. It works
really good and very easy to install. Also is a picture of my
Controller valve so I can adjust airflow as needed and totally shut of in
the winter.
Hope this helps Geoff
Geoff Combs
N829GW
 Filesize:  431.92 KB
 Viewed:  13598 Time(s)
 Filesize:  353.41 KB
 Filesize:  320.91 KB
Geoff Combs
RV-10 QB N829GW
Flying 500 hrs
40033
