chasb(at)satx.rr.com Guest
Posted: Sun Aug 08, 2010 10:14 pm Post subject: High pressure engine driven fuel pump |
I recently had an engine rollback which I determined was caused by low
fuel pressure on my AFP fuel injection system. Turned on the electric
boost pump and got the engine back. Diagnosis: failure of the engine
driven high pressure fuel pump.
Pulled the fuel pump off the engine today. The lever inside the pump
was stuck at the full up position. I could not move the lever. I know
in a low pressure pump, the lever can be moved by hand. Does anybody
have any experience with a high pressure pump? Should the lever be
moveable?
Second question: If the lever is jammed, can there be damage to the
cam in the accessory section? If so, how can the damage be determined
without pulling the accessory section off?
Charlie Brame
RV-6A N11CB
San Antonio
lessdragprod(at)aol.com Guest
Posted: Mon Aug 09, 2010 8:38 pm Post subject: High pressure engine driven fuel pump |
Hi Charlie,
I have my high pressure fuel pump off of my IO-540 engine. I can NOT move the lever by hand.
The reason seems to be that the strength of the return spring inside the mechanical fuel pump determines the fuel pressure delivered from the fuel pump.
Jim Ayers
Less Drag Special (modified HR2) 25 hours TT
Oxnard, CA.
